Question about Fisher and Paykel GWL11 Top Load Washer
During the cycle the cold water will not shut off. Once it kicks on at the first it won't kick off. I have to manually turn off the cold water. Once I turn it off at the valve and turn it back on it will stay off until the rinse cycle, then the same thing again it won't shut off? Any ideas
  • 343 Answers
It sounds like you have a faulty inlet valve. Not an uncommon situation with F&P. Make sure the new valve is for the appropriate temperature, because F&P says they're different.
Not a big job.
Access the valves via the 2 screws at the rear of the facia. Unscrew the retaining plate via the 2 screws between the inlet valves at the rear of the machine.
I usually cut the top off the valve slot so that the valve can be lifted straight up. When the plastic retaining plate is replaced the valves are secure again.
Don't forget to swap over the seal from the old inlet valve.
Good luck....Nomess
Posted on Aug 26, 2010
Wont fill with water
Other than the possibility that a shut off valve on the water line feeding the dishwasher was turned off for any reason, I had a similar problem on a different model and it turned out to be an electric valve that is under the dishwasher front kick panel that needed to be replaced. If it doesn't open no water can flow into the dishwasher during the fill cycle, 4c3igb
Sep 19, 2015 | Dishwashers
Tip
Dishwasher Water Temperatures
No matter what detergent you use, the "pills", powder, or gels, they are meant to activate PROPERLY, key word PROPERLY, at a minimum of 120 degrees Fahrenheit in a dishwasher. I recommend ALWAYS using the "high temp wash, boost, etc" on ANY cycle in order to keep the water HOT! Always run the hot water in the sink prior to starting the dishwasher! The unit is tied in to the hot water line under the kitchen sink and requires very little water to fill--by the time the hot water finally reaches the dishwasher, chances are it'll be running on cold or tepid water--the detergent won't dissolve or activate the way it's supposed to. Not only that, in between fills during the cycle, especially in winter, the water will cool down in the pipes too much. Normally, the water heating selection will maintain water temps in the 130-150 degree range! If someone has been sick in the house, turn on the SANI RINSE if your unit has it! This won't stop--but it'll help prevent cross contamination--people getting sick from the dishes--this setting normally kicks the water temp up to 190 degrees during the rinse cycle.
on Sep 08, 2015 | Dishwashers
1st stage of heat blows cold air
What is the model numbers of your units?
Oct 05, 2017 | Heating & Cooling
2004 ford expolorer air conditioning will not stay on
I would suspect the AC compressor cycling switch (located in low pressure line from compressor) or a AC cutoff wide open throttle relay ( in under hood fuse and relay center) would be causing this problem.
Jul 24, 2012 | 2004 Ford Explorer
Spa kicks off in a cycle. needs to be reset
Dean,
Thank you for asking me to help you with your problem. However, this is either not within my level of expertise or the question is unclear or there is not enough information and I cannot help you at ths time.
Nov 25, 2011 | Jacuzzi Pool & Spa
After wash cycle, tube will not drain water?
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months.
Jun 23, 2011 | Whirlpool Washing Machines
Kick stand safety shut down, once bike warms up it shuts off if kick stand is down
The bike is supposed to shut down if the kick stand is down. It is a safety feature designed to prevent starting out with the stand down, which can be very inconvenient on your first left turn. If you are saying the bike runs with the stand down when cold, then the switch must be in need of adjustment. Please rate my answer.
Feb 21, 2010 | 2001 Suzuki VL 800 Volusia
Water is not entering machine when turned on
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Aug 13, 2009 | Asko D1716 Built-in Dishwasher
Cold water continues to run during entire wash cycle
Adrea, sounds like you need a new valve. When it's doing this leaking, unplug the washer. If it's still leaking you know for sure it's the valve. Part number for the model posted is 22002360. Catriver..post back.
Sep 30, 2006 | Maytag LAT3600A Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
18 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
