Question about Garden
Manual for Ryobi RCS 1835 - Garden
4 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: Has Ryobi RCS 3535A chainsaw a fuel bulb priming
The numbers you supply don't cross to an operators manual but that is typical of Homelite/Ryobi. I'm going to make an educated guess that it does not have a primer system. Other Ryobi saws with primer systems include it in the specification. The 3535A does not. Close scrutiny reveals no primer.
IMO fuel primers on chainsaws are one more source of problems. In the USA ethanol additives attack fuel hoses. Without a primer routing is from the fuel tank directly to the carburetor and much simpler to replace. Primers on chainsaws operate differently than 4 cycle engines too. No fuel is injected into the carburetor or engine, its only purpose is to ensure the carburetor is full of fuel,
Typical Fuel hose routing:
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
HTH
Lou
Posted on Nov 15, 2009
puertobori
  • 7733 Answers
SOURCE: i have a ryobi ECS
at eReplacementParts.com : Power Tool Parts and Tool Repair
Posted on Nov 02, 2010
diodeic
  • 1622 Answers
SOURCE: RYOBI ECS-1835/ECS-2040 leaking oil when
Hi, the question i have to ask is this ,, When last did you service the Engine??
ENGINE VACUUM LEAK DETECTION
Okay, now that we have covered what a vacuum leaks do, how do you find components that leak vacuum? One way is to visually inspect all the vacuum hoses and connections. Look for disconnected, loose or cracked hoses, broken fittings, etc. Hey, you might get lucky and find the problem in a few minutes, or you might waste half the day trying to find the mysterious leak. Vacuum leaks are often the elusive needle in a haystack. And if it is not a hose leaking vacuum but something else such as a gasket, worn throttle shaft, injector O-rings, etc., you may never find it using this technique.
A faster technique for finding intake manifold vacuum leaks is to get a bottle of propane and attach a length of rubber hose to the gas valve. Open the valve so you have a steady flow of gas. Then hold the hose near suspected leak points while the engine is idling. If there is a leak, propane will be siphoned in through the leak. The resulting "correction" in the engine's air/fuel ratio should cause a noticeable change in idle speed and/or smoothness (Note: on engines with computerized idle speed control, disconnect the idle speed control motor first).
Aerosol carburetor cleaner can also be used the same way. CAUTION: Solvent is extremely flammable, so do not smoke or use it if there are any sparks in the vicinity (arcing plug wires, for example). Spray the solvent on suspected leak points while the engine is idling. If there is a leak, the solvent will be drawn into the engine and have the same effect as the propane. The idle speed will suddenly change and smooth out.
TIP: If you have a scan tool, look at the Short Term Fuel Trim (STFT) value while you are using carb cleaner or propane to check suspected vacuum leak points. If there is a leak and some of the cleaner or propane is sucked in through the leak, you will see a momentary drop in the STFT reading. This confirms you have found a leak (keep checking because there may be multiple leaks!).
USING SMOKE TO FIND ENGINE VACUUM LEAKS
smoke leak detection machine A much safer technique is to use a smoke machine. These machines feed artificial smoke into the intake manifold, The smoke may also be mixed with an ultraviolet dye to make leaks easier to see. You then look for smoke seeping out of hoses, gaskets or cracks in the manifold and/or use a UV light to find the leak. This type of equipment is often needed to find small air leaks in the EVAP (evaporative emissions) control system. Smoke machines can cost $600 to $2000 or more depending on the model and features, so they are primarily for use by professional technicians.
Posted on Apr 21, 2011
Where can I get a manual for ETS 1825 saw (Ryobi)1835
I can't online but you can try email the manufacturer.
Oct 14, 2014 | Saws
What size file to sharpen rcs1835 chain
For a standard 3/8 inch chain pitch you would use an 11/64 round file.
There are standard cut files and smooth cut files.
A standard cut file offers the fastest removal rate per stroke and is the most widely preferred chainsaw file. The aggressive tooth pattern of the file yields maximum performance in a minimal amount of time.
a smooth cut file is recommended for those who maintain there chain on a very frequent basis. It removes less metal per stroke, which will extend the life of the chain. Because it's a finer cut file, a skilled user can achieve a sharper tooth.
You will also need a flat depth gauge file. A depth gauge file is a flat file with two round uncut edges.This allows for the correct adjustment of depth gauges, prevents gouging and preserves saw chain life.
Good luck with your saw.
Oct 13, 2014 | Ryobi Rcs-1835 240V Chainsaw 1800W
Spare part reference needed
Brushes are made from tongston steel. you can find them at any electric motor rewind shop. If not in stock they can be made if you have a piece of your old one
Oct 12, 2014 | Ryobi Rcs-1835 240V Chainsaw 1800W
Need new piston,rings and head for rcs 4046c ryobi chainsaw anyone know were ?
Search for Dixie sales in north carolina,they are the distributer for ryobi parts in the US and Canada, lookint the pricing to determine if its wirth the efforts.check the crankshaft and connecting rod bearings for damage also. Its more then likely that they are damaged from the same problem that caused your piston and cylinder to score
Nov 05, 2009 | Ryobi Garden
Engine won't Start on Ryobi RCS 4046C
no spark at plug sends you back to magnita/transformer. ohm it out to see if it has resistance. it should read low resistance. good luck and have a great day please rate bama46, thanks
Aug 16, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
