Question about HP Pavilion a305w (DM181AR) PC Desktop
How to install a stick of ram? - HP Pavilion a305w (DM181AR) PC Desktop
  • 4,102 Answers
Hi you need to make sure you have got the right ram stick goto www.crucial.com and scan your computer and it will tell you exactly the type and the maximum your computer can hold once you have done this and you have the right ram stick then do the following.<br>with it off and unplugged take the case off the computer then touch a radiator to earth your body to remove any static from you then have a look for the ram sticks in your pc you may have only two slots or 4 if you have 2 and both have sticks in you need to take them out and put the new one in and the next biggest one if it has four slots and only 2 have ram in then you can fit your new ram strait in, then put the case back on and switch your computer on and it will install them for you and you should then have a faster computer.<br><br>its best you buy the ram first so you know what your looking for inside your pc<br><br>let me know if you have any problems or need further assistance ok<br><br>plz rate this solution as i have a full page of unrated posts, thanks<br><br>
Posted on Aug 25, 2010
  • 109 Answers
Can I install more than 512mb of memory on a Presario s5300nx. I actually want to do 2gb or more. If so, how can i safely do it w/o messing up my computer. Thank you.
> I want to do 2GB or more.
As the Rolling Stones sang, "you can't always get what you want".
See: http://www.memorystock.com/ram/CompaqPresarios5300nxRAM.html
which states that your motherboard has 2 RAM slots, with a maximum of 512MB per slot.
So, how many RAM slots currently are empty, and how much RAM is installed?
If you currently have 2 sticks, at 256MB/stick, you will need to remove both sticks, and install two new sticks.
If you currently have 512MB of RAM, and one empty slot, then that web-page describes the exact type of RAM that you can insert into that empty slot.
Jun 26, 2011 | Computers & Internet
Running a 1 gig stick and a 512mb stick, system only shows 896mb, apparently not recognizing all of the ram installed?
I assume that you've booted the computer with _ONLY_ the 512MB stick installed, and that the computer recognized it (reporting either 512MB or 384MB), i.e., the 512MB RAM is not "defective".
Hmm. 1024 minus 896 is 128.
So, the "integrated-into-the-motherboard" video-card is "stealing" 128MB of your RAM, to be used strictly for "video" purposes, leaving 896MB for Windows to use.
Now, about the "missing" 512MB of RAM.
1. If you have four slots for RAM, and they are physically arranged into two pairs of two slots, rather than four equally-spaced slots, your motherboard is capable of "dual-channel" mode. But, since your two sticks of RAM are not "matched" (size, speed), you _MUST_ insert both sticks into _ADJACENT_ slots (not slots 1/3, nor slots 2/4), in order to run your RAM in "single-channel" mode.
2. If you have two slots for RAM, interchange the two sticks, to see if that makes a difference.
Aug 19, 2010 | eMachines W3507 PC Desktop
Hi Dear ; When I install memory RAM of 1.0GB .. get ERROR
Cant find your motherboard on the support page, is the memory your trying to install the same speed?
Jul 16, 2010 | Intel Computers & Internet
Trying to upgrade RAM on GA-945gzm-s2 mobo. Already have 1gb 5300 ddr2 stick of RAM. Works fine until I place the 2nd stick of RAM in. I turn it on and get no post beeps, no video, but everything is...
The new RAM module could be faulty or the second memory slot is faulty.
Try removing the original 1Gb memory module and inserting the new memory module in its place to see if the computer boots up normally. If it doesn't then then new memory module is faulty.
Oct 24, 2009 | Gigabyte GA-945GZM-S2 Motherboard
I want to use both RAM sticks
You may not be able to. the sticks usually have to be added in matching pairs. some older machines may read them mismatched
Aug 19, 2009 | Microsoft Windows XP Professional SP2 Full...
I have a compaq pressario 2200 notebook when i try to restart it after instaling things it wont start up all i get is a single beep and a black screen i cant hear the fan kick in and pushing the restet...
One of your RAM sticks might be bad.
Hopefully you have two RAM sticks. They are located behind one of the doors under your laptop.
Try removing one of the RAM sticks & fire the PC up with just one RAM stick installed.
If it still doesn't work, try removing the second RAM stick & replace it with the RAM stick you originally removed. Then try firing it up again.
If that works, try re-installing both sticks again. The contacts may have just been dirty & needed the RAM to be re-seated.
Mar 15, 2009 | HP Compaq Presario 2200 Notebook
Ram and Bios issue
Make sure your other stick of Ram is installed properly, once that is done make sure that the stick of ram is compatible with that computer. After that even, check to see if your computer is capable of processing that amount of RAM.
Feb 04, 2009 | Acer Aspire™ T180 PC Desktop
Error message after installing memory ram upgrade.....
The memory appears to be the right kind.
Try installing just one 1GB module, and run the diagnostics (press F12 at boot time and select diagnostics).
Dec 20, 2008 | Dell Inspiron E1505 Notebook
Installing ram
It will support up to 4 gbs of ram but they both have to be low density, the unit can not go more then 2gb with high density ram.
Feb 13, 2008 | Acer Aspire 5500 5570-2609 Laptop
Problems with Ram
Hi, with my own Foxconn board I had simalar problems, the Foxconn website gave me the needed steps to rest the bios to cope with 4g RAM. I have forgotten the steps now. The web page is the one on the install disk, if you go to Foxconn via google you will only get a company promo. Regards mistyman
Sep 10, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
HP Pavilion a305w (DM181AR) PC Desktop Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
