Question about Tecumseh Enduro Vertical Engine 16 HP 1in x 3 532in Shaft Model OHV16204230F
Engine will not start. plug firing to soon - Tecumseh Enduro Vertical Engine 16 HP 1in x 3 532in Shaft Model OHV16204230F
  • 44 Answers
Check the keyway on the flywheel
Posted on Sep 09, 2010
I have a 97 Dodge Ram 1500 with a 5/9 in it I put plug wires on it and now it's popping and it lost power and it had a code po302 and Po 307
The P0302 code means that the cylinder 2 is misfiring or is randomly misfiring. Start by checking for intake leaks and if no leaks are found the next step is to replace the spark plugs on cylinder 2. If the problem persist more tests needs to be done. PO307 is the same thing except number 7 cylinder. Possible symptoms - Engine Light ON (or Service Engine Soon Warning Light)
- Lack/loss of power
- Hard start
- Engine hesitation
Nov 29, 2015 | Dodge Cars & Trucks
Turns over will not start
Depending upon your level of expertise I would say pull a spark plug and look for a spark.
Any gas combustion engine requires a fuel mixture and spark to "fire" If you know your spark plugs are firing, then the problem is most likely going to be fuel flow.
If it doesn't fire AT ALL. and you are sure you have a good spark, then its probably going to be a computer controlled fuel flow issue.
Are you getting any "service engine soon" lights? Got a really good charge on the battery? Is the engine cold like below freezing? And I gotta ask.... are your sure there is enough gas in the tank? If its low and sitting on a hill its possible its not getting any gas.
Dec 08, 2014 | 1999 Buick Regal
Triton 5 4 v8 engine diagram
Have you checked the plugs and the rest of the ignition system ?
What are the trouble codes stored in the computer ?
May 30, 2013 | Cars & Trucks
Engine wont start
-Check spark plug. It could be too wet of gasoline it you crank so many times and not fire.
-Try this: Hole the gas pedal all the way down then start. Make sure as soon as it fire release the gas pedal immediately.
Mai Lor
Apr 08, 2013 | 1999 Dodge Durango
IT STARTS, BUT IT WONT STAY ON, AS SOON AS IT START, IT SHUTS RIGHT OFF. PLEASE HELP.
Fuel filter could be so stopped its not letting but a small amount of fuel pass just enough at a time to start the engine but not enough to keep it running;Fuel Pumpcould be going out ;Check to see if the engine is getting fire by putting a spark plug in the number 1 spark plug wire and grounding it off while some tries cranking after it goes dead you have to elimanate weather you have fuel or firing problems could be Contol Moduale Problems; Check fuel pressure(Filter& Pump)if not that Check Firing Problems Control moduale make sure it has Diaelectic grease at contact elimanate problems & ask more Questions on FIXYA.com
Aug 28, 2011 | 1994 Cadillac DeVille
I changed spark plugs and wires and now the Service Engine Soon light comes on?
The check engine/service engine soon light comes only when the computer control unit (called the PCM) senses a fault in the electronic controls of the engine and/or the emission system, there are about 200 possible faults that turn the light on, to know what has developed a problem you must have the system tested, this is called an OBD2 fault code test, Kragen and Autozone parts stores do this testing for free.
May 21, 2010 | 2004 Pontiac Grand Am
Will not start
Won't start.... Do you have spark at the plugs, good fuel psi? Does it try to fire or just turn over and nothing else?
Jul 04, 2009 | 2000 Chevrolet S-10
1988 Chevy Van No Spark
Have you put a spark plug fire tester on the plug wire and verified there is no fire at the plugs or do you just figure because it is getting gas if must be an issue with the fire. I ask this because the age of the truck it may have a plugged converter or muffler on the truck and if one of them are plugged it won't allow the engine to pull the fuel into the cylinders and fire. You can remove the 02 sensor ahead of the cat and the truck will start if one of them is plugged up. The truck will not run well but it will start and run ruff. Hope this helps.
Apr 10, 2017 | 1988 Chevrolet G30
Will not start but attemp to turn over. check fire, gas and change plugs.
check the electronic control module and the crankshaft positiong sensor...both will keep the car from starting
Aug 17, 2008 | 2000 Mitsubishi Galant
2001 oldsmobile alero
I have a car in the shop right now same thing - it is being caused by a misfire. Need a real technition to diagnose the problem (auto zone - advance auto can't diagnose the problem - only read the code)
mine was caused by a failing fuel injector. good luck
Jun 26, 2008 | 2001 Oldsmobile Alero
Tecumseh Enduro Vertical Engine  16 HP 1in x 3 532in Shaft Model OHV16204230F Logo
172 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
