Question about Maytag Neptune MAH5500B Front Load Washer
Washer door wont unlock. tired leaving off. cant open door
  • 4 Answers
Check the wax motor, if it's working, or there could be problem with the springs on the wax motor.
Posted on Aug 26, 2010
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
Door wont open
you cant,they are on a timer. make sure theres no water in the washer ( put it on a spin cycle ) drain all water out and try then. if that dosent work unplug the washer from the mains and leave it for a few moments then try then
May 08, 2015 | Washing Machines
Why wont my car boot wont open on my citren berlingo ?
Can you give a check to the micro switch that is connected to your boot lock?
If the catch gets stuck, open your drivers door, leave it open,reach across & press down the lock on the passenger front side. The locks will lock/ unlock themselves, because they sense a door is open. Repeat this action until you hear the boot unlock. Also, keep your battery well-charged.
Let us know if this helps!!
Jul 30, 2014 | 2005 Citroen Berlingo
Passenger sliding door and rear cargo door wont unlock but other doors will why?
window is an issue by itself.its most likely a bad window regulator or a motor or a switch.the sliding door and back door might be an issue with power door lock actuator.or broken handle
Jun 20, 2013 | 02-03 Caravan 2 Tire Pressure Sensor...
Whirlpool duet washer door will not unlock or complete the cycle
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
  • Oct 13, 2011 | Whirlpool Washing Machines
    The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
    Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
    More common issues with the door lock.
    Is water hooked up to the washer?
    The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
    Does water remain in the washer after the final spin?
    If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
    Is the door locked and the Add A Garment light on?
    If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
    Is the door locked and the Add A Garment light off?
    If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
    Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
    http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
    http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
    Jun 10, 2011 | Washing Machines
    The door is open on my ge front load washer but it says it is locked. Door wont close and I cant get anything to work. I tried shutting off the power for about 5 minutes and this did not help.
    You should be able to access the door lock from the bottom panel. Unplug the machine and open bottom panel reach up on the side of the lock. It should have a tab or pull hanging down that takes a little pull to unlock it. Do that and see if it'll unlock. If not you might just have to buy a new door latch/lock.
    Dec 28, 2010 | GE WSXH208A Front Load Washer
    I want to unlock my door
    Manually Unlocking the Door Lock System
    1. Unplug washer or disconnect power. 2. Remove the lower kick panel. 3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit. 4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab. 5. Gently pull the tab down about a ¼" or until a click is heard. 6. The door may be opened.
    Apr 12, 2010 | Kenmore HE2 Plus Front Load Washer
    Cnt get door unlocked on washer
    If water is in machine drop drain hose to floor level to drain off door should now open..good luck
    Sep 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Front load washer
    LO means bad door lock switch or conrtol board. to get it open unlock manually by pulling plastic cable located in dispenser where soap is put in.
    Oct 29, 2007 | Maytag Neptune MAH5500B Front Load Washer
    Maytag Neptune MAH5500B Front Load Washer Logo
    64 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
