Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
Why doe's my fax-mahine need a replacement battery. It say's; Relace Battery Info. code= 026?!
  • Panasonic Master
  • 3,866 Answers
So when the power goes out, you do not loose your stored contacts, Fax transmittal's, and the list goes on.
That is why the battery needs to be replaced,
Questions please ask
please do leave a positive ratings and feedback before you go, thanks
Posted on Aug 25, 2010
  • Grand Canyon Tech
    Grand Canyon Tech Aug 25, 2010
    http://static.fixya.com/Manuals/P/Panaso... 149 it shows you where the battery is at.Thanks for using fixya.com
  • Grand Canyon Tech
    Copy and paste to your browser it will donwload the pdf file for you, you need adobe pdf reader witch can be found at www.adobe.com
Need to find a replacement battery and don"t know where to find one Part #254-026 6.0v battery
Hi beechparent,
Welcome to fixya!
It would help a lot if you give me the make and model of tool and what it is.
Please reply back,
Thanks,
Handie Andie
Jul 02, 2011 | Garden
Xerox workcentre pro 5225 exrror code 026-714
the Xerox error code 026-714 means that the printer cannot access a remote proxy-server. if the printer has been configured to use this remote proxy instead of your local one (or none at all), none of the mentioned network functionalities will work supposedly.
Feb 26, 2010 | Xerox Workcentre 5225 / Copier, With...
Replace battry ifo code 026
Pull out the gray tab on top of the operating panel next to the blue lever. The battery is a CR2032.
Jan 01, 2010 | Panasonic Panafax UF-595 Plain Paper Laser...
Reset Error Code F6-10 for Sharp AR-M277
This code is communication problem between the machine and fax board... The battery on the fax board will need to be replaced.
Usually turning off your machine will make this go away,
for awhile.
Sometimes preventing your machine from going into Sleep Mode also helps.
The Fax Battery is much like the CMOS battery in a computer.
A large round thin battery, (much like a watch battery)
To replace this, the fax board has to be removed, The battery is Soldered to the Board, you have to unsolder the battery, then solder the new battery to the fax board, then reinstall fax board, then set jumpers on fax board. Turn machine on, do some simulation settings, turn machine off, remove jumper from fax board. Then restart, hopefully you will not have to reset the county code.
Unless your experienced with this, do yourself a favor and call a tech..
Sep 25, 2009 | Sharp Office Equipment & Supplies
Manual for panafax uf 585 . it says info code 26 >> replace battery. I dont know where is the socket for battery? Can you please send me a picture for the same or a solution
Hi manish717
You can download a manual free from the following link.
You will have to give your email address.
After downloading, goto page 151 where you will find the answer as how to replace the battery.
http://www.retrevo.com/s/Panasonic-UF-585-Fax-Machines-review-manual/id/313ag417/t/1-2/
Hope this will work for you, Have a Good Day
If this answer helped you, please give a rating
luciana44
Sep 22, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
Replacing the LCD battery on a Panafax UF-885
Open up the document feeder by pulling straight up.
You will see a white tab sticking out of the black base.
Push FIRMLY towards the rear with your thumb.
The battery is a CR-2032 as printed on it.
Feb 02, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Sending Documents
First the battery.
Along the top edge of the operation panel you will see a blue tab. just to the left of that tab you will see another beige tab of the same size, this is the battery holder.
Open the toner door and open the feeder ...pull upwards 1 inch until it stops.
Pull the beige tab out...not the blue one.
Take the battery to radio shack or CVS Pharmacy and match it up....CR-2032.
Next step:
press the MONITOR key and listen for a dial tone.
plug a regular phone into the phone jack to check for a dial-tone.
If all else fails.
Press FUNCTION
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
press set
set
wait for the machine to initialize and reboot itself.
Oct 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
231 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
