Question about Home
How to get toilet to draw water - Home
The bowl in my saniflo toilet has very low water level, and is getting lower. Would you please let me know how to fix this? Thank you, Erin
I know absolutely nothing about the Saniflo system other than the very basic working principle but logically there must be a vent or an airbreak between the macerator/pump unit and the toilet bowl or the pump would tend to create a depression in the container and draw water from the toilet bowl...
Feb 10, 2018 | Saniflo Home
Toilet upstairs sometimes drains when the one downstairs is flushed.
It could be a blocked vent.when the downstairs toilet flushes it draws air down the drain with the wastewater. The vent is suppose to supply air to make up for this. If the vent is blocked or there is no vent. Air is drawn from the easiest place ,in this case through the upstairs toilet,drawing the water out of the toilet trap with it. In northern climates the vents sometimes frost shut causing the problem you describe. Hope this helps.
Jan 14, 2014 | Home
Water ridge toilet manual
Thus if the tank is continuing to drain down through the bowl into the sewer line, the rubber flapper is not seating properly with the flush. These become worn and torn and are easily replaced. Or, even with a new one installed, sometimes they are not adjusted properly to create the appropriate balance between play and pull. Play being the upward connection to the flush handle and pull being the downward draw with the gravity flow of the water. Too much play it won't actually flush or lift properly. Too much pull it does not seat tightly or won't lift up long enough to allow enough water to flow through to flush the toilet...as engineered by the geniuses who designed the toilet. A simple adjustment of the chain links attaching the flapper to the flush handle and perhaps a side to side turn of the cuff so the flapper is aligned to seat properly as it drops should be sufficient. And test, test, test, test, and test again until you're absolutely sure you've got it adjusted correctly. One or two flushes is not sufficient!
Dec 08, 2013 | Plumbing
My kohler persuade toilet won't fill up
Kenny, the gurgling sound is coming from a stoppage in the air vent located above the toilet on the roof. It has to be open to allow proper drawing of air to pull the contents from the toilet. You also have something lodged in the trap as the water goes out. If a snake doesn't clean it out, then you probably will need to take the toilet up and clean from the bottom side. You can a hose with a sprayer and bllast out from the bottom and most of the time that will free up the blockage.
Feb 18, 2013 | Kohler Persuade Two-Piece Elongated Toilet...
My saniflo works ok with shower water but as soon as I use soap and water becomes foamy it does n't draw the water away, just whirls no suction
Have you checked to see if any thing is in the drain that has clogged it . This is an obstruction problem as I see it.
Feb 05, 2013 | Home
Toilet tank...leaking into bowl
rubber flapper in the center of the tank replace.
May 03, 2017 | Home
Five year old Toto toilet has developed a very slow flush in the past few weeks. Plumber has found no clog in line and water from hose flows freely with no back up. We have two other similar Toto toilets...
This can happen if there is a hole (physical damage) inside the trap. Instead of the weight of the water during a flush causing it to drain right down suddenly and completely, it draws in air and loses the momentum. There could be a hole or a crack, which may be hard to find without removing the unit.
Feb 19, 2011 | Toto Ultimate One-Piece Toilet MS854114
How much draw down (tightening) do use to attach the water tank to the toilet bowl on a American Standard Flowise Cadet 3 toilet? Does the tank need to meet the bowl?
Seat the tank well on a new wax ring and then tightnen the two bolts on the sides evenly there is a small amount of pressure but thats it. To much and you'll snap the side of the bowl. You can caulk around the edge if you want more security,less movement.
The tension on the nuts is very tricky just a feel kinda thing.
Be carefull not to over do it.
Sep 04, 2009 | American Standard Cadet 3 Right Height...
Home Logo
13 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
