Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
I have a Sony TV Projection TruSurround by SRS, its showing blurriness on the Screen. It has red outlining on the words, i think it may need to be re aligned or possibly some of the hardware may need to be replaced???
    Top Expert:
  • Sony Master
  • 14,553 Answers
See attached photos, it sounds like a convergence problem.
The model indicated uses two of the STK-392-560 chips for this. Usually replacing both will fix the problem.
Total parts cost on EBAY for this repair (I use the seller) will be under 25 dollars and repair takes less than a hour.
I have fixed over 1,000 sets with this problem--I can assist you if you need help.
If this told you something you did not know or you want more information, rate this solution as very helpful as I do this here for you for free.
SD TECH
92236ed.jpgTypical convergence chip---your set's should have STK-392-560 PRINTED ON THE FRONT OF THEM.
Posted on Aug 25, 2010
This gray box won't go away on my uncle's TV. It says "Video 5 Cable Box" and appears at the upper left-hand corner and won't go away. It has been there for a few days. It's a first. The TV has...
hello my name is rico, you have bad main board, and it needs to replace it, for the square box to go away. if you need more help, call me anytime. 602-810-7149.
Jan 07, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Our tv has red and green shadows on the picture when words come on at the bottom of screen they look like a shadow double Peoples faces will be outlined with red and green lines
your color engine is failing its also known as the optic block and they are very expensive to replace good luck google the optic block failure in these sets to better educate yourself with what your dealing with ok it most often blue that shows the failure but green and blue to and red
Dec 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My Vizio Tv volume does not work properly. When its at volume 100 it sounds like volume 50. What could be the problem? My question is how can I fix it? Let me know...
Okay I just called and found this out. I have the 32 inch vizio hd flat screen. My problem with weak and fluctuating volume, was that I have a cable box. Go into menu, then audio and under the advanced audio section you will see srs trusurround HD and srs trusurround. Basically this function automatically adjusts volume levels for satelites and whatnot. But because cable boxes automatically have this feature you could just turn off the srs trusurround. Hopefully that should help you.
May 10, 2010 | Vizio VF550M 55 in. LCD HDTV
Red lines, blurry picture
try this link. It fixed my sony.
www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 29, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony KP-61HS10 st start up blurry gets better the longer its on
You have loose solder connections on the convergence amps.This is a common problem caused by heat within the unit.If you can solder you can fix it.
Jan 12, 2009 | Sony KP-61HS10 61" Rear Projection...
Sony 52in Projection TV
Thanks for including your model number! Just change the lamp and it should be good to go.
Jun 22, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Samsung SRS TV
Have you attempted to go into the menu and adjusting the convergence.. Check in the menu and line up the bars. If this does not work it might need to be adjusted manually.
Thanks Steve
Mar 27, 2008 | Televison & Video
Hitachi ultravision
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 04, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Blurry Image problem with Mitsubishi WS-55805
Hello, if you want I can supply you with the service manual, please leave your email. Best regards, Arpi
Aug 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
297 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
