Question about Toshiba (K000016310) Cooling Fan
I have a Toshiba satellite P200/P205. The area around the touch screen gets very warm. is this normal or is there a fan under the keyboard ? Please help. Thank you
    President:
  • 548 Answers
It is quite normal. Relax.
Posted on Aug 25, 2010
I cant unlock the mouse of my toshiba its a satellite P205-S6267
Hi Good day!!! Try fn and f9 it toggle your touch pad on/off
Thank you for using FixYa
Please accept if my solution helps you
Nov 10, 2010 | Amstron Toshiba Satellite P205-S6267...
Laptop toshiba satellite p200 bw5 screen goes dark as if darkness/brightness was adjusted - but not Thanks
An LCD screen cannot produce enough light by itself. It needs a Backlight to help illuminate the screen.
Power for the Backlight is produced by an Inverter. An Inverter also provides power for the LCD screen.
It reduces voltage for the Backlight, and increases Voltage for the LCD screen, from the laptop's power.
Most of the time a dark LCD screen can be attributed directly to a bad Inverter. (Around 90 percent)
A Backlight is a CCFL.
Cold Cathode Fluorescent Light.
VERY similar to the fluorescent lights you see used in residential, and commercial applications.
(Homes, and businesses)
Only on a MUCH smaller scale in physical size, and needed power to operate.
When a Backlight goes bad, it just goes all at once. Not goes dark as you have stated.
(Your statement meant to me that you power on the laptop, the LCD screen shows well, then goes dark)
How to install an Inverter in a Toshiba Satellite P200 series laptop,
http://www.irisvista.com/tech/laptops/toshiba-satellite-p205/take-apart-display-panel-1.htm
(You can click on each individual photo to enlarge. You are on Page 1. Page 2 is accessed at the bottom, by clicking on it. Page 1::Page 2::Find another model)
Just one of many places that offers an Inverter for your Satellite P200.
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=5367&zenid=43bc1e775a9ed2d4309140111231cab5
NOTE*
1) ALL power removed from the laptop before beginning.
AC adapter (Charger), and Battery.
2) The screws you will remove, may have screws that look alike, but are NOT.
Do Not mix them up.
For this reason it is suggested to use a multi-compartment container, and label the compartments for where the screws came out of.
You can use a clean egg container, and label the individual egg holders, in a pinch.
IMHO it isn't hard to perform this repair, and you can do it. Save yourself money.
For additional questions regarding this, or comments, please post in a Comment.
Regards,
joecoolvette
Oct 22, 2010 | Computers & Internet
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
@ KEY NOT WORKING
if one key on the keyboard no longer functions, try an external keyboard. It the external keyboard works normally, replace the built in one
Jan 18, 2009 | Toshiba Satellite A100-S8111TD Notebook
Need to unlock phoenix bios password for toshiba satellite a135-s4527
remove the keyboard the mobo battery is there you need to unsolder one end of it, lift the leg, and turn it on that way for it to clear.. you will have to resolder once done.. have the skills or find someone that does... and you're set..
Jan 16, 2009 | Computers & Internet
All for Toshiba Satellite P205-S6287 notebook
I am thinking that he just provided a set of drivers for this Laptop...
He simply put it there and said nothing...
Jul 22, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Touch Pad
Looks like you need to get a replacement touchpad. If its still under warranty then you can avail it to get a new touchpad. Otherwise you will have to shell out around 100$
May 23, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Changing hot keys on laptop
Dullahban,
The key functions along the top of the keyboard can not be changed. They are preset and all of that model function the same.
PAeasop
Apr 24, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Satellite P205
mosture in it rust try taking it aprt look in side under keybord take ram out hit reset on bottem try that 1st blow dryer it under keybord lift it up pop top panel up around screen 2 screws on back
Jan 23, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Toshiba (K000016310) Cooling Fan Logo
100 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
