Question about NEC PT-390 /NITSUKO Phone
I want change the display name to my phone - NEC PT-390 /NITSUKO Phone
How do you change the display names on the Avaya 5420.
hi robert.
see if this helps you,if not go to the link and the bottom.
How to change the display name in Avaya phone? Press the Select soft key or the OK button or the right arrow key. Use the up and down arrow keys to scroll the display to the option Display Name. Press the Change soft key to change the setting or use the left or right arrow keys. Display your extension number and the date and time on the phone when it is idle.
Display Name - Avaya
marketingtools.avaya.com/knowledgebase/user/ipoffice/.../1408/display_name.htm Search for: How to change the display name in Avaya phone?
How do you change the display names on the Avaya 5420 Google Search
Nov 03, 2017 | Avaya Lands Phones
How do I change the display name on KX-T7630
http://service.us.panasonic.com/OPERMANPDF/KXT7630.PDF
May 13, 2014 | Panasonic KX-T7630 Corded Phone
Is there anyway to change the name that is
It's part of the phone system, it's software. Find out who controls the phone system and get your name on it.
Nov 25, 2009 | TalkSwitch TS-9133i
How do I change the settings. (Phone #, Buisness name?)
Press the function -dataregistration button select dataregistration press set or start. User settings will be displayed press set user name will be displayed and press set.Change user name.For phone number,if user name is displayed,scroll with arrows untill Tel number is displayed.
Oct 13, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
Name Display
The voicemail name and the phone system name come from two different places. Your system manager should be able to reprogram the phone system to change names.
Carl
Sep 08, 2009 | NorStar M7310 Corded Phone
How do I change the display name on incoming line
You would have to go into program mode.
program 93-1 would do the trick.
Tony
Ameritel
732.477.7733
Jul 09, 2009 | Toshiba DKT-2020 Corded Phone
Changing display name on phone
Login to system software and change it. If you have a big display phone with Admin Rights you can change it through that phone.
Dec 23, 2008 | Inter-Tel Axxess Phone 5504400
NORSTAR m7310
To Log Into System Programming:
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
Press: NEXT Display will read: "B. General Admin"
Press: SHOW Display will read: "1. Sys speed dial"
Press: NEXT Display will read: "2. Names"
Press the SHOW Display will read: "Set names"
Press: SHOW Display will read: "Show set:__"
Enter the extension number of which you wish to change the name Display will read: "<##:name>"
Press the CHANGE softkey
Using the dial pad spell out the name Ex: If you need the letter K press the 5 key twice and then press # to confirm the letter. Continue until the entire first name is spelled. (note: you are limited to 7 characters)
Press: NEXT (if you fail to do this step, the name will not be saved!!!)
Press the RLS key
Hope this helps!
Jun 17, 2008 | NorStar Meridian M7310 Phone
Changing the display
In your system support room - - you will have two computers set up for your phone system - maybe (at least that's how it's set up here).
One is for the voicemail system and one is for the phone display, essentially.
You will log in to that other station and when you get the command prompt type
change station xxx (where xxx is the extension of the phone display you wish to change).
Sep 13, 2007 | Avaya Definity 6408D Corded Phone
Lands Phones Logo
171 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
