Question about Hotpoint HSS25GFP Side by Side Refrigerator
I have a Model Hss221FPA CC and it just doesnt seem to be cooling correctly....any suggestions?
New aircon but doesnt seem to be cooling
Hi Donna,
Check outdoor unit is running - the larger pipe/fitting of the two should be cool to touch after about 20 minutes, and the small one should be hot - if not either the system is short of refrigerant or the compressor is not running.
Check to make sure the settings are correct - snowflake for cooling - not for wintertime
Good luck
Dec 31, 2015 | Heating & Cooling
Hi there I have an LG Icebeam Door Cooling fridge that doesnt seem to be working correctly. The fridge is not that cold and the freezer is defrosting on the top section. The light is on and it seems
Find your model # and put it in the search box here: http://www.lg.com/us/support . Once your fridge is showing, there is great troubleshooting info available. Also, armed with the model #, we can actually give you pertinent advice!
Nov 24, 2014 | LG Refrigerators
New World G90m grill turns off - overheating?
Its a good chance its the thermal control board to the fan (PCB),if faulty it doesnt allow fan to reach correct speed thus overheating.
Hope this helps
Feb 05, 2012 | New World G90m Gas Double Oven
The system is on in cooling mode and I have it set for 16 degrees celsius. It does not drop to below 24 degrees. I have it set up correctly but just doesn't seem to want to get cool. Any...
If you're running the dehumidifier at the same time as the cool mode. That's the problem. The dehumidifier mode generates heat and the cool mode operates at half capacity, when both are run at the same time.
To obtain a copy of the Owners Manual for your model contact the Danby Consumer help line: 800-263-2629, as your model has been retired. They can email you and copy as an attachment.
Hope this helps you and thanks for choosing FixYa.
Jul 25, 2011 | Danby DPAC10031 Air Conditioner
Hello my car is using allot of water and my cooling fan doesnt seem to be working are these problems related
Yes they are likely related. The 1st thing you need done is to have a pressure test run of the cooling system to determine the cause of the coolant loss and to check the cooling system for rust and or a clogged radiator. If you have electric engine cooling fans they need to be tested as well to determine if they are functioning correctly. Any well equipped repair shop can run these tests for about 1 hour labor charge.
Jul 06, 2011 | Ford Escort Cars & Trucks
My webcam doesnt seem to be working.
This model does not have an integrated webcam, the sister model does. Here are the specs for your model!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02542735&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=4308201
May 26, 2011 | Compaq Presario CQ56-115DX Laptop
Hi there, I have a kh ford laser 93 model 1.6... when i drive the car it seems to overheat but there is water in the radiator and happens on hot days what do you think problem would be. thanks
I assume motor tune or other mechanical condition is not causing the problem.
When engine running, ensure no engine combustion gas bubbles in coolant resevoir (if so, the head gasket is blown).
I suggest you go through this checklist:-
Check radiator cooling fans are operating ok (as required when car warms up) - if not check
1) fuse,
2) relay operation,
3) heat sensor switch.
Check/replace the thermostat, Check for collapsing (soft) coolant hose on suction side of waterpump when engine revs above idle.
Check the coolant pressure cap is serviceable & of correct rating,
Ensure cooling system is correctly filled, bleed off any airlocks as necessary,
Check radiator cooling core is not blocked internally or externally.
Oct 09, 2009 | 2006 Ford Laser
Hotpoint HSS221FPA WW Side by side refrigerator runs continuously. coils are clean/replaced defrost heater. Even with refrig side turned off...keeps running
Howdy....Try changing the sensor to the themostat,or something is covering it so its not getting the cut off temp.
Jul 29, 2009 | Refrigerators
Hpdj1050c plotting problem
1. make sure you are using the correct print driver.
2.check that printing preferences are set correctly in said drivers.
3. if these suggestions don't work, then make sure your application settings are set correctly, and order the most recent firmware dimm you can find. this machine cannot be flashed and in order to upgrade the machine "BIOS", you must install a new firmware dimm onto the emod (electronics module). Good Luck!
Aug 25, 2008 | HP DesignJet 1050c plus InkJet Printer
Hotpoint HSS25GFP Side by Side Refrigerator Logo
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
