Question about Epson R245 InkJet Photo Printer
My Espon R245 is refusing to work - its indicating that all the cartridges are empty, they are not empty and they are genuine inks. Can anybody help me to fix this?? Thanks Kay
  • 3,866 Answers
Are these refilled cartiridges?
Probably are so you gonna need to get a chip programmer to basically confuse the system that the ink is full, This does ruin the print head over time that is the reason why they want you to spend money on the real thing. If these are orginal cartridges then the print head is the issue and will need to be replaced.
Thanks for your question please do leave a rating before you leave, Thanks
Posted on Aug 25, 2010
Ho do i know which ink cartridge is low
Hi
the easiest way is to send a print job to printer. If any cartridge is empty, the printer should refuse to print and display an error message. This should indicate which cartridge is empty/not recognised - with a red X above the empty colour. Another way is to go to 'printer properties' then 'maintenance' page and click on 'Status monitor' button.
Hope this helps & good luck with it.
Oct 03, 2014 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
I changed ink cartriges and it won't let me print it says ink is empty. How do you reset the ink levels?
There is no reset for ink levels. When you open the cover do the cartridge lights flash indicating the cartridge is empty. This problem can arise from using compatable cartridges. Try a set of genuine cartridges and the problem will probably be solved.
May 04, 2011 | Canon PIXMA MX350 Wireless All-in-One...
What is the problem if ink out error is appearing always?
If you refilled and replaced the cartridge yourself and the printer doesn't accept that the cartridge is now full, here are the instructions how to reset the ink counter: http://www.fixya.com/support/r1598313-reset_epson_printer_ink_counter_ink
Mar 06, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Cannot recgonize ink cartridge using Espon Stylus NX400
Did you use Epson Genuine Cartridges?
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you. Try the excellent forum below with your similar problems.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Mar 02, 2010 | Epson Stylus NX400 InkJet Printer
My printer keeps leaving lines through my documents I have cleaned the heads all other bits several times.
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
This is the only advice I can give you. If you find this helpful, pls rate me.
Feb 05, 2010 | Epson R245 InkJet Photo Printer
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
False error empty cartridge
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jun 01, 2009 | HP Photosmart C6280 Printer
Cannot print with new ink cartridge
Sounds like a non genuine, aftermarket ink that is dodgy.
if not ensure it is indicating the same colour that you replaced
Dec 12, 2008 | HP Photosmart C6280 Printer
Printer saying refilled bci3e is empty, when it is actually full
This is a very common issue with refilled ink cartridges. The fact is that you have a MP730. The cartridges have an eprom chip loaded into the cartridge which blows once the cartridge is empty. Refilling it as a general rule does not work. The best and only solution to your problem is to pop out to your stationery supplier and purchase a genuine canon cartridge.
As a side not, the ink inside the cartridge is covered by a patent held by canon. it means that no other supplier can use this particular grade of ink. The use on non genuine ink will destroy your printhead and make future use of your unit much less than its normal life expectancy.
Gremlin 11
Dec 10, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Epson r245 not printing black
try to check if the black ink cartridge is not dried up.
Oct 30, 2008 | Epson R245 InkJet Photo Printer
Epson R245 InkJet Photo Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
