Question about Jura Capresso C3000 Espresso & Coffee Maker
The water gets diverted to the grounds collecting container and only half to one third makes its way into the cup. how can one fix this problem. done the usual of cleaning the machine cycle etc.
    President:
  • 1,618 Answers
Sounds like your coffee grind is a little too fine.
Posted on Aug 26, 2010
Measuring rice cup. it reads at the top 160g. and instructions say 150g. Two make 4 to 5 cups of cooked rice do I fill the cup to the top, two times?
Its the most easiest to make with any measuring utensil..
Find anything like a coffee cup .. If you put one coffee cupp full of rice put two coffee cups of water place a lid on set stove. on med to highish and wait til u no longer hear water bubbling inside the pot or if your lid is clear no longer see water Never stir until u know for sure its tender and if its done on top part its done on bottom part...
1rice. 2water
2 rice. 4 water get it.
Apr 11, 2015 | Kitchen Appliances - Others
How to freeze apricots
Before freezing, be sure you clean them thoroughly and avoid using any apricots that are damaged. Once apricots are washed and patted dry, cut them in half and remove the pits. Then slice them as you would slice peaches or any other similar fruit.
Boil a medium sized pot of water and dip the slices for about 30 seconds to prevent the skins from toughening, then place in strainer and run under cold water. From this point, freezing them may be done a few different ways, but the most important part is to be sure to include ascorbic acid to keep the apricots from turning brown.
One of the more common ways is to freeze them in a syrup. To make a simple syrup just add one cup of water with one cup of sugar to a pot. Heat and stir until all sugar dissolves. You will need about a half cup of syrup for each pint container you plan to fill with apricots. Then, add 1/8 teaspoon of the ascorbic acid to every cup of syrup.
Pour half of your syrup into a pint sized container you intend to freeze, then layer the apricot slices into the container, leaving about half an inch of space at the top, as the liquid will expand during the freezing process. After that, close the container, label it if preferred, and freeze it!
With this process, frozen apricots should keep for about 18 months if left in the freezer. Best of luck!
Jun 05, 2014 | Camping, Backpacking & Hiking
Water is leaking around base of "spout" and
If you have properly replaced the diverter assembly, there is either a problem with valve or debris was left in the valve from old diverter when new diverter was installed. Disassemble diverter by pulling spout back off. remove new diverter and check valve. Cup your hand over faucet and turn cold water handle on to attempt to flush any debris left behind. Try several times then reassemble. If this doesn't do the trick then replace. Get a quality filtering system and take care of your new faucet by making sure it's dry and polished after use. You won't be replacing your fixtures as often from calcium and corrosion.
Apr 23, 2011 | American Standard 4271S 'The Standard...
How many tablespoons of ground coffee are needed per cup of water in the Smart Brew coffee maker?
For ground coffee, use 1-1/2 (one and one-half) tablespoons of beans per 6 ounces of water.
For whole bean coffee, use two tablespoons of beans per 6 ounces of water.
Coffee strength is a very personal preference, so use these numbers as a guideline for middle-of-the-road coffee, and adjust to make the coffee that you like to drink.
Sep 30, 2010 | Black & Decker DLX900 12-Cup Coffee Maker
When making a cup of coffee, half the water flows back thru the vent resulting in half a cup of coffee. I have de-scaled but that did not fix. Any suggestions?
When the water comes back through the vent, it usually means that the TOP needle may be plugged with coffee grounds.
Unplug the coffee maker.
Lift up on the silver handle, and look inside. You will see a silver needle (similar to the one in the bottom of the K-cup holder). With a round seal surrounding it.
Straighten out a paper clip and run the clip through the center of the needle, and rotate it, then pull the clip out.
Plug the unit back in, and wait until it is ready.
Remove the K-cup holder, and run only water through the unit, as if you are making a cup of coffee.
You will see some grounds in the coffee cup, if the needle was plugged with grounds.
If this doesn't fix it, call customer service, the unit may be bad.
Jun 02, 2010 | Keurig B60 Coffee Maker
I don't know how to make coffee.
The best way, if using ground coffee, 1 teaspoon per cup. Depends how big your coffee pot holds of water. So if you're planning to make coffee for 12 cups, just put in 12 teaspoons. Best Part is you can ground your own fresh ground coffee, or ground them at your Favorite Store, like Hazelnut etc.
You can buy the pouches. They make them for 4 cups 6 cups 8 cups, etc. (Like the ones they give you when you stay at the hotel). Fill the proper amount of water, for cups you're making.
My favorite are the single cups. Folgers makes them in regular and decaf. Look like tea bags, and they for 1 Medium Cup of Coffee. After you are done, just throw away.
Good Luck :0)
Nov 11, 2009 | Krups Coffee Makers & Espresso Machines
Water leaks from underneath
Make sure your drainage tube is not plugged.
Check inside the back of your fridge to make sure the little cup that collects condensation from your freezer compartment is not plugged with food or ice.
(I had that happen in my fridge,different model). I had lots of water on the floor of the fridge until I found this solution here on fix-ya.
Also, make sure your fridge is set right for the the humidity levels you have may experience.
Get a hold of the manual for your fridge if you don't have it, and make sure freezer is not too cold.
If you have a lot of condensation on the outside of your door, look inside your freezer and try some different settings.
I'm not sure if this helps at all. Try blowing with a blow dryer on your condensation container area on the inside of the fridge.
I'd love to know if this helped.
Aug 26, 2009 | Frigidaire FRT18B4A Top Freezer...
SAECO Incanto Type Sup021 grinds and jettison grounds - no coffee
Here's how to fix your problem, remove the brew unit and clean the shower screen located at the top, under the red o-ring. Remove the screen and clean, then try coffee again this time adjust grind about 2 numbers coarser.
Jul 30, 2009 | Saeco Incanto Classic Espresso Machine
How do you make coffee in cafetiere 6 cups
You grind the beans quite fine
Pull up the knob on the lid till it pulls out of the top and the filter out of the glass container.
Put enough of the the ground coffee for six cups into the glass container , pour on boiling water till it reaches about one inch from the top
Put the top back on a push the knob slightly down to locate it in the top of the glass container
Give the water a few minutes to work on the beans and then gently push the knob all the way down so that the filter goes to the bottom og the glass container taking the grounds with it
Pour the coffee
Enjoy!!
Jun 19, 2009 | La Cafetiere Santos SN030200 3-Cup Coffee...
Blinking red light
When you prime the machine, can you get a full cup of water or just a half?
If you only get a half then you have to replace the "water turbine" in the machine.
Mar 04, 2008 | Saeco Trevi Automatica Cappuccino
Jura Capresso C3000 Espresso & Coffee Maker Logo
48 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Jim Goldsmith
Jim Goldsmith
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
