Question about Epson Stylus C88 InkJet Photo Printer
One cartridge is not producing anything. Cartridge is filled
  • bwoesten Aug 25, 2010
    One cartidge is not producing anything at all while being full. Multiple cleaning did not help
  • 857 Answers
Follow these steps:
Step 1
Remove clip/tapeclip from ink cartridge.
Make sure you’ve removed all the tapes and protective plastic covers on the ink cartridge.
Step 2
Check ink cartridges are securely in place.
If the printer does not work after you have changed the cartridge, in all likelihood it means that the ink cartridge is not securely in place.
Step 3
Clean your inkjet printer cartridge heads.
Most printer software come with a set of tools for cleaning and aligning the ink cartridge and printer heads.
You may need to repeat this process several times if you haven’t used your printer for some time.
Step 4
Leave ink cartridge overnight.
If the cleaning routine doesn’t work, try leaving the cartridge in the printer (turned off) overnight.
The next day, run the cleaning process again. The dried ink will soften, making it easier for the printer to clean.
If you have tried all of these steps and the new ink cartridge is still not working you may have a faulty cartridge and will need to return it.
Posted on Aug 25, 2010
    Genius:
  • 1,478 Answers
Do you have another black cartridge? If so please install it and try again. Clean the cartridge's print head and contact points. Also clean the contact points on the printer, leave to dry. I would also suggest you to use a new cartridge to make sure if the problem is related to Cartridge. If the problem still persist, reset the printer.
Take care.
  • Jimoh Adeleke Muyideen Aug 25, 2010
    Replace the cartridge and see if the replacement will print.
Our Hp 5550 prints thin vertical black lines on high res images. They are evenly spaced (3cm apart on an A4 print).
This is caused by a damaged drum. The drum is the long metal cylinder inside the toner cartridge. You will have to replace the hold cartridge. You should be able to flip a plastic cover on the toner and see the drum. If it has black toner lines then it usually means the drum is scratched and there for toner fills the scratch and produces lines.
Replace the print cartridge (toner cartridge) and the lines should go away.
Jul 19, 2011 | HP LaserJet 5550 Printer
My canon mp470 prints blurry images. what to do?
Blurry images are produced due to poor functioning of the cartridges. This is mainly due to the fact that you either just re-filled the cartridges or you purchased poor cartridges. Buying new ones might be of help.
Secondly, ensure that you aligned the cartridge heads well. Go to your installed printer software to and perform a nozzle clean.
Dec 01, 2010 | Office Equipment & Supplies
HP 1510 PSC prints diagnostic page, alignment page fine. Will not print anything else. I have already tried reconfiguring and cleaning the heads. No success
It was a "refilled" cartridge and not a new cartridge. For some reason the refilled cartridge was empty after being filled recently. Not sure why or how. A new replacement cartridge fixed the problem.
Nov 16, 2009 | HP PSC 1510 All-In-One InkJet Printer
Error 1203
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
May 21, 2009 | Lexmark X4270 All-In-One InkJet Printer
Printing problem
The printer determines the amount of ink left in the cartridge by counting the number of ink "shots" when printing, head cleaning etc. This information is stored in the "chip" on the cartridge. Thus, it is not an actual measurement of the ink left, but an estimate calculated by subtracting the total shots from the original full ink quantity. This estimate can sometimes be grossly in error, usually due to a cartridge replacement not being carried out correctly, or a cartridge that wasn't, in fact, properly filled. In other words, your cartridge (or cartridges) may actually be empty, even though the Status Monitor says there is ink in it/them.
You do not say if this problem is one cartridge, or all four. If it is the latter, then something is clearly amiss, since it is unlikely all four would be erroneously reported as containing ink when actually empty.
However, the first step is to buy a new set of cartridges - you can get a set of compatible cartridges from E-Bay very cheaply. You can save the old ones - tape up the nozzles to keep them from drying out - you may be able to use them again when you know what is going on.
Make sure you go through a proper cartridge replacement process so that an ink charging cycle is carried out.
If the new cartridges produce no printing, try a couple of head cleans and nozzle checks. If this still produces no print, report back with a new comment on what you have done so far.
Apr 26, 2009 | Epson Stylus C63 InkJet Printer
Canon pixma ip1300 initialisation problem
I have a canon ip 1300 produces an error(both LED's are alternately blinking one blink for the green led and 5 blink from the orange led) then it will produce an error 5600.
Dec 03, 2008 | Office Equipment & Supplies
Black ink
filling up the ink cartridge of the printer will cause an issue that the printer will be damage.HP ink are very unique and designed to be able to attain the good quality of print..filling up inkcartridge will make the warranty of the printer to be VOID...
Aug 27, 2008 | HP OfficeJet 6210 All-In-One InkJet...
ARC ink cartridge = Mac color MISmatch?
change the cartridge with the correct color that is shown in the printer cartridge tank container, The inks in the Arc cartridge may be filled with the wrong color
May 15, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Epson Stylus C88 InkJet Photo Printer Logo
44 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
