Question about Amcor PLM-16000EH Portable Air Conditioner
Hello i have a amcor plm 16000e and i pluged it in a 240 hardwire line with a 125 plug, not really knowing much. but something inside popped and it shut down instantly. i took it apart to look inside, and found a 2amp fuse that was blown, well i replaced it and every time i plug it in now it jus pops it right away again. is there anyone or anything i can do? i have no manual either please help if u can plz and thank u
Where do I find a manual for PLM 13000 E?
I cant fined one so I would get In touch with Amcor
Jul 03, 2014 | Amcor Heating & Cooling
I need a replacement part for my amcor portable air conditioner model plm14000 The part which goes on the window that holds the hoose
Depending on where you live, you can contact Amcor.
In the USA 1 201 460 8100
In the UK +44 20 8560 4141
In Israel +972 9951 5351
Jun 27, 2011 | Amcor PLM-14000E Portable Air Conditioner
The cooling is not coming.I also want to know how to set it
Hi, I did some checking on this unit for you. To give you some direction to follow to what you are asking, call toll free Quality Matters Amcor.
866-725-9980
Not toll free 503-946-5869
Sincerely, Shastalaker7
A/C, & Heating Contractor
Feb 24, 2011 | Amcor PLM-14000E Portable Air Conditioner
I have an AMCOR 1400E and my compressor kicks on and gets very hot but no cold are comes out of the unit, I think i may have a bad compressor and don?t know who to call about the warranty since amcor is...
dear sir
if your aircon compressor is working and it,s not getting cold then it can be cause of leakage in aircon system then need to refill freon on your system .
please contact to your area amcor dealer for get the benefit of your warranty period(if it is in under warranty)
thank you
hope answer the question
Aug 30, 2010 | Amcor PLM-14000E Portable Air Conditioner
Amcor aircon 15000btu
Have you tried pushing the reset button on the power plug? If the unit overheats the reset button will click on and the a/c will turn off. In order to turn it back on you will have to push the reset button.
Jul 09, 2010 | Amcor PLM-14000E Portable Air Conditioner
Beeps and flashes when I plug in the unit but it will not turn on.
When the unit beeps and the display flashes that means that you need to drain the water. It will not turn on until you drain it. If you have drained the water and it is still doing that then I don't know what's wrong sorry.
Jun 14, 2010 | Amcor PLM-14000E Portable Air Conditioner
Amcor plm15keh
change thermostate switch.its means yr thermostate switch donot working.the heater running cotinusly,this is the reason for over heat.
Feb 24, 2008 | Amcor PLM-14000E Portable Air Conditioner
Amcor PLM-16000EH Portable Air Conditioner Logo
26 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
