Question about Kyocera CS-2050 Black and White Copier
I have a Kyocera CS-2050 and there is a dark line that prints in the center of the pages. What causes this and how do I correct it?
  • 29 Answers
Several things can cause this if it does this when copies are made on the doc feeder try making copies on the platen glass (the main glass). If the copies on the platen don't have the line its the **** glass the small line of glass left of the main platen glass. Clean with windex or alcohol. If it does it when any copies are made and doesn't do it when prints are sent from the computer Than the optics (mirrors) need to be cleaned. If it does it from prints from the computer than it might be the charge wire. To clean this open the front door and next to the waste toner bottle their is a slim green tab. Pull it out until it stops do this several time. If that doesn't fix it it might be the drum look for a line in the drum hold the page next to the drum to see if the line lines up with a deeper impression in the drum. Maybe the fuser unit do the same with the fuser (the unit that gets hot) and see if the teflon is worn off (will be a gray line were it has worn off.
If you have anymore questions just ask.
Hope this helps.
Posted on Aug 26, 2010
DARK PRINT IN KYOCERA KM 4050
my dear you clean mirror and grid wire clean
Jun 09, 2014 | Kyocera CS-2050 Black and White Copier
How to change your computer ip address so it matches the printer so it can print
go to printers devices ,right click on icon for 2050, click on printer properties, then click on portd , then click on configure port
enter correct ip address on bottom ip position.this should fix the problem
Dec 12, 2013 | Kyocera CS-2050 Black and White Copier
I have a print mode error on my Kyocera Mita CS-2050 KX How do I reset the copier?
what the error code ?
if c6xxx you need to rest by program 163 just tell me the error code and i'll help you
thanks
Aug 10, 2010 | Copystar CS-2050 All-In-One Printer
Kyocera cs 2050 copy has faded print down center
make sure the glass is clean it sounds like you either have a dirty scan glass or the wires need to be cleaned there should be a cleaner on the front cover of the macin that you you pull out and slide back abd fourth to clean it
May 05, 2009 | Kyocera CS-2050 Black and White Copier
Printing backwards mid-job?
the ram in your kyocera is going bad... there is also the possibility (if you have an internal hard drive) that your internal hard drive needs to be reformatted... consult a service tech in your area...
thehre is also the off chance that its a power problem... get a good power conditioner or surge protector and see if that helps before calling the tech...
Jan 23, 2009 | Kyocera CS-2050 Black and White Copier
Cannot setup/connect to Kyocera CS-2050
go to kyocera mita america online. they have all the drivers. you need the KX driver
Jan 21, 2009 | Kyocera CS-2050 Black and White Copier
Kyocera CS-2050 Black and White Copier Logo
164 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
