How to replace color wheel part BP96-00674A for Samsung 61" HLP6163W model
Do have a "how to" step by step guidance program or directions for me to replace the color wheel without breaking anything or incurring more costs. I have the color wheel part, but a bit nervous in regard to replacing w/out some kind of direction(s).
Thanks for your help, PjS
Also: I'm replacing the lamp and would like to know what kind of gloves to use as not to damage the bulb...
Here is step by step process to do the color wheel. Its really quite simple.
http://www.youtube.com/watch?v=Cx4pbNjsxfU >> Replacing the color wheel in a Samsung DLP Television
http://www.youtube.com/watch?v=4fGgpR-DEXY&feature=channel_page >> Replacing the color wheel in a Samsung DLP Television Part 2
The bulb is even easier. Also you do no need gloves if you don't touch the glass bulb. So just use a towel and be very careful while putting your new bulb into the old housing.
Posted on Mar 11, 2009
I have a benq projector which has a very noisy color wheel can I stop it or how do I replace it
Jan 12, 2014 | Samsung HLP6163W 61" Rear Projection...
Replace color wheel on samsung HLP6163W
that needs experience of electricals first
Jun 10, 2008 | Samsung DLP HL-P5663W 56" TV
I have no jumper on my samsung dlp to change colors back after changing the color wheel.
hi,,
after the color wheel replacement you need to get the restore sequence procedure using button combination of your remote..
try to to this link www.fixya.com/users/chester_pendilton0
and get any of my services..
thanks
Feb 03, 2012 | Samsung HLP6163W 61" Rear Projection...
My Samsung HLP6163W started making a loud buzzing sound and the picture is distorted. I've read around and have come up with two possible solutions: replacing the lamp or replacing the color wheel. ...
100% this tv problems it is the tv colors wheel it is defective require replacing.The loud tv buzzing noises sounds are the sounds came from the tv wharp colors wheel it is spinning out control wildly and off of it motor axis and by hitting it to the wall of it steel box holding it.The tv distorted colors pictures are came from out of the reflections of a badly worn out of the tv colors wheel.
Jul 08, 2011 | Samsung HLP6163W 61" Rear Projection...
I changed the color wheel in my HLP6163w. Now the color is off. I looked at the delay index and tried to adjust it but it won't work. The colors are just not right. How do I get the colors right?
Check if instructions with color wheel show a jumper on DMD board for an upgraded bearing-type of color wheel. Jumper hole would be on rear-facing shield of DMD board. (Standard 2-pin jumper used on computer boards.) Probably would have to remove jumper; not insert it.
May 02, 2010 | Samsung HLP6163W 61" Rear Projection...
MY SAMSUNG DLP MN HLP6163W PICUTURE HAS FADED
If you have had this unit for awhile it could just be the lamp. If the image does'nt brighten up you may have an issue with the light path. The color wheel produces the color. If there was an issue with the color wheel you would most likely have a black and white image.
Jan 24, 2010 | Samsung HLP6163W 61" Rear Projection...
My samsung dlp 61inch dont have any power on it.Is there an automatic shut off switch in the back panel? This had happen after I replaced my colorwheel.I dont have a manual for this tv.
did you replace the color wheel yourself? if so, it's a good possibility that something came unplugged or wasn't plugged back in correctly. retrace your steps.
Jul 31, 2009 | Samsung HLP6163W 61" Rear Projection...
Samsung dlp 6163w color wheel
Ours was on the color wheel. I also went to samsungparts.com and entered my tv model number and we could veiw the color wheel. However, the one we needed is back orders . I hope your is not.
Mar 02, 2009 | Samsung HL-P6163W 61" TV
People on tv are blue
you will need to index the color wheel in order for it to have the correct tints
Sep 26, 2008 | Samsung HLP6163W 61" Rear Projection...
Televison & Video Logo
3,195 people viewed this question
Top Televison & Video Experts
