Question about Acer Aspire 5630 Notebook
Power point broke can i replace it - Acer Aspire 5630 Notebook
    Problem Solver:
  • 10 Answers
If it is internal that is broken then you mite be able to get a pc repair shop to replace it but it has to be considered wether the cost of replacing this is going to outway the cost of the laptop as it can cost as much as 100.00GPb. if it is the charger that is broken then a universal is available at maplins, pcworld, and most good electronic suppliers.
hope this helps
Posted on Aug 26, 2010
Back cover popped off- won't power up
just replace it motherboard possibly got broke when it hit .
Nov 22, 2017 | ASUS Google Nexus 7 Tablet
Male tip of charging point for Acer a500 broke off
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 09, 2012 | Acer Computers & Internet
My tension pulley broke i got a new one n had it replaced but its still very hard to turn how can i find a leak in my power steering?
Find where fluid is coming out under the vehicle follow clean area caused by flow of power steering fluid to the highest point and most foward point as gravity and air resistance causes fluid to flow down and towards the back of vehicle. Highest most forward point is source of leak.
Jan 12, 2011 | 1997 Buick LeSabre
Buckle on 5 point harness of stroller broke.
Hi I have a trends for kids stroller and I los the harnes, where can I buy those
Feb 09, 2010 | Chicco Cortina Travel System - Discovery...
I first broke the screen on this laptop i changed it but shorted out the invertor at this point the laptop switched on fine with a dark screen after replacing the invertor with a new one it no longer turns...
You should have checked the power voltage rating before using another power cable.
The computer memory or processor must have gone bad.
Check the power rating before connecting another inverter.
Dec 24, 2009 | eMachines eMD620-5133 Notebook
The coupling between magneto and engine broke, and
1) Check the points (inside the magnetor cover) and clean if needed.
2) It could be 180' out of time.
As you rotate the engine and come up to compression TDC, the magneto should trip or 'click' to start the spark. If that click is on the exhaust stroke, it is out of time.
*Magentos will make a very sharp bright blue spark, so points, condensor, and coil is very important.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 23, 2009 | Electrical Supplies
Power window cable connection point -broken tab on plastic piece
the regulator has broken.you will need a new one.they do repair kits for golfs and beetles but not for passats you have to replace the whole regulator.dont attempt it unless 100% confident they can be tricky.
Apr 27, 2009 | 2001 Volkswagen Passat
When powering on it just flickers has been dropped 2 times
There is a short somewhere within the DS. At this point, your going to have to get a new one or send it in for repair. here is the direct repair and troubleshooting line for nintendo 800-255-3700 hope i've helped in some way :)
Mar 19, 2009 | Nintendo DS Console
Can't close door after loading film.
sounds like the door latch broke. (tape) Canon will only replace/upgrade not repair.
ours cracked after a drop then broke replacing the film.
Jan 07, 2009 | Canon Sure Shot Z155 Caption 35mm Point...
Acer Aspire 5630 Notebook Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
