Question about Whirlpool Refrigerators
My frig is less than a year old. Anything that I put toward the back of the frig freezes. This is the same thing my old one did and why I replaced it. What's wrong?
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Water filter inside fresh food compartment keeps freezing up? Frigidaire brand 3-4 years old. Thanks, Steve.
hello,
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze
Check the cold control, and also the air deflector. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout....
Aug 08, 2010 | Frigidaire FRS6R5EMB Side by Side...
Frig freezes up after a few weeks -- the glass tube looks fine
THERE IS A DEFROST SENSO ON TOP OF THE EVAPORATOR MANY TIMES IT WILL LOOK SPLIT WHERE THE WIRES GO IN THE BACK IF SO REPLACE IT
Dec 19, 2009 | GE GSS22SGM Side by Side Refrigerator
The back of mt fridge is frozen. I've set the temperature between 4 - 5. If I put food near the back it freezes. What is the best thing to do?
Move items that are susceptible to freezing towards the front. The air circulates in from the back and anything set directly in the airstream will freeze.
Eric
Oct 14, 2009 | Freezers
My Panasonic DMC-FX30 is less than a year old and is failing. It won't take a picture, constantly requests to turn the off and back on, and now pretty much freezes up on the screen and won't react to any...
There could be a few things. One thing is for sure though. If it is less then a year old. Don't waste another second. Have it sent into the manufacturer to be repaired under warranty.
www.panasonic.com
Thanks,
Lee
Jul 11, 2009 | Panasonic Lumix DMC-FX30 Digital Camera
Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerator keep running
Way too much refrigerant in this fridge.
You have a bad thermostat.
Feb 24, 2009 | Fogel FOG-CR67PCUS Sliding Glass Door...
FRIGIDAIRE REFRIGERATOR PROBLEMS
Freezer stayed cold but upper compartment wouldn't. Freeze started having problems with staying cold. I just paid $377 to get the two year old evaporate fan replaced. It is located inside the frig behind the panel in the freezer compartment. It took about 15 minutes. Seems this part is part of the evaporator system but not covered by anything other than the first one year warranty. Problem solved but what a ripoff from Kitchenaid.
Jun 21, 2008 | Refrigerators
Ge water filter cracks
The issue is with length of the filter and the space behind the filter allowing it to bend.
Along with many people we put a lot of things in our frig. When you jam things into your frig they can hit the filter causing it to bend towards the back of the frig. The long filter becomes a lever putting extra force on the plastic threads on the filter causing them to crack and leak.
Luckly we noticed our leak early and did not have a big leak into the floor below. But when I was removing items from the frig to get to the filter we had just bought two big gallons of milk and one was jammed into the filter.
You can try to remember to not put to much on that side, but within a month you will for get. Best thing to do until GE comes up with a better filter is to tape a wedge to the filter that fills the space between the filter and the back of the frig. That way if you jam a big gallon milk into the filter it will not bend and crack.
Jan 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
MAYTAG MZD2766GE SIDE BY SIDE
Mine kept doing the same thing- the flap between the freezer & the frig is getting stuck. I finally just broke mine off & left it that way. Now the frig is really cold, sometimes things partially freeze- but that is better than going rotten. I now have a section under the water/ice dispense tray bubbling/peeling the white paint off. Mine is 6.5 years old & out of warranty, so I'm searching for a way to repair this problem. Any suggestions?
Jul 11, 2007 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
32 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
