My desk top pc monitor is flickering and a buzzing noise is coming from the lead in the back of the monitor and keep getting a pink tinge to the screen.what is causing this.
  • 3,289 Answers
It sounds like your thin screen monitor's fluorescent (ccfl) back light or associated "inverter" is going to fail very soon.
If either fail, the screen will be black. If you look close - you'll see images on the screen - but because the fluorescent lamp or inverter has failed, there will be no back light source.
You can replace the lamp, inverter or both yourself - or you can send it out for repair. Usually, the yourself route is the only financially feasible option - unless the monitor is a large, expensive type. You should google your monitor's make and model along with "ccfl" "inverter" to learn the options available to you.
Posted on Aug 25, 2010
Display goes black but comes back momentarily when the lid switch is toggled
if the pink tinge forms like lines that means that you have some dead pixels on your screen, so you have to change it,
if the pink tinge is all over the screen, then may be some pixel are dead or it can be a connection problem between the screen and the motherboard, and it's fixeable, tou have to open it and check the connection.
Oct 29, 2011 | HP Compaq nx7010 Notebook
HPL1906 screen has a pale blue tint / haze over that flickers over the screen I tried the buttons on the bottom of the monitor but they just changed intensity of the tint/haze
Try the monitor on another computer first, and check the security and condition of the VGA lead pins.If any are bent or missing that could be the problem. A missing pin will account for part of the signal not being sent from the graphics card to the monitor and could give the blue tinge. Loose connections are also culprits here.
Check there are no strong magnets neat the monitor.
Try a different monitor on your computer.
After that, I think that your monitor could be failing.
Jul 25, 2011 | HP Computers & Internet
Got a compaq desk top model SR2177CL went in and adj. hibernation settings now the screen keeps flickering what is that?
Hi i'm Rain.
It sounds like the settings you have selected may not be what the factory decided. Return the settings back to the way they were.
check to see if that corrects the problem. { Note always reboot after changing settings to ensure that the change takes affect}.
Turn monitor off wait a few seconds then turn back on.
if problem is fixed you can retry to make the changes .
Nov 25, 2009 | Compaq Computers & Internet
My R51 thinkpad screen keeps flickering and is quite garbled it blanks out alot and stays black until you hit FN + F7 (the key to switch from laptop screen to desktop screen) in wich case the screen would...
Sounds like the lcd is toast.
Hook the laptop up to an external monitor and see if you get normal video. If you do, chances are it's the lcd. You'll have to replace it.
Jun 19, 2009 | IBM ThinkPad R51 Notebook
Screen is tinged yellow
It sounds like you're going to need a new VGA/DVI cable. (from PC to monitor)
I suggest you try another one, then post back here if it doesn't fix the problem.
I hope this helps,
Yannick.
Jun 19, 2009 | Samsung SyncMaster 172N 17" LCD Monitor
Compaq 7550 monitor keeps turning pink. Works fine for a few minutes then back to pink and hard to see. Sometimes moving the mouse quickly will help but only for a few minutes. Have tried adjusting all...
Defective CCFL backlight may has the following symptom:
· Screen flashs on red/pink and off.
· Picture stays on in red and slowly be come normal.
· Picture flickering with dim display.
· Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
Monitor is Flickering and screen becomes pink
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it goes back to white, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. I used to check my LCD monitor and could see window image using flashlight and found out that Some of CCFL lamps inside were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Tan
Mar 10, 2008 | Acer AL2017 20" LCD Monitor
Unwanted sound from subwoofer.
switch your subwoofer off from the socket for at least 30 minutes and check if the noise is still there,if its still there open it and play a movie then press it lower if the sound stops then you will have to put some toilet papers at the back of it ,thats what I did to mine.
Feb 19, 2008 | Logitech S200 Computer Speakers
NEC ACCUSYNC 900
Havent you got a person or a friend that has a puter to test the monitor??? This would be the best way as it could be the crt on the monitor or the crt driver board but before we go there we should make sure where the problem lies. Good Luck
May 12, 2006 | NEC AccuSync 900 19" CRT Monitor
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
