Question about Refrigerators
My Kenmore elite m# 106.556.03.400 is not making ice. The freezer door was left open for a couple of hours by mistake one day and after that that ice maker does not make ice. The trays don't fill with water. The water line to get filtered water out of the fridge is working though. Any ideas? thanks Gary
  • 1314 Answers
SOURCE: fridge freezer door ice maker
the ice maker controls the seloniod the icemaker wire arm must be all the way down .just because the seloniod test good doesnt mean the valve seat isnt stuck the water valves open by your house water pressure if your filter is dirty this can also lower the pressure if the icemaker module is bad this also can cause it if you pull the front of the ice-maker off you will se a bunch of holes if you get a piece of 10 Gage house strip about 1/4 inch off either side and insert it into the holes marked t and h that will test cycle the ice maker they will be close together don't get shocked if the ice maker cycles and doesnt fill and the ice maker fill tube isn't frozen replace the water valve if the ice-maker doesn't cycle replace the brown motor module
Posted on Jan 09, 2008
  • 236 Answers
SOURCE: Red light blinking inside freezer
The light may be telling you that the temperature is not cold enough to operate the icemaker.
You may have a bad defrost timer, heater or thermostat. If you have an ice bucket then it may ot be seated properly.
Stargazer
Posted on Mar 16, 2008
  • 42 Answers
SOURCE: NO WATER IN ICE MAKER
From what you've described, it sounds like you have a defective inlet water-valve.
I would remove your outside rear bottom panel; disconnect the 2 prong wires connected to your ice-maker water valve (blue with black solenoids) and check for continuity using an ohm-meter setting. If defective, replace. Whats' your model #?
Posted on Jan 26, 2009
  • 10865 Answers
SOURCE: Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on May 30, 2009
  • 1218 Answers
SOURCE: I have a Kenmore Elite Model 106. 56619501 and the
Good day,
One of the common problems but not the only one. Go step by step, and it can be solved.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on Feb 03, 2010
Adora freezer on the bottom not making ice
It could be a couple of things. Check to see if the bar that controls turning the ice maker on and off is in the down position. Up is off. My ice makes water line froze in the refrigerator section; no ice and no clod water. Check to see if the cold water is working in the refrigerator section. If not, turn the refrigerator section temperature to 42, keep the door open until it drops to that temp, and wait 24 hours for the water line to thaw. The water and ice maker should start working.
Jul 12, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
How do I take KENMORE ELITE TRIO 596.75533400 out of demo mode?
Try pressing ultra ice and home while the refrigerator door is opened,or ultra ice and the refrigerator pad with the freezer opened. Hold for five seconds. Hope that works.
Jun 12, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
My refrigator isn't making ice, and hasn't in about 6 months?
It could be a couple of resons, I have the same problem. With my refrigator its the water tube that fills the tray freeze up. So I have to shut off the unit, leave the freezer door open for about 30 minutes or so. Then restart the unit.
Jan 31, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
What causes Ice to accumulate on the back wall of the freezer? We had not properly closed the door of the freezer before leaving for an extended time. Now we are having problems.
if you have the freezer in the garage. it hot out there and the warm air will condense ,when u open it all the time. or the seal is not sealing right when its closed.
Oct 24, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Our Kenmore Elite (new last summer) bottom freezer double top doors, stopped making ice. The wire that seemingly controls the ice maker is hanging down in a way that is causing difficulty opening the...
Well, that wire is likely the cause of your issue, somebody probably bent it, and now it gets caught on the door or a basket or a food item or what have you, and since it cannot move, the ice maker will not make ice.
Aug 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Jun 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Jun 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Trio 795.7756 /7757 problem
I had the same problem, freezer full of groceries defrosting or crisper drawer freezing produce. Sears Appliance Repair sent servicemen out twice and both times I was assured the problem was fixed. After freezing produce the third time I insisted they come and get the faulty appliance. The replacement has worked perfectly since day 1. INSIST ON A REPLACEMENT
Sep 03, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
117 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
