Question about Xantrex Technology Heart Freedom 20 12 Inverter
My 2000 Fleetwood Discovery Motorhome has a Heart Freedom Combi Inverter/Charger 2000 watt. I have 120 volts going to the input but have 0 Volts on output #1 and #2 unless I go from Neutral (white) to ground or hot (black) to ground, in which case I have 120 Volts. Terry
  • 1 more comment
  • kenaicoach Aug 25, 2010
    With the inverter input connected and the load removed from the two outputs I have 120 VAC input (between the white and black leads). On both output #1 and output #2 I have 0 volts between the black and white leads but I do have 120 VAC between the white to ground and also 120 VAC between the black to ground. Yes the breakers are on, the fuses are good. Terry
    Ok I will try that. My meter is a Fluke 337 true RMS clamp meter. Thanks, Terry
  • kenaicoach Aug 26, 2010
    Thank you. I will do that. Terry
  • 3,740 Answers
Terry this unit has 2 AC outputs so the reading that you got is correct. I am trying to surmise the actual problem that you have. You may have lost a system ground in the mobile home which would give you power as you stated but no power to the mobile home as the system ground has been lost.
Dumb questions time.
1. Battery voltage above 10 Volts?
2. Have you checked the DC Fuse?
3. Have you reset the breaker on the control panel?
Last test.. is to disconnect all outputs and try a voltage test again. A system distribution short will cause the inverter to go into the self protect mode.
Kelly
Posted on Aug 25, 2010
  • 9 more comments
  • Kelly
    Kelly Aug 25, 2010
    Terry this is from Xantrex about their ground:
    Floating neutral
    The XPower inverters do not have their neutral bonded to ground. This is called a floating neutral which causes there to be any value of voltage between hot and ground and from neutral to ground.
    As long as the proper amount of voltage is present from hot to neutral measured with a true RMS voltmeter, the inverter is working correctly.
    The XPower is designed to have loads plugged directly into it so the fact that the neutral is not bonded to ground is not a safety concern.
    Never bond an Xpower's neutral to ground as this will damage the inverter and will not be covered under warranty.
    Never connect the AC output of an Xpower to an existing electrical system as the vast majority of residential electrical systems do have the neutral bonded to ground.
    I am going back to research Still tyring to assertain what your actual failure is. I am thinking you have no power output anywhere. Are there any LED's lit?
    Kelly
  • Kelly
    Kelly Aug 25, 2010
    Xantrex has really good techincal support you can contact them here.
    http://www.xantrex.com/support/case/tech...
    I have to apologize about not grasping the problem here. I am thinking that your doing the measurements without a true RMS meter and that your getting false readings.
    I hate to site a google search as a reference but these are examples of true RMS Meters:
    http://www.google.com/images?hl=en&s...
    Kelly
  • Kelly
    Kelly Aug 25, 2010
    Terry,
    I think you should perform this continuity test and the real problem may show up. Get a really long piece of wire and plug it into an outlet line (black) or neutral (white). Then disconnect your inveryter output. Use that long piece of wire as a long meter test lead and read continuity back to the disconnected inverter output. ONE of them will read continuity if the chassis wiring is good. ALSO read that same wire to chassis ground to make sure you do NOT have a distribution short. Switch the long lead to the opposite outlet terminal and perform the same checks. Continuity of the distribution wire and to the chassis ground.
    Kelly
  • Kelly
    Kelly Aug 26, 2010
    Hi again Terry. I may have sent you on a wild goose chase. I had to go back and read everything that was discussed for that keen sense of the obvious to hit me right between the eyes.
    Per Xanatrex: As long as the proper amount of voltage is present from hot to neutral measured with a true RMS voltmeter, the inverter is working correctly.
    You stated that you had 0 volts hot to neutral using your Fluke 337 Meter. (nice meter!) That is telling us the that inverter itself has a problem.
    ^--That can be from low battery voltage of less than 13.3 volts.
    Are you seeing any fault LED's illuminated on the control panel?
    Last question this post.. and beacuse of the way the system is set up I can NOT see all posts when replying. You may have alread answered this question.
    The question is: With the load / distribution leads disconnected do you have good output voltage on the output terminals using your Fluke 337?
    Kelly
  • Kelly
    Kelly Aug 26, 2010
    Another thought I have is from what I have read so far this inverter has 2 AC outputs. I am assuming you have checked both outputs.
    Kelly
    I have found the problem. It is a stuck relay on a circuit board. I need to know who I can order the circuit board from as the repair center here will not sell it without doing the installation. Terry
  • Kelly
    Kelly Aug 26, 2010
    Good job on the relay find.
    I came to the conclusion yesterday that it was in internal relay on the board when that keen sense of the obvous hit me and was going to ask that you check power on the board next at the relay.
    There are several sources for relays. Do you have any numbers printed on the relay on the board. I am not kidding just google search the number and you will find sources. Search parameters any search engine: relay "numberhere" in quotes. If it is realy bad as in a zillion results try doing an image search same parameters
    However there are a bunch of distributors / exporters that will come up in the process. You have to weed thru them to find a source. If you can not locate a source pass the numbers off the relay and I am pretty sure I can find you a source in the next 24 hours.
    Kelly
  • Kelly
    Kelly Aug 27, 2010
    Terry a few last comments here. Have you checked the relay coil power? The PCB transformers are notorious for loosing 1 leg of power and you end up changing a relay only to find out the PCB transformer is bad. (Been there done that!) Now I always check the PCB transformer outputs and relay coil power inputs before changing relays. Most PCB transformers have the output voltages on them just above the terminals. Sometimes you have to use a magnifying glass just to see the terminal labels. The usually are in pairs as in pins 1 and 2 = input power 120VAC, 3 - 4, 5 - 6, 7 - 8 all are output AC low voltage power out with the output power being converted to DC via diodes on the main board.
    There will always be that question in the back of your mind.... "What caused the relay or the PCB transformer to fail? My experience is... either water intrusion on to the board or corrosion on the main board. 90 percent of them can be cleaned with isoprophyl alcohol and Q-tips then returned to service after parts replacement.
    It was nice working with you on this one. I respect a person that can use a bit of know how and personal skills how to resolve a tough issue.
    I was serious about helping you find a relay if you need help. I just need the number off of your relay.
    Kelly
  • Kelly
    Kelly Aug 27, 2010
    I know this web page is in the UK. Use the page for looking at your relay needs. I think your going to need either the WJ111 or the WJ114 That is a good part number... but not sure of your main board configuration as far as useabilty. Pretty comon relays though.
    http://www.relays-r-us.co.uk/webpages/pr...
    After you find which one you need.. then again the web searc by part number.
    Kelly
  • kenaicoach Aug 27, 2010
    Kelly, I ordered a new board (part #70013103) to be shipped out tomorrow and should have by Monday. Will let you know if that resolved the problem. Thanks again for your help. Terry
  • Kelly
    Kelly Aug 27, 2010
    I actually did do some more relay research and came up with 2 possible relays... (too late now)
    Both are NEC relays.
    R45−5D20−12 20 amp 5 pin
    and
    R25-5D16-12 16 amp 5 pin
    I don't think either one of them is more than $5.00
    Still got that hmm why did the original one fail hence my recomendation to check the output wires for chassis shorts when the inverter was disconnected. A stuck relay is usually due to a hot contact from a short or.. just an over time heat build up failure. Could just be one of them the inverter relay actually failed things or something else.
    Best of luck with the new 70013103 board. (Let me guess the only source is Xanatrex?) I am pretty sure you have tamed the beast and will be back to normal sometime early next week.
    Again it was a pleasure. This site never has been about the money for me.
    Kelly
Loosing power
You need to add up all of the loads connected to the inverter. A 120watt load at 120 volts equals a load of 10 amps at 12 volts.
Watts= VoltsXAmps.
Add to that any other load on the battery - radio, lights, etc. and the standard vehicle battery will be dead in a short time. You need to either have a bank of large batteries, such as two or three group 27 batteries in parallel, or you need to keep the van running so the alternator can keep the battery charged.
Dec 07, 2013 | Xantrex Technology Xantrex 458 10 12...
Tip
What size of inverter do I need?
The correct size of inverter is an easy calculation and important to ensure long life from the inverter and the life of the appliances getting there power from the inverter. To calculate you take the volts and multiply by the amps which equals the wattage. Every appliance has a tag which must state the volts and amps. Locate the tag to find the information. Here is an example.
Under Counter Refrigerator 1.3 amps (120 volts x 1.3 amps = 156 watts)
Microwave (120 volts x 10 amps = 1200 watts)
Alarm Clock Radio (120 volts x .03 amps = 3.6watts)
TV (120 volts x .6 amps = 72 watts)
You now add all the watts together, since the above list could likely be running at the same time. There is a combine wattage of 1431.6 watts. In this example you would need at least a 1500 watt inverter. However given some unknown variables personally I would get a 2500 watt inverter. Less stress on the inverter, will lengthen the life of the inverter. Had the total been 1,000 watts a 1,500 watt inverter would suffice.
You must also remember that your alternator on your vehicle must be able to keep up with the power demand of not only your vehicle needs but your inverter needs as well.
on Apr 23, 2010 | Electronics - Others
I have a question about a freedom marine 25. If the voltage into the inverter charger is not at 125 volts will the system not charge properly?
I don't know if i'm not reading your question right...but an inverter is an equipment that takes 12 Volts DC and transforms it into 120 AC. The input is a 12 VDC not 125 V.
May 29, 2013 | Boating
Freedom 20 Inverter/Converter Charger installed on Alpenlite RV. When remote switch for solar use (2000 watt) is turned on, all 110 system is energized. Turn solar switch off and voltage check at...
Second Freedom 25 inverter/charger...first one repaired, this one went to fault...started microwave on fire, fried the satillite receiver and possibly other components....installing a Mangnum....."do not let anyone rebuild the Freedom 25" First time about $900.00 to rebuild...this time about $9000.00 with components it fried. Fleetwood LLC Corporate knows of problems and only offer to sell you the conversion kit for about $4200.00....bankruptcy sanctifies previous problems "they" left with us.
Oct 27, 2010 | Xantrex Technology Heart Freedom 20 12...
I recently bought a used 2004 Fleetwood Discovery 39L with a Xantrex Freedom 458 system in it. The system worked (sort of) for the first few months I owned it, but now fails to charge the house batteries....
It sounds as if your inverter has failed altogether. This failure could also be caused by power management having issues.
So far, I know that you have a 2004 Fleetwood Discovery 39L. If memory serves, this is a *30AMP* chassis, with 2 air conditioners, using an intellitec power management panel located above the driver position. If I am incorrect, please advise.
Aug 18, 2010 | Xantrex Technology Xantrex Freedom Xmic...
Freedom Combi inverter/charger stopped working with the remote inside the RV. Replaced remote but still didn't work. I have to press inverter button inside RV, go to inverter outside RV and press...
Sounds like the link between the inverter and the remote is bad. Chaffed wire, broken wire, etc may be the culprit.
You should still have the shorting jumper that came with the Freedom. Put the jumper into the AUX port, and you should now have local control of the inverter. If so, then replace the wiring between inverter and remote.
Aug 08, 2010 | Xantrex Technology Xantrex 458 10 12...
Heart Freedom 20 will not default to generator power.
First of all it is possible that the is no power going into the inverter,trace the input source to see if the connection from the generator is ok. check the fuse if it is broken if not, the contactor or switching relay in the inverter is bad
Apr 06, 2010 | Xantrex Technology Heart Freedom 20 12...
Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
Jan 15, 2009 | Xantrex Technology Heart Freedom 20 12...
Xantrex Technology Heart Freedom 20 12 Inverter Logo
773 people viewed this question
Top Xantrex Technology Boating Experts
Tre Elkins
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
