Question about Friedrich QuietMaster RS10J10 Air Conditioner
Where is the vent on my Friedrich AC unit? I don't know how to close or open it.
  • 139 Answers
The fresh air vent open close tab should be located somewhere along the vent louvers look at the bottem of them starting from right to left its their use a flashlight to see it good luck ..let me know /joe/
Posted on Aug 26, 2010
Why is a brand new in wall ac not dehumidifying room
could be to small for room or could be to big for room. It the unit is too big it will cool the room down to fast and shut off to soon, this will not remove the humidity. Try running the unit on a lower temperature the slower the fan the colder the coil which will remove more humidity from room also make sure the fresh air vent is closed and not bringing humidity from out side.
Jun 11, 2014 | Friedrich Heating & Cooling
Hi there, I have a LG ac through wall/window unit LWHD1200FR 11,500 BTU. It's have a Open vent/Close vent mechanism by the front louver from where the cool air comes out. I would like to know what...
The OPEN is to be used when the air temperature is cool enough, not to have to use the AC. When it's open, the fan continues to operate and pulls cool air in from the outside and circulates it inside the room. Generally, this is only used at night, when temperatures are milder and there's less humidity. When it's CLOSED, the AC is in cooling mode and only the inside air is used to cool and is exhausted as needed. Hot, humid days & nights are when it should remain closed.
I hope this helped you & thanks for choosing FixYa.
Jul 29, 2011 | LG Electronic Window Air Conditioner
Why does the air conditioner leak water from behind the unit. My air conditioner is placed in a wall and the back end of the conditioning unit sticks out inside the garage. I have ventilation by...
It is normal for an air conditioner to leak water out the back. This water is actually the humidity being taken out of your house. Being vented out in to the garage is always an issue with condensate water. I have seen some people take a funnel and run a hose outside the garage somewhere. Keep the vent closed. It will be harder to cool the house with the vent open because it lets outside air in to the house.
Jul 04, 2011 | Friedrich Heating & Cooling
Should your exhaust vent be open or close when the air condition is turn on?
It does not mater....when the exhaust is open you will vent a bit of the stale air from the house and pull in a bit off fresh air...if it is closed, it just recirculates the existing inside air...
heatman101
Jun 28, 2011 | Friedrich WallMaster WS07A10D Air...
Friedrich AC through the wall ac leaking water out front vent
pull it out and check for packaging left in ac unit, and make sure drain is clear and large enough for water flow ,,,go ahead and tilt ac unit more and see if that doesnt do the trick
Jul 04, 2009 | Friedrich CP12C10 Wall/Window Air...
Mothers AC unit
That has nothing to do with the water. Sounds to me like it needs cleanning, (the water is not drainning toward the back of the unit) ,,(dirty filter, which its trying to **** air anywhere it can even thru the drain hole, or not enough slope, leanning toward the back so gravity can flow the water to the back of the coil! Thank you-very-much!
Aug 28, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Friedrich RS10J10-C: Only half the coils are chilled...
If the evaporator coil is only half coated with water, this means it is low on Freon. You need a repairman to fix the leak and add Freon, but this costs way over a hundred dollars.
Jul 23, 2008 | Friedrich QuietMaster RS10J10 Air...
Friedrich QuietMaster RS10J10 Air Conditioner Logo
218 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
