Question about Maytag SkyBox MBV1976A Beverage Dispenser
Lights blink when drink button pushed. - Maytag SkyBox MBV1976A Beverage Dispenser
  • 3 Answers
Hello first check the flap sensor where the magnet in the flap is even.You will have to take the door off and apart the sensor is right behind the flapper door frame.Take 2 black screws out to get to the sensor.Moisture builds up on it and corrodes it.Clean it with alcohol,replace it and try it,this is just an easy trouble shoot it worked for me,though my chutes still dont go to the home position always but maybe yours is set right already.Good Lucklights blink when drink button pushed. - e4aadca.gif
Posted on Aug 29, 2010
  • MrMiami81
    MrMiami81 Aug 29, 2010
    The Flap sensor would be 21 on the chart
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
Car garrage door opener
smart or learn button is located on the back of the garage door opener. (the machine that is over your head) on most units such as liftmaster, craftsman, chamberlin. its on back or side by the light bulb and is green, yellow, orange/red, purple. genie units are black button behind light cover. or external on old units. push and hold your cars homelink button will blink slow, at the same time push and hold the remote for the garage door. led light in car will blink fast. let both go. now go to the garage door head unit, (overhead) and push the learn button. button will blink and you have 30 sec. to go to car and push the cars garage door button. head unit should flash its light, letting you know that it is programed succesfully. genie units push 3 times
Dec 10, 2013 | Building Materials
Drink-o-matic seems to run fine but doesn't get cold
Power supply is getting weak, and or the room is way too hot.
Nov 10, 2012 | Sharper Image Drink-O-Matic
Fisher Paykel DS605i single dishdrawer with a user-supplied integrate panel. There are three buttons on front. The left-hand button is power button; the center button is start/pause; and the right-hand...
Hello, Thank You for using FixYa. I will be helping you today.Are any of the cycle lights lighting up like rinse and normal and is the light on front blinking and pausing if so how many times is it blinking? Try turning the power off too the unit for five minutes and back on, because if the lid was open some or was stuck it can stop the unit from running.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jun 29, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Tassimo Coffee Maker: Tell me how to operate it. I can fill the water, put the pod in and all the lights keep flashing. Pressing the start/stop button does nothing.
• All lights will blink the first time you turn on your
machine. This is your cue to prepare your machine for use by
following the quick instructions in Step 1 on separate insert.
• If the water level runs low while you are preparing a
beverage, all lights will flash. Simply remove and refill the
water container, and brewing will continue automatically
where it left off. It should not be necessary to discard the T-DISC
and start over.
• The AUTO light will blink throughout the brewing process.
Some drinks require a pause in brewing as part of the recipe
for brewing your perfect cup - this is to allow the optimal flavors
to unfold and is a normal part of the brewing process. The AUTO
light will continue to blink throughout this process.
HOW TO MAKE A DRINK
• Place the mug of your choice on the cup stand.
• When the STANDBY light illuminates, insert the T-DISC® of your choice
and close the clamp.
• The HEATING light will blink as the brewer heats the water to the
optimal temperature for your drink.
• Once the proper temperature is reached, the AUTO light will
illuminate. When it lights up, press the start/stop button to begin
the brew cycle.
• The AUTO light will continue to flash throughout the brewing cycle.
PLEASE NOTE: Some beverages have a pause in brewing
after the initial influx of water into the T-DISC®.
• The MANUAL light will illuminate when your drink is ready.
Jan 14, 2011 | Braun Tassimo Espresso Machine/Coffee...
What does a blue light mean on my aerochino? thanks.
Means you are not heating your milk, the frothing milk will be cold (for iced drinks) because you have held the button down longer than normal. Usually it takes 5 Seconds for the blue light to go on. try turning it on or pushing the button faster, It should turn on red, for heated and frothed milk.
Nov 10, 2010 | Nespresso Aeroccino Automatic Milk Frother
Not making ice!
Try removing it and let the ice thaw. The mechanism for the rake to push out the ice can freeze up.
Apr 30, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
X box 360 controller
Awesome...You are THE MAN!!! WORKS GREAT
Jul 21, 2008 | Microsoft Xbox 360 Controller
Maytag SkyBox MBV1976A Beverage Dispenser Logo
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
