Question about Lexmark Office Equipment & Supplies
I have a X7550 printer, I am haveing trouble sending more than 2 pages in the Fax mode. How do I send multiple pages of a FAX?
  • 2 more comments
  • ham305 Aug 25, 2010
    The FAX mode will NOT accecept more. IT ONLY 2 pages. HOW DO I SET/UP THE X7550 TO ACCECEPT MORE THAN 2 PAGES????????
    HELP
    Some one who is familular with the Lexmark X7550
  • 857 Answers
Please follow these steps for help:
Print out the documents that you want to send. Create a cover letter if you are sending professional documents.
Separate documents by fax number. If you need to send faxes to more than one number, make piles for each number you need to fax to.
Set up pages in each document and pile according to how the fax machine accepts pages. Follow the diagram that located on the paper tray demonstrating how to position paper. Place the pages face down or face up on the paper tray, according to the diagram.
Your documents may feed from the back of the stack of pages to the front. It is possible that the fax machine will send the paper on top first. Check the fax's owner's manual to find out exactly how it sends pages. The page order, including your cover page, may be reversed when the recipient receives the fax.
Type the first fax number on the fax machine's dialing pad. Put the area code in first for local faxes that use a ten-digit number. Enter "1" before the area code for long distance faxes. Put in the country and city code, if necessary, if the fax is going to an international number.
5
Send an entire pile of documents at one time if they are all going to the same number. However, do not send more than about 10 to 20 pages at a time if you are using a desktop fax machine. You do not want to overload it. Higher-quality and higher-capacity fax machines can handle much larger documents, but remember that the recipient may not be able to handle too large of a document.
Repeat this procedure for faxes going to different numbers or for documents you have to send to the same number that exceed the approximate 20-page recommended maximum.
6
Push the "Send button" on the fax machine. Listen for the dial tone and the fax number being dialed, as well as the modem tone when the fax is connecting with and sending data to the receiving end machine.
FOR
Computer
Set up a fax modem on your land phone line. This is necessary if you are not going to use an Internet-based fax service.
Scan documents if you do not have copies of them saved on your computer. It is also possible to send faxes from open documents in many word processors.
Save multiple documents as one document if they are to be sent to one fax number. Copy and paste text from different word processing documents, and paste them into a new document. Save that document as either a PDF file or as a word processing document. Ensure the formatting matches your specifications. Add in your own cover letters between each document to ensure that your faxes get to the correct departments or individuals if they are not all going to the same location.
Open the first file you want to send. Choose "Print" from your open file, and select "Fax" as your printer. A fax wizard will open. Follow the instructions in the wizard to fill in the first fax number.
5
Send your faxes online an alternative to using a phone line-based fax modem. eFax Free, FreePopFax, and FreeFaxButton are three of the many online fax services available. These particular services allow you to fax documents online for free, but there are others that you can pay for that may meet your needs better.
Posted on Aug 25, 2010
  • 3,866 Answers
If the FAX is hanging up on the other end might be a 2 page limit on the other side, or you must have a dsl line with a bad filter try using a new filter if that is the case.
There can be allot of causes to this.
let me know
please do click the accept button for my efforts.
  • 10 more comments
  • Grand Canyon Tech
    Grand Canyon Tech Aug 25, 2010
    its already set up
    What i was telling you is there might be a fax limit on the other end, i will find you a manul just one min.
  • Grand Canyon Tech
    No where in this manual does it say anything about limiting to 2 pages
    http://images.lexmark.com/publications/p...
    I think there is some other problem here that you deflected to another expert.
    Allow me to help you
    I CANNOT PROGRAM THE X7550 TO EVEN STACK MORE THAN 2 COPIES. HOW DO I STACK MORE PAGES, THAT HAVE TO BE STORED IN A SEPERATE FILE.
  • Grand Canyon Tech
    this would be a feeder issue and not a settings issue my friend and i would be so thanksful if you took off the caps lock, internet leet speak means your yelling ot get your point across.
  • Grand Canyon Tech
    Load an original document faceup into the Automatic Document Feeder (ADF) or facedown on the scanner
    glass.
    Note:
    Do not load postcards, photos, small items, transparencies, photo paper, or thin media (such as magazine
    clippings) into the Automatic Document Feeder (ADF). Place these items on the scanner glass
  • Grand Canyon Tech
    glass.
    Note:
  • Grand Canyon Tech
    if you not using the above media and its regular paper then you have a defective auto feeder sensor point in case here like i was trying to explain to you
    THERE ARE NO SETTINGS FOR MORE THEN 2 PAGE FAX YOU LOAD THE PAPER IN THE (ADF) AND LET IT TAKE THE PAPER.
    Note:
    No expert on Fixya.com or otherwise is going to tell you anything diffrent, I am providing you quality help here.
    if you haveign so much of a ADF problem then the printer need to be fixed point in case.
    press the accept button for my efforts.
    I don't think you understand the probleum. I go to the Fax mode , I must scan in all pages when I do it will only allow 2 pages to send. I cannot get the other 3 pages to load. I can't send, It sayes will only accecept 2 pages. I am still waiting for asouloutio to stack all 5 pages cover
  • Grand Canyon Tech
    RTFM
    There is no settings or otherwisein the manual for multi faxing i am rather thinking its a issue with the unit.
    None of these solutions help me. Thanks , but no help
  • Grand Canyon Tech
    I reckon Call lexmark to get the same answers, good day!!
  • Grand Canyon Tech
    what size paper are you faxing?
Lost my manual and don't know how to send a fax. Not sure which tray the document goes in. Can you help?
Directly from HP's manual on this printer:
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
For more assistance with this printer, you can go to http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=441125& and download the owner's manual. It is in PDF form, so you will need adobe reeader which you can get for FREE at http://www.adobe.com
Rose Marotta
PC ICU
Danville, Va 24541
For all your computer repair needs.
Jul 11, 2011 | HP Officejet 5610 All-In-One InkJet...
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
Insstructions for sending a Fax on a Brother
You can find the entire user manual by clicking here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Or, here are the instructions for sending a fax:
Entering Fax mode 5
To enter fax mode, press (Fax), and
The LCD will show the new job number and
the memory available.The number of pages
you can scan into the memory will vary
depending on the data that is printed on them.
Faxing from the ADF 5
a Make sure you are in Fax mode .
b Put the document face down in the ADF.
c Dial the fax number using the dial pad.
d Press Black Start or Color Start.
document.
Note
• To cancel, press Stop/Exit.
• If the memory is full, the fax will be sent in
real time.
Faxing from the scanner glass5
You can use the scanner glass to fax pages
of a book one at a time. The documents can
be up to letter or A4 size.
You cannot send multiple pages for color
faxes.
Load your document on the scanner
glass.
If you press Black Start, the
page. Go to step e.
If you press Color Start, the
machine starts sending the
document.
Do one of the following:
To send a single page, press 2 to
choose No. (or press Black Start
again).
To send more than one page, press
1 to choose Yes and go to step f.
Put the next page on the scanner glass.
Press OK.
starts scanning the page.
Dec 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
Will not fax but will receive
Sounds like you are faxing multiple pages through the document feeder and it is trying to grab a few sheets instead of just one.
If you are doing multiple pages make sure they are aligned and separated.
Maybe fan the pages and then pat them on a level surface to make sure they are aligned.
Jun 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Laserjet 3015 will not fax more than one page a time
Open up the document feeder and clean the roller and pad with alcohol.
Jun 08, 2009 | HP LaserJet 3015 All-In-One Printer
SENDING A FAX TO MULTIPLE RECIPIENTS AT ONE TIME
Type in the first fax number, then hit the Enter key (the check mark), then type in the next number, hit the Enter key, and so on until you've gotten all of your numbers entered. Then hit Start Fax.
Feb 25, 2009 | HP LaserJet 3050 All-In-One Printer
I need to know how to send a Broadcast fax to multiple numbers
This is right from the manual:
You can use the Multiple Send feature, which allows you to send a fax to
multiple locations. Originals are automatically stored in memory and sent
to a remote station. After transmission, the originals are automatically
erased from memory.
1 Press Fax.
2 Load originals face up into the ADF, or place a single original face
For details about loading an original, see page 5.1.
3 Adjust the document resolution and darkness to suit your fax needs.
See page 9.1.
4 Press Menu until Fax Feature appears on the bottom line of the
display and press OK.
5 Press the Scroll buttons until Multi Send appears and press OK.
6 Enter the number of the first receiving fax machine and press OK.
You can use speed buttons, speed dial numbers, or group dial
numbers. For details, see page 10.2.
7 Enter the second fax number and press OK.
The display asks you to enter another fax number to send the
document.
8 To enter more fax numbers, press OK when Yes appears and
repeat steps 6 and 7. You can add up to 209 destinations.
Note
You cannot use group dial numbers for another fax number.
9 When you have finished entering fax numbers, select No at the
Another No.? prompt and press OK or Start.
The original is scanned into memory before transmission. The
display shows memory capacity and the number of pages being
stored in memory.
10 If an original is placed on the scanner glass, select Yes to add
another pages. Load another original and press OK.
When you have finished, select No at the Another Page? prompt.
The machine begins sending the fax to the numbers you entered in
the order in which you entered them.
Manual - see page 54
Dec 15, 2008 | Samsung SCX-5530FN All-In-One Laser...
Please help me send a fax on my HP 5610
Send a fax
You can send a fax in a variety of ways. Using the control panel, you can send a blackand-
white or color fax from your HP All-in-One. You can also send a fax manually
from an attached phone. This allows you to speak with the recipient before sending
the fax.
If you frequently send faxes to the same numbers, you can set up speed dial entries.
For more information on setting up speed dial entries, see Set up speed dialing.
Send a basic fax
from the glass.
2. Press Fax.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Faxing multiple pages
reinstall the printer software. deleted the existing printer software first.
Sep 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
FAX doesn't go through
re-install the unit. What operating system are you using. More detail needed. Perhaps its the modem that is not functioning.
Jun 26, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
