Question about Hoover Dryers
I have a Hoover dryer i think the model no is 35250 it is about 5-6 years old.When i turn the timer around to set the dryer wont work and there is an electrical noise
catriver
  • 878 Answers
SOURCE: Maytag Atlantis Electric Dryer
Fly, sounds like you blew the thermal fuse. This is located on the front blower. You will need to remove door by removing the two screws and lifting up on the hinge. Remove the 2 spacers on the other side of the door. Now the panel will pull out and the blower will be exposed. The fuse will look like the one on the right of the attached picture....Catriver..post back.
Posted on Jan 27, 2007
frankgant
  • 250 Answers
SOURCE: Maytag Neptune dryer timer won't stop
If the timer is not stopping as it goes around then it's for sure the timer. The timer does pretty much all the work with controlling the dryer. And if it's physically not stopping going around then it has broken.
Posted on Jul 08, 2008
TheMobilian
  • 8220 Answers
SOURCE: older amana electric dryer model #le8457w, wont heat up
You probably have a bad heating element. This is just about the easiest dryer to repair ever. Take the screws off the base and pull the front off. The heater is on the left on bottom and has all the fuses mounted on it. 2 screws hold the whole thing on. get it out and give it a look over for a bad coil. Not sure if it is bad? Take it to the appliance parts store and let them guys confirm if it has a problem. they will be glad to do so because they hate to have to give refunds on electrical stuff and they know the cust will get bent outta shape. Trust me. How do I know? Because my friend I used to own and operate an appliance parts store.
Posted on Apr 10, 2009
heatman101
  • 43501 Answers
SOURCE: fisher-paykel electric dryer less that
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
wywter
Posted on Sep 29, 2010
heatman101
  • 43501 Answers
SOURCE: Maytag SDE4606AYW electric dryer won't start.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
dghj53
GE Front load Gas Dryer Model GTDP490GDOWS won't turn on
Remove the timer nob see if it is cracked, replace it with another nob or use pliers to turn the timer see if that works
Aug 26, 2014 | Dryers
Whirlpool dryer model LER7646E02 will not turn off
When they wont shut off it is almost always the timer Sorry.
Feb 09, 2013 | Whirlpool Dryers
Dryer not turning on.........before I would change the timer setting and it would would work.......after a couple of weeks, when i change the timer setting it wouldn't turn on at all. Question is
Definitely sounds like a timer problem. Sears Parts Direct should have your part. The model # you supplied is incomplete to determine if you have a gas or electric dryer. Check the model # again and go to Sears page to find the correct part.
May 08, 2012 | General Electric DBXR463EG Dryer
Our Hoover (3535d) dryer tumbler does not want to spin although you can hear the motor starting. The load does not appear to matter. There is no sign of belt slipping. Can the problem be due to the start...
If you hear the motor starting then it normally wouldn't be the start capacitor. It is when it doesn't start that you suspect the capacitor.
If your motor is turning and belt is NOT slipping then your drum should be turning! Those things do tell you that your electronic (control board and timer) are good, but you are wrong about either the motor or the belt!
Jul 03, 2011 | Hoover Dryers
I have a 5 year old Whirlpool Electric Dryer, Model #LER7648KT2. The Dryer won't start. I have checked the door switch, start button switch and visible thermo switches or thermostats with an ohm meter...
There are usually 2 thermal fuses in dryer circuits. One is on the heater housing and will blow in an overtemp condition around 310-350F.
The other is on the blower or exhaust housing and will blow around 200F
Make absolutely sure the 2nd one is continuous and not intermittently functional. This will definitely stop the motor from functioning
Below is a diagram for an older model (LER4634). Your dryer has some additional terminals probably because it has additional drying cycle options.
The diagram may be more readable when copied and pasted into a plain text editor such as Notepad or another editor with non-proportional fonts
Switch Terminals
|TM |TM |BK |BK |BK |
|WB |OR |BU |BU |R |
|-- |-- |V |-- |-- |
|O |X |O |X |X |Auto - High Heat
|O |X |X |X |X |Auto - Low Heat
|<> |<> |~ |X |O |Cool Down / Fluff
|O |X |O |O |O |End of Cycle
|X |O |O |X |X |Timed - High Heat
|X |O |X |X |X |Timed - Low Heat
Legend:
O = Open (Infinite Resistance)
X = Closed (Continuous)
<> = Either (But not Both)
~ = Doesn't Matter
NA = Not Applicable
Switch Terminals:
TM - Timer Motor (Different Models may use different colors)
WB - Black/White
OR - Orange
BK - Black
BU - Blue
V - Violet/Purple
R - Red
Example: For the Auto - High Heat Dry cycle, the following terminals are continuous:
Terminals
<TM - OR>
<BK - BU>
<BK - R>
(of course since BK-BU is continuous and BK-R is continuous, then BU-R is also continuous.
This should allow you to test at least some of the cycles your timer switch has
I have a general schematic in PDF for whirlpool for gas and electric, but did not see an option to add an attachment to this message.
Hope this helps or point you in the right direction.
Apr 21, 2009 | Dryers
Kenmore dryer timer never shuts off.
REPL/ YOU BROKEN LID SWITCH ,, IS ON OPEN POSITION REASON FOR NO T SHUTTING DOWN////
Nov 28, 2008 | Kenmore 27032
We have a new hoover bagless that is a couple months old. The pet hair attachment stopped working. I disassembled it found lots of hair wound around the various rollers and removed - painstakingly thorough...
Without the model number, I can't look it up, but this has a 1 years warranty on it, maybe take it to a warranty shop. Just take proof of purchase, model and serial numbers.
Mar 08, 2008 | Vacuums
Maytag dryer PYE3300AYW Continuously runs
jefo, it sounds to me like your timer is not advancing. Does it move at all or stay in place? In what you are saying it will stop when you turn it to off, I would think it could be the timer that is the problem. Part # 53-1810.
May 19, 2006 | Maytag PYE2300AY Electric Dryer
Dryers Logo
27 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
