Question about Poulan Garden
I have a Poulan 3312 Pro, the primer bulb opped off...how do I re-attach it?
    President:
  • Poulan Master
  • 1,545 Answers
You may have to get a new one that has more flexibility and will stay in place. External bulb assemblies snap in place and the ones on top of the carburetor of course have a metal retaining ring with 2 screws holding the primer bulb to the primer base.
Posted on Aug 25, 2010
Changing a primer bulb on a poulan pro chainsaw?
If it is one those that is extrenal to the carburetor you change the whole primer assembly and not just the bulb.
Feb 26, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
POULAN PRO PP446 HOW TO REPLACE PRIMER BULB
get a new one and just unscrew the screws that hold it on and just put the new one back on with the srews.
Aug 03, 2014 | Poulan Garden
How to change/ Replace Poulan 2150 chainsaw primer bulb
I have attached a video on chainsaw primer bulb replacement from YouTube. There are many great videos about chainsaws on YouTube.
I hope this helps.
http://www.youtube.com/watch?v=sNj2oO9L9ic
Jul 01, 2014 | Poulan 2150 Chainsaws
Trying to replace the fuel line and the primer hose both were rotted off not sure what goes where on my poulan pro ppb200 31cc string trimmer there are two lines into the tank the primer wont fill i have...
The smaller line is connected to the fuel filter in the tank and goes on the carb body opposite the end with the hole in the cover. A larger diameter line coming out of the tank is the fuel return line and has the little connector on it just inside the tank to hold it in place there
It goes on the carb body (if primer is on carb) by the bulb.
If there is an external bulb...the small line is the same...there would be a larger line going from the carb body (nearest the end with a hole in the cover) to the smaller nipple on the primer bulb. A third larger diameter line would be connected to the larger nipple on the primer bulb and running to the little nylon connector inside the tank. This is the fuel return line and the smaller diameter line is of course the fuel supply line.
Aug 07, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
I have a poulan 2150 chainsaw. I replaced the
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb refills).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My Poulan Pro weed trimmer SM132 does not run. I replaced the primer bulb and spark plug and it ran fine for 10 minutes. Now it will only start with the choke on and dies immediately. It will not start...
The primer does require two lines attached as it is a Walbro style primer. All four SM132 models uses the WT628 Carb. Since the trimmer ran 10 minutes then you have got all the lines connected right. Mostly you got trash in your carb or it simply needs rebuilding as the diaphragm may have pin hole in it or the check valves are worn out. Depending on the age and use of your unit you may also have a sticking piston ring.
Aug 23, 2009 | Poulan Garden
LOOKING FOR INFORMATION ON FUEL LINE ROUTING CONNECTIONS. FROM FILTER TO PRIMER BULB, TO CARB CONNECTIONS AND THEN TO RETURN BACK TO FUEL TANK.
most trimmer fuel lines run from line in tank with pick up filter to bottom of carby then out of top of carby to inlet on primer usually the smaller tube then out of the longer tube on the primer and back to the tank.
Jul 21, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Carburetor overflowing
Gas line from primer bulb to carb may be cracked or broken. Check gas lines for damage. If not that then there maybe an overflow problem in side the carb caused by the float shut off not seating correct or worn "o" ring etc.
May 16, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
116 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
