Question about Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
Blades on razor are not moving - Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
  • 193 Answers
Disconnect the blade and ensure the drive Lever is moving if it is apply pressure to the lever and make sure it still moves.
There could be a problem with the Gear Wheel inside the gearbox, check for strpped teeth or even a loose post holding the gear and drive lever into place, relavent clipper repair parts can be found at www.angliaclipperservices.com .
Posted on Sep 18, 2010
Rotary razor
If it runs fine without the blades, it would certainly suggest that the blades are causing the problem. Replacements can be found at shaveroutlet.com at the links below
Norelco Philips HQ56 Super Lift and Cut Replacement Heads Generic Replacement Heads fit Norelco Philips HQ3 HQ4 HQ55 HQ56
Jan 28, 2016 | Health & Beauty
Dull razor blades after moisturizing stripe wears off
Expensive replaceable cartridges are only made to offer 4-6 "good" shaves for most people. Sorry - that's the deal. You can strop cartridges (in on direction only) on denim and pick up maybe a dozen more - search youtube for examples. I finally gave up on carts and moved to a straight razor; a razor or two will last for a lifetime with good care. There IS a learning curve for safe use and maintenance procedures. Find a straight razor forum if you want great shaves and good advice on what to buy, what not to buy and how to be safe.
Double edged safety razors are also a very good alternative for better, smoother shaves and WAY less expensive blades. Same advice - find a razor forum to save money, buy right and avoid nicks.
Apr 16, 2014 | Health & Beauty
How do i change the battery in panasonic es-rt51 electric shaver
Panasonic ES-RT51 battery problems?
If your razor battery runs down after only a few shaves e.g jumps from 60% to zero Let the razor completely discharge by leaving it switched on until the blades stop moving completely. (This can take over 24 hours so be patient) When they are stop moving recharge the battery and you will find the battery will charge and discharge just like new!
(This may take a couple of discharge cycles). Only charge the battery when it is flat after this and the problem SHOULD not reoccur.
Terence Saunders
Jan 01, 2014 | Electronics - Others
I have a Philips Norelco 7310XL razor and I have a problem. I recently moved, and in the process, something happened, and my razor isn't working. When I turn the razor on, the blades turn slightly and then...
It sounds like maybe one of the blades is damaged and it is jamming the whole thing. Try taking apart the head assembly and then insert each head one by one turning the shaver on in between each one. This should identify if one is damaged and causing the problem
If you require new heads, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
Sep 18, 2010 | Philips Norelco 7310XL Electric Shaver
Makes noise blades don't move
you have some teeth missing off of one of the gears, most likely the dual gear thats driven by the motor.
razors
Apr 23, 2010 | Fellowes 220C-2 Shredder
I have a Homedics PC200 which I have owned and used for at least 10 years. Is there a way to replace the head or sharpen the blade? It "bites" my boy's scalp when I use it.
go to a razor shop or electric appliance shop and ask for the replacement blades for your model. You can usually unscrew the blades with phillips screw driver. Be careful when replacing the blades to adjust them properly so the top blade doesn't extend over the underlying blade.The blade that moves should be retracted 1\16 of an inch
Oct 24, 2009 | Homedics PC-400 Pro Clipper
Oiling my razon
run a small amount of oil acrossed the blades. if they dry out, the blades will quit moving.
Jan 22, 2009 | Braun Cruzer 3 Electric Shaver
Wahl razor's not cutting, how do I fix it?
have you tried taking apart the blades and replacing them so that they line up together? Have you had a professional shear sharpener look at your blades? mabie all they need is to be sharpened again. Blades like knives or scissors need to be sharpened every once in a while. Also try replacing the blades with a new ones. The blades may have worn out. also try oiling the blades every once in a while.
Jun 24, 2008 | Wahl The Peanut Hair Trimmer
Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
55 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Chuck
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
