Question about Dometic Rooftop RV Air Conditioner
Rooftop A/C in-op. Clicks when t-stat is turned to "cool" but no fan or compressor. Breaker set, t-stat good.
  • Dometic Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 30, 2010
Why does air conditioner trip circuit breaker?
call the technician
indicates a compressor problem
could be a failed start/run capacitor or compress failure
Nov 19, 2017 | Heating & Cooling
Dometic roof top AC unit compressor turns on even if T-stat is off. Only way to get the compressor from turning on is to turn the breaker off. Unhooked T-stat wires to see if issue was there but the...
Sounds like you may have a couple of problems there. First, have you checked incoming voltage to make sure you are getting 100-120 VAC at the AC control board in ceiling? If that's ok, try removing/disconnecting Ac compressor wire at ceiling control box and see if compressor shuts off then. May be a capacitor for compressor going or shot, and possibly relay in control box sticking, or bad wiring to thermostat. Have you had any lightning in the area prior to all this happening?
Jan 23, 2013 | Dometic Rooftop RV Air Conditioner
Compressor will not stop running
There has to be a stat or switch or controller of some kind on the rv. I would check that first. If you have a battery operated stat then try changing the batts, otherwise it could be the contactor on the unit or a bad stat.
Apr 26, 2012 | Dometic Rooftop RV Air Conditioner
Dometic unit cools great but compressor does not cut off when desired temperature is reached. The thermostat is on wall. The fan will cutoff at proper temperature but the compressor keeps humming and...
Hi, as you know the thermostat controls the unit. Here's what you need to do first. Go to your thermostat on the wall, pull off the cover. You are looking for the main control wires that come in from the back to connect to the screw terminals. Don't be afraid of shock as these are millivolt wiring connections.You say the fan shuts off but the compressor keeps running causing it to ice up. You need to get a screw driver and disconnect the wires from this stat. This should cause the compressor, fan, and all to shut down. If it does, you know that your thermostat is faulty and you will need to make your self a drawing on the wire connections, remove the stat, and you can get a new one at a RV sales and parts house.Find your breaker box where your main wiring comes in and shut off the a/c breaker if you like. Now, if the compressor keeps running after you disconnect it from the thermostat, then somewhere from the stat to the controls on the top have a hot wire that is touching somewhere causing the compressor to be energized all of the time. If you can go up top and find where this thermostat wire comes in, look it over good to see if the red is touching the yellow wire some where. I believe you just have a faulty stat at this point. Do what I asked on the stat, disconnect it completely, and we will go from there. You can get back to me by leaving a comment under my user name. Please let me know and we will take care of this problem.
Sincerely,
Shastalaker7
A/C, and Heating Contractor
Oct 01, 2010 | Dometic Rooftop RV Air Conditioner
Rooftop RV Air Conditioner: replaced capacitor on dometic 59516-531 steal trip...
You need to borrow a clamp on style amp gauge, and check amp draw on black wire in box where hydro wires connect. (PLEASE, be careful, and if not experienced in this type of test, don't try it, due to likelihood of getting a shock. ) If it's the compressor kicking in that's causing the breaker to trip, and capacitor is good, then it's usually a problem with either low incoming (supply) 110-120 AC voltage, which will cause high amperage draw, or compressor on it's way out causing high amp draw. If it's only drawing 15-18 amps, and your tripping a 20 amp breaker, then breaker is getting weak.
May 18, 2010 | Dometic Rooftop RV Air Conditioner
Rooftop air, when stat calls for cooling, fan comes on but no compressor. If I switch the stat of & on a couple of time manually, the fan and compressor both come on. Does this sound like the start...
Good place to start checking for voltage, in and out of relay when triggered. ( careful, if not experienced with electrical, you have capacitors nearby that can zap you real bad if not familiar with them.)
Apr 13, 2010 | Dometic Rooftop RV Air Conditioner
Ac fan wont turn on clicks when go from on to off and high to low motor spins free
Any sound from compressor or just clicking on every setting. Did you double checked (breaker) that you have hydro (120VAC) to it?
Aug 17, 2009 | Dometic Rooftop RV Air Conditioner
Dometic roof air
Sounds like the unit either has been miswired from the beginning or there is a stuck contactor relay.
The more rare scenario is that the control wire between the t-stat and the contactor is shorting to a power source causing the relay to energize. Good Luck!
Jun 23, 2008 | Dometic Rooftop RV Air Conditioner
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
99 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
