Question about Neff 22 in. T2124 Gas Cooktop
One of the rings keeps making the clicking noise as if trying to ignite itself after everything has been turned off. I have checked all parts are in correct place.
I have the same problem
Posted on Aug 25, 2010
Rings make a clicking noise all the time they are ignited
Turn knob back from "lighting mode" back to normal flame level. If this is not the answer, there may be a control or wiring problem.
The clicking is the normal ignition spark system but usually only operates at the time of turn on until flame is on.
Apr 27, 2015 | Cooktops
2 of 5 burners do not start
The spark gap needs to have flow of gas across it for ignition to occur. The gas outlet holes at the point where the igniter sparks may be blocked, clean and inspect these for any blockages. Also check that the igniter spike is in the correct place. Careful evaluation of the position of the igniter in reference to the gas ring on the other rings may help you here. Good luck
Feb 02, 2008 | DCS CT-365 Gas Cooktop
I saw an answer relating to a problem that has just developed on it's own on my Jenn Air Gas Cooktop regarding a clicking noise. My burner is trying to ignite all by itself and I'm in my bedroom. It's 10...
If you can disconnect the power to the cook-top then do so..this will give you a little peace of mind...it seems like the switch for that burner is defective(eg: stuck in on position)..the switch is an integral part of the control that turns on the gas for the burner..you may need to replace the control assembly..these are available from appliance parts stores and on-line
Jan 22, 2011 | Jenn-Air Cooktops
My stove is making strange clicking noises. please help.
It sounds like the ignition knob is stuck in the "ignitor" position. Try taking it off, clean it and adjust it. If that doesn't work, it will have to be replaced with a new one. If yu leave it alone, it will probably wear itself out. Just make sure that the gas valves on the stove are in the off position so that they don't accidentally light on their own. Good luck
Jul 13, 2010 | Cooktops
My ignition will not stop clicking
hi friend,
There are a few things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help.
it sounds like it is the spark module that's making the clicking noise. normally there are 4-6 wires that connect to it , and if you are not comfortable making the repair yourself then I would call an appliance repair company.The part should cost 30-50 $ Good luck
hope this helps u
please rate me.......................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Wolf Range 18 in. SPR-100 Gas Cooktop
Miele KM 320 G gas cooktop ignitor
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
Note: The 2-zone Wok Burner had a different control knob that the other burners.
To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
Disassembly
Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
Mar 04, 2009 | Miele 35 in. KM326G Gas Cooktop
Spark igniter doesn't arc
hi im gerbee fr.phil, much better to replace the part(igniter wire) coz that part cannot be repairable dont try to repair coz more dificult problem if u repair.to replace the part dismantle the unit or remove all the screw at the top of ur cooktop.before that unplug the unit fot ur safety.buy the part from the brand u carry.tnx i hope i help u
Nov 30, 2008 | Jenn-Air JGC8430 Gas Cooktop
Trouble with Kenmore Gas Cooktop
hi there,
the clicking noise is the spark module trying to ignite. i would get a technician to come and check it.
Sep 28, 2008 | Cooktops
DCS Range Ignition problem
I agree with two of the reviews here. Every so often after a good cleaning, or most recently after some oil spilled over, I had a burner that wouldn't light. All of them clicked, but the one I wanted didn't light. So after reading the above posts, I unscrew the hex nut, removed the shimmer ring, and cleaned it, and mopped up a bunch of oil under where the ring sits. Put everything back together and lit it manually. After 30 secs of flame I shut it down and tried to light it automatically. It worked! Looks like, thanks to some folks here, that I saved myself an annoying phone call and possible repair bill!
Aug 18, 2008 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Dacor gas range igniter clicking
I did have the same problem after the house keeping people done with cleaning. They used window/surface cleaner. First I asked them not to clean the ignitor with any cleaner. Here is what I did to solve the problem
I took scotch scour pad (one that you use for washing dishes), In dry state I polished ignitor switch. It is abrading the residuals and deposits on the top and polishing it. Don't use any thing more abrasive than that. MAGIC - I don't have any more problem.
Aug 14, 2007 | Dacor Preference SGM365SS Gas Cooktop
Neff 22 in. T2124 Gas Cooktop Logo
112 people viewed this question
Top Neff Cooktops Experts
Jim London
Jim London
Samyfam
Samyfam
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
