Question about Casio FX-115ES Scientific Calculator
Does the calculator rely completely on solar Not turning on Do you have to change battery
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
The calculator uses a battery in addition to the solar cell. If the battery runs down you need to replace it. Turn the calculator over and you'll see the battery compartment in the upper-right corner (with a screw holding it shut). The calculator takes a LR44 battery or equivalent.
Make sure you clear the calculator after replacing the battery: press ON SHIFT 9 3 =
Posted on Jun 07, 2012
5 Suggested Answers
marsrover
  • 682 Answers
SOURCE: Problem
take the old battery to radio shack near you and buy a new one.
Posted on Feb 29, 2008
jurassic
  • 55 Answers
SOURCE: Calculator won't come on
most calculators have solar power strips on top so if there is no strip its not solar. there should be a plate on the back if there is a screw you found the batterie area put a few calculators have to be pride open to get to the batteries but it usily depends on the brand of the calculator.
Posted on Aug 13, 2008
vladp995
  • 81 Answers
SOURCE: My Casio fx-85v Super - fx solar power calculator shows a erratic
Yeah I had the same problem, you need to open your calculator and check if all the screen cables is alright, i had just put sellotape on the back of the screen from inside so that the screen hold better, and it works for me if for you not maybe something broken in the schema but try it. The thing I know for sure the problem is in the screen or from where it get the data the schema. Tell me if it's working
Posted on Jul 07, 2009
  • 38 Answers
SOURCE: I haven't used my calculator in some time. Now
If it is solar powered and hasn't been used in some time, the battery may have died, permanently. If there is no battery to replace then it is broken forever. Sorry.When batteries are left without juice for a long period of time they die, and cannot be recharged.
Posted on Sep 15, 2011
Texas Instruments TI25X SOLAR Calculator didgets not all showing
Even if there is an issue with the calculator it is no longer relevant because it is a discontinued product. It does not have a backup battery and it only uses Solar Power. I suggest to expose the panel to sun light to fully activate the display. And then again it may be just old age, and it is time for you to get a more powerful calculator.
Jun 14, 2012 | Texas Instruments TI-25X Solar Calculator
I haven't used my calculator in some time. Now when I go to use it, it won't turn on. I've pressed on and clear and reset. Nothing. It is solared powered and its not like I just change the...
Sep 14, 2011 | Office Equipment & Supplies
How do I recharge it ?
You can't recharge it. It is a solar calculator with watches battery. You need to change the battery.
Mar 01, 2011 | Texas Instruments TI-30 Xa Solar...
How do you change the battery? The solar cell has stopped working.
It does not have any batteries, it's purely solar-powered. Cost for a repair most probably would exceed the value of the device, sorry,
Jan 09, 2011 | Texas Instruments BA-35 Solar Calculator
My HP 10s Scientific calculator does not switch on what could be the problem, is it maby because the calculator was left in a drawer and now the batery ran flat hou can I charge it on the solar power...
You can't charge the calculator off the solar power panel. The solar power panel merely conserves battery power when using the calculator in a bright environment. Try putting in a new battery and see whether the calculator turns on.
Aug 25, 2010 | HP 10s Scientific Calculator
Can I do numbers squared on this calculator, and how would I enter this?
The TI-30XA is a scientific calculator with many functions. You can calculate problems with fractions and decimals, as well as solve problems of probability and functions. A scientific calculator computes the number sentence you type in using the order of operations: parentheses first, then roots and exponents, then division and multiplication and, finally, addition and subtraction.
How to Use a TI-30XA
  • Step 1Press the [ON/C] key to turn on the calculator. Press the [OFF] key to turn it off. To use the calculator in solar mode, put the solar panel in the light and then press the [ON/C] key. To turn it off when in solar mode, slide the calculator cover back on and it will automatically shut off.
  • Step 2Replace the batteries by first removing the cover and placing it face down. Use a Phillips-head screwdriver to unscrew the back panel. Remove the back panel and change the batteries. Screw the back panel back on. Press [OFF] [ON/C] and [ON/C].
  • Aug 08, 2010 | Texas Instruments TI-30XA Calculator
    New Battery???
    Try to expose their solar panels to direct sunlight (10 or 15 minutes), just to see if they come back to life.
    Hope it helps.
    Jun 23, 2009 | Texas Instruments TI-15 Explorer...
    Aug 13, 2008 | Texas Instruments TI-30XA Calculator
    Lower half of numbers gone
    The only solution which can be tried is replacing the battery.
    Goodluck.
    May 06, 2008 | Texas Instruments TI-36 X Solar Calculator
    Problem
    Feb 25, 2008 | Office Equipment & Supplies
    Casio FX-115ES Scientific Calculator Logo
    109 people viewed this question
    Top Casio Office Equipment & Supplies Experts
    k24674
    Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
