Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Craftsman 358 350180 throttle cable routing - Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do i check problem with gas pedal to the floor chev impala 2002
has cable from pedal to throttle positioner on engine side of firewall
Dec 18, 2014 | 2002 Chevrolet Impala
Throttle on 92suzuki katana keeps reving when turn left how to fix
Your throttle cable is mis-adjusted or possibly routed wrong. Has it been replaced? If so, check the routing of the cable assembly. Most all cables have cable housings which mount by some type of clamping device on each end. It sounds as if one end of yours is loose. Best Wishes
Sep 02, 2014 | Motorcycles
Craftsman Riding Mower (24 HP 42 in cut Model 289254) with throttle issue. Very slow in 6th gear
follow the throttle cable all the way down to the engine. Have some one move the throttle up and down to see if the throttle plate is opening and closing all the way. You can loosen the screw holding the throttle cable and move it back and forth to see if it will allow the throttle plate to open and close correctly. It may have slipped when the assembler tried to tighten it.
Mar 10, 2012 | Craftsman Garden
SEARS 5.5 HORSE POWER BRIGGS&STRATTON ENGINENE NEED THROTTLE CABLE PART NO 9215R
please mention sears craftsman 5.5 HP model numbers.
is the part no. 9215R correct?
Jul 14, 2011 | Craftsman Throttle Cable Murray 319306...
How to install throttle cable for c77 motorcycle need routing of the cable
Keep the bends gentle. Go from the grip toward the tank down under the tank to the carb.
You may take the tank off and route cable beside frame. If the old cable is there well follow the same route. After you install cable insure that it works freely.
The other cable will lay beside the throttle cable.
Feb 04, 2011 | Honda CB 100 Motorcycles
Replacing throttle cable on craftsman weedwacker
how does throttle cable attach under the carberator?
Sep 20, 2010 | Craftsman Garden
Need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Aug 06, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cable broke
you should be able to use any cable of comparable length and type...(tip)take the old cable with you to your local small engine shop and dont buy any that are to short and if its a foot longer dont buy it either
unless you can rout it different you dont want any cablle you buy to have sharp bends or twist to much.other than that you should be good to go with any manufactures cable of simular type..go ahead and try it if the ends look the same..
Apr 11, 2009 | Garden
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
262 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
