Question about Bosch 4000 - 07 Electric Table Saws
Motor stopped spinning. it will barely turn in the counter direction, but wont turn at all in the right direction!
  • 2,176 Answers
You have a motor/bearing problem. UNPLUG tool and turn on its backside and remove the back motor cover and see if the bearing has collapsed. and remove brushes to see if motor burnt
Posted on Aug 26, 2010
Kenmore 80 Series 110.27802690 agitator barely moving
It's the transmission that's bad. The motor turns one direction to spin and the opposite direction to agitate. The transmission converts the constant belt speed from the motor into the back and forth motion. In the other direction, the transmission stops and the whole system spins.
(I don't suspect you have it set to "delicates")
Jul 20, 2016 | Kenmore Washing Machines
Maytag fav6800aww will not finish cycle
No spin, or lite spin try these: bare in mind that many times there is no spin it can be due to a clogged water pump so check it for debris and or broken propeller.
Other items to check Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. Bare in mind the lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a ****** *****. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next if belt driven check for a loose, worn or broken belt. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand. And in some models check with a meter for continuity and voltage.
LID SWITCH TEST- next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,
basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer
http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN
By the way my advice is free cuz God is good!
Diagnosing and Repairing Spin and Agitate Problems in Whirlpool Kenmore...
Mar 21, 2017 | Maytag Neptune FAV6800AW Top Load Washer
How to correct trimming problems did what the insteuctions said and keep having the same spinning counterclockwise problem
Just bought the air hogs helicopter with the crane. Had the aircraft constantly spinning clockwise, no matter how much I turned the trim control counter clockwise the aircraft still rotated. I then turned the trim control in the opposite direction until I noticed the aircraft had stopped spinning, and used the rudder control to fine tune forward flight. So, get the aircraft to hover and turn the trim button in the opposite direction until you see that the aircraft spinning slows right down. If you continue to turn the trim control in the same direction the aircraft will increase its spin, so just dial back the trim.
Dec 29, 2012 | Air Hogs Havoc Heli Helicopters
Machine wont spin. it tries but stops
Hello there and thank you for choosing fixya
This is a very common problem with top load machines
Direct Drive Washer Motor Coupler Problem Discussion coupler-exploded.gif couplers on direct drive washers fail almost more than any other part. When it fails it will prevent the washer from agitating and spinning but it will still drain as the pump is connected directly onto the motor. If the water is draining, the motor is functioning properl this is what it looks like
PLEASE LET ME KNOW IF YOURS IS DIFFERENT OK IF SO I CAN GET YOU THE RIGHT DIAGRAM tbirdfan1_13.gif
Aug 15, 2011 | Fisher and Paykel IWL12 Top Load Washer
Drill stopped during a day of usage. Motor was getting hot and just started to smoke. I stopped using the drill so it could cool. Two hours later, it makes a buzzing noise, but the drill will not spin. ...
the heat has seized the motor or plastic gears im leaning more towards the motor
disassemble the drill and take a look all the parts pretty much stay in place see if
you can turn the motor by hand if it wont turn use some 3n1 oil on each end of the
motor that shooed do the trick
hope this helps you
good luck
bob
May 08, 2011 | Dewalt Makita Bhp452 18v Cordless 1/2"...
Model WJSE4150B2WW ser# AF171808G GE washer agitates but won't spin with front cover off motor turns belt in the right direction for just an instant and then stops interior basket can be turned...
When spinning the motor freezes up and will not spin. I released the motor and took off the belt off and the motor ran fine. However the pulley that the belt is also on will not spin the proper direction, only backwards.
Mar 03, 2011 | GE WJSE4150B Top Load Washer
When i turn a/c on. the motor barely spins. it wont even spin fast enough for the thermostat to kick in.
mcdevito75 here, Sounds like the fan motor is shot, Check with your local a/c repair shop or replace the unit.
Jun 21, 2010 | Frigidaire FAH125N2T Air Conditioner
Hi I our agitator has stopped turning. It barely will move back and forth.
Set the washer for spin and turn it on.
Does it spin?
If no.
Check the direct drive coupling on the motor.
Mar 08, 2009 | Whirlpool Washing Machines
Hoover six express wont spin
all hoover machines spin in a clockwise direction the fact that you say the machine only washes in an anti-clockwise direction is a good indication that the reversing switches have failed (these provide the switching to drive the motor in either direction) if your machine uses a mechanical type programme timer this has failed if it it is a processor controlled machine it will be the motor drive card will need to be replaced either way not a diy task
Apr 21, 2008 | Washing Machines
Bosch 4000 - 07 Electric Table Saws Logo
106 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
