Question about Pure Digital Pure FMDAB Radio
My pure siesta alarm clock ceased up when i turned it off yesterday morning & now has no display. I have unplugged it and turned it back on and only get the backlight, has anyone got any ideas?
    Problem Solver:
  • 16 Answers
The power supply is probably the problem, you should try a new one. It's 5V - if you're in the UK or Ireland you can get one here: http://www.digidave.co.uk/jshop/product.php?xProd=36231
Posted on Mar 10, 2011
Elextrolux french door fridge turns on and off and says power failure.
what is the model number?
Here is a little trick to try first. Get an alarm clock that has a LED display. Plug it into the same outlet as the refrigerator and leave it over night. In the morning, check to see if the clock is flashing. Post back the results.
Feb 06, 2013 | Electrolux Refrigerators
How do you tune a pure siesta mi
well as i live in spain and this fact coupled with the fact i have lived here for 26 yrs now make me an expert on this siesta lark ,now about 1.30 to 2. you rush home for dinner then you have a kip for a hour then back to work ,so how do you tune a pure siesta ,well it takes practice to get the timing right so you get back to work on time
Mar 09, 2012 | Cars & Trucks
I can't figure out how to set the alarm and make sure that it's set. The instructions with the clock radio are not clear. Also not sure how to turn off the alarm when it buzzes in the morning.....Help!!
Hello Barb,
To set the alarm hold either alarm 1 or alarm 2 buttons down. While holding down the button adjust the hour by pressing the tune+ button. The bottom left of the display there will be a light letting you know if it is pm or am. While still pressing the alarm press tun- to select the minutes. If you want to wake with radio or a buzz keepholding the alarm button down and press the am/fm/aux button. Release the alarm button when done. To select an alarm just press the alarm botton you want once, a light on the right side of the display will turn on. To unselect press the same alarm button once and the light will turn off. To turn the buzzer off in the morning select power/al off button located at the top left of the unit.
Jan 05, 2011 | GPX C389B Clock Radio
Pure DAB radio not coming on when turned on. Just showing setting clock on display?
On all PURE products you have the option of being able to return the product to its original factory settings. As well as being useful for fully re-tuning the radio, a reset effectively 're-boots' the product's operating system which removes any user settings such as presets and timer/alarm settings. A reset can often resolve any anomalies found.
tip.gif Note: You will need to re-enter your network security information after performing a factory reset. Make sure you have your network security key to hand before performing a reset or you will not be able to re-connect your radio to the internet.
Instructions for EVOKE Flow/AVANTI Flow/ Oasis Flow/ ONE Flow: Make sure your radio is switched on. Press and hold the 'Options' button down for two or three seconds and confirm the reset when prompted.
Instructions for Sensia: Make sure your radio is switched on. Tap 'Settings', tap 'Update' and tap 'Factory Reset'. Confirm the reset when prompted.
Instructions for Siesta Flow: Make sure your radio is switched on. Press and hold the 'Options' button down for three or four seconds and confirm by pressing the 'YES' button when prompted.
Dec 29, 2010 | Audio Players & Recorders
Design of back of clock
I know how you feel... it is hell to get old. Have you tried looking at second hand stores for the old original Big Ben? I changed over to electronic digital alarms with battery backup, but I'm with you... it is not the same. It is a good thing that time becomes less critical to us as we age... except having more of it. Perhaps you can go to Westclox website and click on CONTACT, and send them a message yourself. Better in your own words than mine. http://www.alarmclocksonline.com/BigBens.htm May God richly bless you.
Oct 24, 2009 | General Time Corporation Westclox Bell...
Dead
check the fuses in the plug and in on the board
Sep 14, 2009 | Emerson Smartset Clock Radio
Accidentally threw out instructions and can't turn off alarm in a
Just press ALM1 button for a second and it will be turned OFF. Do the same for ALM2.
Mar 27, 2009 | La Crosse Projection Alarm Clock with...
How do you set the wake up? So the radio turns on automatically? each morning
I did not find my manual, but this worked for me. Set the clock to be a 24 hour clock by pressing and holding the Memory/Clock Adj button. The display will show 24h or 12h. Use the fast forward button to change from 12h to 24h. Press the Memory/Clock Adj button again and use the fast or reverse forward buttons to change the time to read, for example, 13:00 instead of 1:00 if the time is 1pm. Press the Memory/Clock Adj button again to set the minutes.When you are done setting the time, press and hold the Timer/Sleep button. Either a time or "0:00" will appear in the display with the word "TIMER" flashing above it. Quickly press and hold the Memory/Clock Adj button until the first digit in the time starts flashing. Set the hour that you wish the alarm to sound using the fast or reverse forward buttons, just like you do for setting the time. Press the Memory/Clock Adj button again to set the minutes, and one more time to finish. The word "TIMER" will stop flashing and go solid, and the display will return to the time of day. When the alarm sounds, you can hit Snooze which will give you 5 more minutes, or you can turn the Clock Radio off. Pressing the Timer/Sleep button again will turn off the timer (alarm) and pressing and holding it again after that will turn it back on.
May 28, 2007 | Teac LT-1 Clock Radio
Pure Digital Pure FMDAB Radio Logo
1,254 people viewed this question
Top Pure Digital Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Pure Digital Audio Player and Recorder Expert? Answer questions, earn points and help others
