I have a Visco VSC-37V1 TV and it has sound but not Video. I found the c112 and c113 caps damaged and I replaced those but still same problem. is it related with somethig like plastic that was over the caps or it doesn't matter?. seems that it has to be cold weld, How I do that? Thanks
  • 74 Answers
CHECK YOUR INVETER PANEL ON THE BACK OF SCREEN AND CHECK THESE SURROUNDING CAPS AND IF THESE SUPPLY THE INVERTER POWER CABLE CAPS GONE MAY HAVE BLOWN SURFACE MOUNT FUSES ON INVETER PANEL
Posted on Aug 25, 2010
Samsung Monitor Backlight/Power Issue
hi, these mosfets are obsolete now, do you know a good equivalent for them?
Thanks
Aug 16, 2012 | Samsung SyncMaster 931B 19" LCD Monitor
My tv keeps flickin on and off. sometimes the remote works and sometimes it dont.what can i do?
Hello Malcolm,
That model is sold under several different names but the same model number. These units are well known to have issues with the power supply board and this can cause the exact symptoms you are having. The power supply board can easily be repaired, you just need to replace the defective capacitors on the board. Here is a link to a repair guide for the Visco TV that is the same as your Polaroid model. The repair guide shows what to look for and replace on the power supply board to repair it. I hope this helps.
http://www.ccl-la.com/blog/index.php/visco-vsc-37v1-no-picture-lets-repair-it/
BuddyMc
Jul 20, 2012 | Polaroid FLM-323B Television
My lcd element FLX-3711B dont turn on.. I plug the cord cable and only flashing front red light? Whats the problem?
The Element FLX-3711b TV is the same unit as several model of Polaroid and Visco TVs. They are all made by the same company just labeled fr different brands. The flashing power light is a very common problem and is caused by a failure of the power supply board. The capacitors on the board short out and this causes the board to not power up correctly. Here is a link to a repair guide for the Visco TV that is the same as the Element FLX-3711B so the information will be the same for both units. The repair guide shows the parts that will need to be replaced on the power supply board to rebuild it.
I hope this helps you out.
BuddyMc
Jul 10, 2012 | Televison & Video
My poloroid will power on but no picture
The Polaroid 3700 has a know issue with the power supply board. Here is a link to a repair guide showing how to remove and repair the power supply board and it should get you back watching TV in no time.
I hope it helps, if so please rate my solution.
BuddyMc
Feb 12, 2012 | Televison & Video
My poloroid 3700 flatscreen will turn on but no picture
known issue witht he power supply board in this model. Here is a link to a repair guide that should get you back going again.
I hope this helps, if so please rate our solution.
BuddyMc
Polaroid FLM323B,power board What is the voltage at these pins?
Check the caps on the power supply board, this is the most common problem with this model. Here is a link to a repair guide for a TV that uses the same power supply board
I hope this helps, if so please rate my solution
BuddyMc
Jan 24, 2012 | Polaroid FLM-323B Television
Screen isn't blue when you turn on its white
The most common cause of white screen and no picture problems on this unit is a failure of the power supply board. Here is a repair guide with full dis-assembly and repair instructions that should be able to get you back going again. This guide is for the Visco TVs but the boards are the same as the Polaroid model
I hope this helps, if so please rate my solution.
BuddyMc
Dec 25, 2011 | Polaroid FLM-323B Television
No power on tv after i shut uit down
This model is know for having power supply issues. We have a step by step repair guide posted on our web site at http://www.ccl-la.com/blog/index.php/visco-vsc-37v1-no-picture-lets-repair-it/ If you can solder then you can repair your TV, if you don't want to do the repair yourself we do offer a repair service. If you want us to do the repair on your TV you can send the whole unit or remove and send just the power supply board. You can setup a service request at: http://www.ccl-la.com/blog/index.php/service-request-form/
BuddyMc
Feb 06, 2011 | Polaroid FLM-3732 Television
Tv will not turn on. power light flashing red and blue. june@thecellulitesolution.us
This model uses the same power supply that is found in many of the Polaroid TVs. The board is model MLT070AX. The failure you are having is a common problem with this board. The repair is easy if you can solder. Check out this link to an article about how to do the repair.
BuddyMc
Jan 16, 2011 | Element Electronics FLX3711B 37 in. LCD TV
The power board burned out don't know where to get replacement board
Check this website to find the power supply for your LCD or you can replace the defective capacitors C120, C112, C113, C119, C118, C117, C115 and C114 if your LCD has the following symptoms:
No powering ON
Slow powering ON
Back lights ON, No video
Let me know if you require further assistance.
Sep 28, 2009 | Mintek DTV-323 32 in. LCD TV/DVD Combo
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
