Question about HP Color LaserJet 2600n Printer
Red is printing pink.
All three color cartridges show half full or better. Black is 1/4 full. Restarted and restored factory settings. Large red area has good coverage but almost pink, it is still printing light. I have the same problem with mine and my cartridges are all brand new. I even purchased a new magenta cartridge thinking I might have a defective one. I have the same problem
    Master:
  • 555 Answers
A manual and troubleshooting guide for your printer can be found here.
Posted on May 05, 2008
  • Matt Jurach
    Matt Jurach May 05, 2008
    from Page 96 (Chapter 8- Printer Maintenance):
    "Environmental differences or aging print cartridges might cause fluctuations in image density. The printer accounts for this with image stabilization control. The printer automatically calibrates at various times to maintain the highest level of print quality. You can also request a calibration by using the HP Toolbox."
    To calibrate the printer at the printer:
    1. Press (LEFT ARROW) or (RIGHT ARROW) until the display
    reads System setup.
    2. Press (SELECT).
    3. Press (LEFT ARROW) or (RIGHT ARROW) until the display reads Print quality.
    4. Press (SELECT).
    5. Press (LEFT ARROW) or (RIGHT ARROW) until the display reads Calibrate color.
    6. Press (SELECT).
    7. Press (LEFT ARROW) or (RIGHT ARROW) until the display reads Calibrate now.
    8. Press (SELECT).
    9. Press (SELECT) to confirm Calibrate now.
My Officejet R80 prints only in red and black; Any suggestions
Color cartridge dried up..Perform clean cartridges through printer properties.. check,,no result, replace color cartridge..
Sep 01, 2012 | HP OfficeJet r40 InkJet Printer
I have artwork that is mostly black text with a logo After printing only 1 or 2 discs the print factory 3 starts making the black red. On another disc that has multiple colors it prints nothing in the...
Welcome to FixYa!
Solution 1. You might want to check the ink levels of your printer. One of the ink color might be out. Your printer uses the C,M,Y (one cartridge) and K (another cartridge). The printer mixes this colors (C,M,Y,K = cyan, magenta, yellow and pink) to produce the right colors including black.
Solution 2. Please do a printer head cleaning. You can do it using your printers software maintenance option.
Thank you for using FixYa.Have a great day.
Dec 23, 2011 | MicroBoards PF-3 InkJet Printer
Ink levels show emptry.
Need one plastic plate that you don't care much about, or a plastic disposable plate.
Tear off one section from a paper towel roll and roll it up into about a 1-inch diameter roll.
Flatten the roll
Soak the flattened roll in warm water
Lay the flattened roll down on the plate
Place the nozzle area of the ink cartridge directly against the wet paper towel
Fold the flattened roll as needed to support the ink cartridge so it stands upright.
The trick here is to make sure the cartridge is supported upright so the nozzles come in full contact with the wet towel surface.
The wet towel acts as a wick to soften and draw out the ink.
After awhile, you shoudl see a kaleidoscope of colors on the paper towel. This indicates the nozzles have been opened up and the ink is flowing. Try to print and see what happens.
Repeat as needed.
May 21, 2010 | Dell 926 All-In-One InkJet Printer
Problem with printing black and white photos
Probably what happen is that you are printing black and white but you have your printer on color mode, try to set the printer to grayscale or black and white before print. The printer is tring to get the black and white by mixing all three color, that is the most comon way of make black, so, when one of the color is missing you see those red lines.
Also you will solve the problem replacing the color cartridge.
May 19, 2010 | HP PSC 1510 All-In-One InkJet Printer
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Prints only pink and black
seems ur color catridge is empty with some colors, go for refill or replace
Jul 13, 2009 | HP DeskJet 990cxi InkJet Printer
Print head is mising
PART B - RECOVERY/FLUSH PROCEDURE
1. GENTLY INJECT RED FLUID: Remove the CAP assembly (If not already removed). Place a paper towel in the
cavity where the cap was. Position the printhead over the towel. Remove any ink cartridges. Using a syringe with
tubing, gently Inject red cleaning fluid into each color and black nozzle set. (NOTE: If fluid can not be injected,
install and puddle cap with fluid and let soak for 30 minutes. Retry step 1.)
2. REPLACE THE CAP and RE-INSTALL THE OLD INK CARTRIDGES: Move the CR assembly to the left and
remove the paper towel, dab the area dry with a clean towel. Replace the CAP assembly and reconnect tubes.
3. PUDDLE THE CAP: Fill the cap with red fluid. That is, “puddle” the cap using the syringe.
4. SOAK OVERNIGHT: The printer is now ready to soak. The cartridges in place will keep the fluid in the head, and
the red fluid in the cap will loosen any remaining residual ink.
Leave undisturbed overnight
5. REMOVE THE CAP AND CLEAN: (Yes.. take out the cap and clean it again, just like Part A)
6. GENTLY INJECT CLEAR FLUID: Place a paper towel in the cavity where the cap was. Position the printhead over
the towel. Remove any ink cartridges. Using a syringe with tubing, gently Inject one full syringe of clear cleaning fluid
into each color and black nozzle set (flushing out the red fluid).
7. REINSTALL CAP: Put the CAP assembly back in.
8. WITH POWER ON, INSTALL NEW CARTRIDGES: Place new ink cartridges in the printer using the correct install
procedure.
9. PERFORM CLEANING CYCLES UNITL FRESH INK IS IN THE CAP: It usually takes two to three cleaning cycles until
the cap is “ banded” with color from the ink.
Jul 09, 2009 | Office Equipment & Supplies
Kodak aio 5100 all in one just prints red/pink
An inter active website is being provided by Kodak to help their customer w/ this issue.....Try using www.kodak.com/go/itg and use missing colors for sub class if this does'nt solve the issue call Tech. support. (1 800 421 6699)
Nov 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
have u used this printer quite a bit....? if so the following may be the problem and I just did run across this recently in a printer we had in the shop....I recently read in one of my technical magazines that there may be a design flaw in the placement of the laser scanners and the openings that protect them....it seems that excess toner dust can readily get in to scanner area and specifically inside the scanner assembly and accumalate on the scanner glass and lens. Just cleaning through the opening in the back of the printer will not eliminate the issue. Machine will have to be disassembled, scanner removed and opened and the glass/lens cleaned with a q-tip....the placement of the fan (behind cartridges, lower right) seems to speed this process up and it usually becomes first notable with the magenta cartridge, seeing as it is at the bottom of the printer closest to the fan. Hope this helps..
Inkworks
Oct 04, 2007 | HP Color LaserJet 2600n Printer
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
HP Color LaserJet 2600n Printer Logo
199 people viewed this question
Ben Johnson
