Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
My screen is very dim, my pictures turn out clear and light but i cant see anything on the screen, even stored pictures. I have to put my memory card into a different camera or upload my pictures to see them. I dropped it lightly when it was OFF shortly before this started happening.
  • 10,594 Answers
This problem is only related with back light in lcd screen and has nothing to do with ccd imager chip as explained by previous expert.
LCD screen is not getting enough voltage to lit back light to show its image thus you get darker image.
I suspect back light circuit section at main board got physical damage due to drop of camera. Visual check by qualified camera tech is needed to fix it.
Posted on Aug 25, 2010
  • Canon Master
  • 3,866 Answers
The could be the Backlight/CCD image going bad in the camera, if the output video is so dark you cannot see it or the screen is black you have a CCD image issue, Now if its just dim this is a back lighti ssue with the lcd. all after witch need to be repaired unfortunatly, You might also be in power save mode so check that out is well, also check the birghtness in the menu as well.
let me know
please do not forget to rate before you leave, Thanks
How do i use the samsung wb35f camera
If you did put in a memory card, like it says on page 18 of the manual, the picture should be stored there. You should be able to view the pictures on the card, or you could put the memory card in an external card reader connected to your computer. Before you connect a card reader or connect the camera to any computer, install the software belonging to the device, or you won't see a thing.
Dec 27, 2014 | Samsung WB35F Smart Digital Camera White
How to rapair my samsung corby bultooth i can transfer pictures but i gan't transfer mp3 files
If the phone memory is full u cant get files thru bluetooth, even u set bluetooth memory as memory card. so clear your phone memory and try it again. the files u r recieving thru bluetooth is temporarly stored in phone memory till the full file is recieved and after recieving it is automatically transfered to memory card if u set bluetooth memory as memory card. even i faced the same problem, now its working
Oct 11, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
How to delete all pictures from the internal memory of my fujifil
Remove the card, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory.
May 02, 2010 | Fuji Finepix Z20fd Digital Camera
Screen says internal memory full and wont do anything else
You need to copy picture files from internal memory to memory card and then delete those files OR put memory card in camera so it will store new picture files on it.
Aug 01, 2009 | Kodak EasyShare ZD710 Digital Camera
My MicroSD Memory card in my phone just stopped working...
put your memory card in the computer as if you were going to put the picutres on your computer and save them then clear your memory card and then take them from the computer adn put them on your memory card adn then save all pictures from memory card to phone and then clear memory card again and then place in computer defrag memory card and then put all pictures back on and then place in phone move all picutres to the memory card and then you will have two of each picture then delete them to where you only have one of each and then it is fixed
May 05, 2009 | LG VOYAGER VX10000 Cellular Phone
Getting pictures off internal memory
1....put your SD card in the slot...
2...turn cam on and go to playback menu
3....go to MENU/OK option
4...scroll down to COPY select ok
5....Then choose option INTERNAL memory to card and hit ok
Mar 23, 2009 | Fuji FinePix Z10fd Digital Camera
Memory full on LG Renoir but nothing on phone, Help ???
go into phone settings - memory manager - handset common memory and tap clear all. This worked for me i took my memory card out just to be on the safe side
Feb 24, 2009 | LG KC910 Renoir Cell Phone
Samsung s850 cant copy from camera to sd card?
The Samsung S850 has an internal feature to do this. I have one. Put in your memory card and turn on the camera, push the button on the bottom right hand side of the lcd screen to view the picture, next when you see a picture (it can be any picture) push the OK button, this brings up a set of commands across the top of the screen, as you go across the commands one of them will be "copy to card". Select yes and the camera will copy the pictures to the card.
Dec 09, 2008 | Samsung S850 Digital Camera
Problem eith bluetoth
Hello
You could try doing a master reset but you will lose all data / contacts /pictures/ on your phone
Steps to do a master reset
Settings/general/master reset/reset all/continue
Phone will restart
Darrin
Jan 04, 2008 | Sony Ericsson W550i Cellular Phone
No pictures when SD disk is out of camera
Before you do anything else find a friend who's camera takes the same memory card and try it in their camera. If it doesn't work there try cleaning the contacts gently with a pencil eraser (make sure you remove any rubber pieces left behind) There is a locking mechanism on the side of the SD card. Make sure this isn't locked. If everything still fails it looks like you could have a faulty SD card. Borrow one to try to see if the fault in the camera disappears. This camera has 32 MB of internal memory. Are you sure your pictures aren't being stored there. Read your manual and you can find out how to transfer them to the SD card once you've proved the card is working. Also check your SD card in a card reader and if there's still any problems pop it back into the camera and format it. BMW
May 30, 2006 | Kodak EasyShare DX7440 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
100 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
