Question about Xerox WorkCentre Pro 123/128 Printer
Xerox Workcentre Pro 123 has this error code 077-103. where is the fuser exit sensor? what is the usual problem with this code?.
2 Suggested Answers
  • 208 Answers
SOURCE: Unable to print envelopes on Xerox WorkCentre Pro 123
Some thoughts.
Envelopes won't print from bypass tray. Cause:
Extended tray is not set up properly for envelopes. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Enter tools "Login" 1,1,1,1,1 Touch buttons with the following names in that order: System Settings System Settings Common Settings Other Settings Scroll down to "Extended Tray" Next to "Extended Tray" it may say "Inverter" if it does go to change settings then change it to "Offset Stacking" Close out tools.
Posted on Nov 30, 2007
I have replaced everything on my 123 but it still jams
Is it jamming at the fuser? the most common problem is the fuser exit sensor that is located behind the fuser on the frame of the machine. Can you provide more details or an error code?
Oct 06, 2014 | Xerox WorkCentre Pro 123/128 Printer
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
Fault error occurred no. 123-333
I install xerox new machine when turn on gives error code 123-333
Jun 20, 2013 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Xerox WorkCentre Pro 123 linux driver ?
if you open your web browser, put in
www.xerox.co.uk, go to cusomer support then to suport and driver,
there put
  • WorkCentre M123/M128 and then your operating system. From there you should find the driver package for the linux system
Dec 06, 2017 | Xerox WorkCentre Pro 123/128 Printer
Problem connecting Win 7 64-bit to Xerox Workcentre M128 printer - Windows is giving a "no suitable driver found" error.
Try this link, it goes directly to the 64 bit driver download site.
http://www.support.xerox.com/support/workcentre-pro-123-128/downloads/enus.html
If that doesnt work. Go to www.xerox.com. Select support and drivers, in the search box, type 128, then go to the workcenterpro 123/128 and click on downloads and drivers.
You will find 32, 64 bit drivers for all OS.
Jan 27, 2011 | Xerox WorkCentre PRO 128 Copier
O47-212 error code how to clear?
This is an exit problem. A sensor didn't see the Exit OCT Motor 2 rotate and actuate the home sensor.
You may need a technician, or do parts swapping with these items: Exit Control Board 160K94211
OCT Home Sensor 930W00113
Offset Motor 127K37951
Best of luck
Whit
Item, Inc
Oct 05, 2010 | Xerox WorkCentre Pro 123 Copier
Error 116-364
Error 116-364 Problem with the Xerox WorkCentre Pro 123/128 Copier Finisher Staple Refills Copier. Dear i am also facing the same problem, It would be very helpful if you share the solution you may had come across. Thank you very much .
May 17, 2010 | Xerox WorkCentre Pro 123/128 Copier...
I have Xerox workcentre pro 128 copier machine. can you solve my problem? when i copy before appear this Error code 123-396.
That is a software related error, You most likely need to reload the firmware, or replace the hard drive.
You can try disconnecting all the document feed and scanner cables then reseating them. Other than that, your looking at a software issue.
Jan 28, 2009 | Xerox WorkCentre PRO 128 Copier
Xerox Workcentre Pro 123 error code 016-719
this is not a mechanical error but a software error.
It either doesn't recognise the format or program
as for the driver don't thinkit's the problem the HP can use PCL6
Sep 08, 2008 | Office Equipment & Supplies
Xerox WorkCentre Pro 123/128 Printer Logo
1,045 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
