How can i get a user's manual for a siebe climate control thermostat, model PU1? Can't get the heating to come on.
2 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: I need a user manual
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large:
I have two here, one that is for a "Drayton Lifestyle LP522" which is this one:
http://micromatikal.dlinkddns.com:8000/cust/lp522.PDF
And one that is just a "climate control Lifestyle LP522", I would think it has to be one of these two, but please let me know if it isn't, here's the other one:
http://lp522guide.tripod.com/sitebuildercontent/sitebuilderfiles/lp522guide.pdf
Posted on Oct 14, 2010
Wiring instruction for a White Rodgers 1F78 non-programable thermostat.
The White-Rogers 1F78 thermostat is a single stage 5/2 day programmable thermostat. Home Depot has the manuals for one model of this thermostat, 1F78-151, on the product page: https://www.homedepot.com/p/White-Rodgers-Single-Stage-Digital-5-2-Day-Programmable-Thermostat-1F78-151/202771121 . The wiring diagrams are in the Installation manual. The direct link to this manual is https://www.homedepot.com/catalog/pdfimages/f9/f955280d-67a2-4502-bb94-4975cd857c0b.pdf . Emerson Climate also has the wiring diagram here: http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6615.pdf .
If you have a different White-Rodgers 1F78 thermostat, check for the manual at Emerson Climate by starting at http://climate.emerson.com/en-us/products/thermostats/thermostat-manuals . Click on the Enter Model Number button and start typing in the model in the search box. I found a number of models with 1F78 listed. After selecting a specific model, I found a link to the installation guide on the left side of the page, below the search box. (Note: the manual link was above the Suggested Replacement header for the models that I checked.)
I hope this helps.
Dec 15, 2017 | White Rodgers Home Security
Are there two thermostats for a 2012 Chrysler 200 with a 2 .4ltr engine and where are they located
There are two separate thermostats in your application, a primary and a secondary. The primary and secondary thermostats have different temperature profiles in terms of their opening temperature because they are located on different areas of the engine. The primary thermostat is located on the front of the water plenum in the thermostat housing/coolant inlet. The secondary thermostat is located in the cylinder head under the water plenum. The adapter that you are referring to does exist and I believe it is associated with the secondary thermostat.Here is a link to the first one. https://www.autozone.com/cooling-heating-and-climate-control/thermostat/duralast-thermostat/335455_381037_13514_93207 Here's the second thermostat. https://www.autozone.com/cooling-heating-and-climate-control/thermostat/duralast-thermostat/335477_381036_1620_93207
Nov 23, 2017 | Chrysler Cars & Trucks
Where can I find an instruction manual for a n american standard remote for a trane split heating and ac unit?
AccuLink Remote Control - American Standard
https://www.americanstandardair.com/.../acculink-remote-control.html
Find more information on the AccuLink Remote Thermostat available from ... terms for your AccuLinkTM Remote Thermostat, please refer to your owner's manual ...
Thermostat Controls - American Standard
https://www.americanstandardair.com/products/thermostat-controls.html
Discover thermostats and get a digital thermostat for your home with American Standard. ... 7-day programmable comfort; Remote monitoring and programming ...
Free American Standard Thermostat User Manuals ...
homeappliance.manualsonline.com/manuals/.../american_standard/ameri...
Products 1 - 34 of 34 - Find the user manual you need for your home appliance products and ... American Standard Central Thermostat Installation Instructions.
Free American Standard Air Conditioner User Manuals ...
Feb 03, 2016 | American Standard Heating & Cooling
I need an operating manual for a Siebe T45/British Gas PT5 central heating temperature control.
You have this posted in the car and truck problem category. Please re-post.
Jun 11, 2012 | Cars & Trucks
I am not getting warm air in my 1999 escalade
I would say either blend door issues or a vacuum control valve, heater control valve or a vacuum hose to the heater system is leaking. I would start to suggest. You are correct in checking the blend door. A computer scan should tell you what temp the climate control thinks it is in the passenger compartment. It may be a thermostat problem giving the climate control a false reading. Your blend door is controlled by a servo motor under the dash. You can remove the servo and watch to see if it moves when you change the temp setting from heat to cool. Also, you should be able to manually move the door to the heat position and see if you get heat.
Dec 17, 2010 | Cadillac Escalade Cars & Trucks
I have just replaced my thermostat housing bleed the radiator and i still got no heating the thermostat is brand new
MAKE SURE BLOWER MOTOR OPERATING IF NOT CHECK FUSE AND RELAY.ALSO CHECK HVAC FUSE THIS CONTROL HEATER + AC CONTROL SWITCH AND MODE SELECTION FOR OPENING AND CLOSING HEATER DOOR OR HEATER CONTROL VALVE AND AC+ DEFROST AIR DOOR.IF BLOWER AND HVAC FUSE OKAY.IF YOU HAVE MANUAL HEAT CONTROL MAKE SURE MODE SWITCH IS RECEIVING VACUUM. YOU HAVE TO REMOVE HEATER CONTROL SWITCH AND CHECK TO SEE IF GETTING VACUUM GETTING TO SWITCH LOOK FOR BROKE DISCONNECTED VACUUM LINES IN THE DASH AREA.IF YOU HAVE CLIMATE CONTROL.YOU COULD HAVE A FAULTY ELECTRICAL HEAT DOOR ACTUATOR.SOME CLIMATE CONTROL CARS HAS THE CLIMATE CONTROL PROGRAMMER HAS TO BE REPROGRAM BEFORE THE HEATER AND AC WILL WORK AGAIN.YOU NEED A DEALERSHIP SCANNER TO CHECK IT OUT.BUT IF YOU HAVE MANUAL CONTROL CHECK TO SEE IF YOU GETTING VACUUM.IF YOU GETTING VACUUM AT HEATER DOOR VACUUM ACTUATOR OR HEATER CONTROL VALVE EITHER ONE OF THOSE COMPONENTS COULD BE FAULTY.WARNING YOUR VECHICLE HAS AIRBAGS YOU HAVE TO DISARM THEM BY REMOVING FUSES WAIT 20 MINUTES BEFORE WORKING ON DASH AREA.YOU HAVE TO CRANK CAR UP TO CHECK TO SEE IF YOUR HVAC GETTING VACUUM.
Oct 24, 2010 | Renault Sport Cars & Trucks
I need a user manual for Siebe Climate Control LTD "lifestyle Miodel LP522 control
Oct 14, 2010 | Heating & Cooling
I have a Model FEF367CGSA Frigidaire range that had a power surge that burned out the oven control card ( Robertshaw 2999) and the instrument panel control card ( Siebe trimline 316101004). Where can I...
sears.com, repairclinic.com, or locally those numbers arent part numbers u will need to use your model number to detrmine parts u need hope this helps
Feb 02, 2010 | Electrolux Kitchen Ranges
A/C Heater problems
the main issue with this is either the thermostat or the climate control switch I do not know if your climate control switch is electronic or manual either way I would start out with the cheapest and go with the thermostat first good luck!
Nov 22, 2008 | 2004 Chevrolet Impala
Heating & Cooling Logo
227 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
