Question about E-Machines T3958 (827103050974) PC Desktop
I AM INSTALLING A NEW POWER BUTTON... I NEED TO KNOW WHAT PLUGS WHERE...
  • 2,229 Answers
If it's the power button that is on the case, it plugs into the motherboard. Most likely, in the lower right hand side as you are looking into the case with the front of the case to your right.
The little row of pins is labeled. You are looking for the label pwr sw or something similar. If you can't see any labels, short each pair of pins with a small screwdriver--two at a time. When the machine turns on, you've found the correct two pins.
Posted on Aug 25, 2010
Could improperly installing a new exhuat system make your transmation not shift gears
not that I know of unless they pulled one of the wires(plugs) accidentily
Apr 11, 2015 | 1995 Nissan 200SX
How do I replace the spark plugs?
This requires a certain amount of mechanical skills and knowledge of how to use a torque wrench properly. To begin the process know that the spark plugs are recessed deep in the valve cover. Follow the high tension 8mm wires from their individual coil-paks directly to the respective plug and carefully remove. Now using a 5/ 8" deep well plug socket and an 8-10 extension carefully remove the plugs. Install new plugs (spec per mfg.) I like the iridium then platinum, but check to ensure gap is correct before installing the new plugs. Now take plug and insert into plug socket then carefully lower into recess until you contact threads lightly. Rotate plug clockwise with very little pressure keeping plug socket 90 degrees until you get proper thread engagement. Continue installation of each plug then torque to spec, and reinstall all wires.
Jun 12, 2014 | 2006 Toyota Corolla
When I push the power button the blue lights come on for about 1-2 seconds and turns off. Totally black screen no power.
Sounds like you just need a new power supply. I had the same thing happen when mine died on me. NewEgg.com has them at a good price if you want to wait for shipping. Not sure if Staples or places like that carry power supplies. Make sure it's the same voltage or lower as the one you have in there now.
Mar 23, 2011 | Computers & Internet
Kawasaki kdx 125 plugs oil up and bike stalls
I think you have worn internal engine parts. To much oil is getting past the piston rings. Try installing new piston rings and honing the cylinder walls.
May 23, 2010 | kawasaki Full Suspension Mountain Bike Men
The power just dosn't come on have tryed the reset button and changed wall plugs so I know I have power but it just dosn't turn on
Your bluetooth or Wifi module might have stopped working on the Wii. If this is the case then you can buy a replacement. If that doesn't fix your problem then you will need a new motherboard. Email me at mr_fix-it@live.co.uk if you need any more help.
Feb 13, 2010 | Nintendo Wii Console
I need to know how to install spark plugs on a 2004 dodge durango
3.7L and 4.7L engine have ignition coil for each cylinder. You need to remove the resonator from the throttle body. Now one a time disconnect electrical connector from the coil. With a 10mm socket remove the bolt, now remove the coil , (it will be really tight). You will need different lenght extenions to reach the spark plugs. When installing new plugs use piece of hose to start plugs (so not to cross tread the hole)
Oct 22, 2009 | 1998 Dodge Durango
Kohler propane genset won't stay running
hi
try a new plug with the same heat range
bye
Jul 07, 2009 | Electrical Supplies
No power getting to my radio i am in the middle of putting in a new radio and there is no power getting threw the harness
what type of vehicle do you have? check the fuses in the box or box's. what type of radio are you installing and are you using the aftermarket wire harness that plugs directly into the factory chassis harness? sorry about all the questions but this will really help me solve your issue. thank you and let me know
Mar 04, 2009 | OEM Systems Car Audio & Video
Connector pulled off power buton wires
Hi ford, the most common case colored wires used for negative - is white. The colors blue, red, green are usually positive +. The internal speaker though it uses a 4 pin connector only plugs onto the 2 end pins. Black is connected to negative - pin & red is connected to + positive pin. (Depending on the MB model).
All these case LED's use 5volts DC. If you make a boo-boo, don't freak out. You can usually shut down the system & turn the connector 180 & re-connect it with out hurting the board. Suggest you connect 1 at a time & check in-between each.
Still having trouble, include the name & model number of the MB.
Mike
Sep 28, 2008 | Computers & Internet
Pavilion 525C won't start
HP Pavilion 525c/525c-b
Model Comments - 266MHz FSB, NVIDIA nForce2 IGP Chipset
After installing a new harddrive
The system may not boot and may need to be reconfigured.
You may have setup your new harddrive incorrectly.
Your system BIOS may require you to check it's settings due to the addition of new hardware.
It's recommended that you check your system bios configuration for errors after installing new hardware.
Az.
Sep 23, 2008 | HP Pavilion 525c (DD210AR#ABA) PC Desktop
E-Machines T3958 (827103050974) PC Desktop Logo
22 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
