Question about Microwave Ovens
The water appears to heat up, but does not flow through to make the coffee. What can I do?
  • Judith Kaufman Aug 29, 2010
    something seems to have gone wrong. This was not a question about a microwave but about my Keruig coffee maker...again the water heats up but does not flow through to brew.
    I keep sending notes that it is not a microwave problem which did not obviously get through.
    thanks for your help
  • Microwave Ovens Master
  • 43,501 Answers
The magnetron or the part the make the radiation that causes the heat has gone bad....it can be replaced but it really is not a DIY job, it is too dangerous....high voltage...
Here is a tip that I wrote that will help explain this further...
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 25, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Aug 30, 2010
    I was wondering but I see some strange ones here...:-)
    For that I would say that if you have waited till you can get no water through then it may be too late to do anything that would not cost more then buying a new one...
    If you can still get any water through then go this route...
    mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
    heatman101
Sparks from wave guide
the magnetron may have burnt itself up. it may be time to replace
Nov 05, 2013 | Microwave Ovens
My Keurig coffee maker keeps flashing prime and nothing we do makes it go away and it wont make coffee.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 21, 2011 | Microwave Ovens
Coffee is not coming through spout. Water just builds up and when switched off it flows into drip tray. Coffee machine bought new just over a year ago. Freshly ground coffee beans being used at the correct...
The water valve has failed - the internal shaft that moves the flap was sheered off. The valve would have to be replaced by a dealer or certified repair shop - they are the only ones with access to replacement parts.
It will be expensive so ask an estimate before accepting the repair - it might be cheaper just to sell this one for parts and get a new one.
Aug 21, 2011 | Microwave Ovens
We have a 12 cup Mr. Coffee about a year old. We put 4 scoops of coffee in and the appropriate amount of water. Every day, the filter overflows and grains of coffee get into the pot. How do we keep this...
Because I own a espresso company,I believe I can help you. There is several things that can cause a coffee machine to over flow. 1, putting to much coffee in, where water can not drain through filter. 2. The grind of the coffee, if it is ground to fine, like ground for espresso, will not allow coffee to flow through filter , drip machine that are not under high pressure like espresso machines have to have ground more course. 3, wrong type of filters, not fine enough for water to flow, or made for high pump pressure machine such as espresso machine . 4, putting to much water in, is not an issue on a mr coffee, because even if you fill it to full cup line, it would have nothing to do with filter over flowing, besides the coffee grounds always absorb some of the water anyway. In conclusion, my positive professional diagnose is Grounds of coffee to course, and 4 scoops seem a bit to much for a filter of a mr coffee machine that holds only 12 cups. To test this is make a pot same way and use only two rounded scoops and see what happens, if does not over flow that solves that. But your saying I want it stronger, believe me I know. I too like my coffee strong and a flavorful . I have that solved too. Go to a good walk in espresso shop, like a star bucks, tell them you want some good strong blend and have it ( Ground for Drip) and then still only put two rounded scoops, it takes less do to the blend and kind of coffee. Please let me know if my advice worked, thanks mike. oh notice my screen name of mc1 bean, now you know, I know what I am talking about :)
Jun 07, 2011 | Microwave Ovens
13402 coffee maker. switch light on and fuse ok. no loose connections. no heat in hot plate. not siphoning water from tank
Appears heating element is open circuited ,if resistance meeter is used between active and nuetral and resistance higher than 100 ohm indicates open circuit in element as indicator light should be in parallel with the element .The problem could also be caused by either over temperature safety thermostat which may have to be replaced if it is not reseteable or the thermostat itself is faulty.
Get someone with electrical expertize to check these
Apr 29, 2011 | Microwave Ovens
How do you go about "descaleing" the coffee maker? The water does not flow through the coffee capsule very well.
I know that most grocery stores sell a "cleaner" or two next to their coffee filters/coffee makers/kitchen appliances section. These are usually heavily acidic, and will do a great job of cleaining your coffee maker. I've always been wary of acid in my coffee though, so I just use white vinegar. It'll do a decent job of cleaning out the coffee maker. Run a 1:1 mix of water and vinegar through your coffee maker, drain it, then run water through at least twice.
Scaleing/deposits building up in a coffee maker are signs of imperfections in the water. All tap water has it, but if you don't want to worry about it, use bottled or filtred water in your coffee pot. Plus, your coffee will taste better!
Mar 16, 2011 | Microwave Ovens
Our Magimix 11400 (less than 2 years old) heats normally, the vapour nozzle fonctions too, but our problem : when the coffee selection switch is put on the motors starts up, seems to fonction properly but...
Hello Pat, You have a common occurring problem. Your tubing in clotted. The least expensive solution is to use regular vinegar instead of water for several cycles, no coffee grounds. The clot will dissolve and water flow will return to normal. Cycle just water until no taste or smell of vinegar is present. Have some HOT COFFEE.
Oct 12, 2010 | Microwave Ovens
Microwave Ovens Logo
13 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
