Question about KLH DA1302 5-Disc CD Changer
KLH Model DA-1402 5 cd changer tray is stuck in in position
My 04 yukon cd changer won't eject the cd. any advise?
if you push the eject cd magazine button on the changer does it sound like it's trying to eject it? if it doesn't you'll need to replace the changer. if it does, then you've got a stuck cd magazine tray. it sounds weird, but when i was working on land rovers this happened all the time on the full size range rovers. what we did was push the magazine eject button on the changer to eject the cd magazine and sort of slap the changer around a bit. 90% of the time it worked. the other times, we'd go in with a 90 degree pick and try to push the stuck cd tray back into the magazine (while it was still in the changer) while pushing the eject magazine button on the changer. and you'll need to replace the cd magazine. if it happens again, you'll need to replace the entire changer.
Feb 16, 2010 | Car Audio & Video
Cd 6 from the cd changer has stucked. do i have to
Dismount the cd changer so you can open it, and unstucked the cd tray.
Sep 27, 2009 | 2007 BMW Z4 Roadster 3.0si Convertible
2002 dodge intrepid CD changer stuck will not accept CD's
There may be a small pinhole in the front side of the player which into you may stick a straightened paper clip in abuot one inch straight in and the tray/trays should open. Thanks, Dana
Aug 24, 2009 | 2004 Dodge Durango
Sony 5 disk changer disk is stuck not able to open the tray
After some time it was showing some C 31 00 error. I searched on internet, opened the top cover, there is the CD changer and my cd was stuck in there, I pushed the CD from finger and there it goes... on press of eject it came out... thanks anyway...
Apr 02, 2009 | Sony CDP-CE375 5-Disc CD Changer
Sanyo FXCD-500 RB CD/Cassette
Perhaps the disk tray is not in correct position and leave some micro-switch unpressed.
Jul 05, 2008 | Sanyo FXCD-500 RB CD/Cassette Receiver...
Alguin me puede ayudar
Puedes sacar los discos del cd changer,si es asi trata dandole una limpieza al laser.
Mar 30, 2008 | Audio Players & Recorders
Klh cdr2000
If you confirm they are music use CDR's or 'consumer audio' then it sounds like your drive is dead. Can it read normal cd's? When you open the tray can you see that the disc has actually been spun i.e the disc has changed position at all?
Dec 02, 2007 | KLH CDR2000 2-Disc CD Recorder
How do I hook it to The tv
you may have an "intelligent" tv that only turns audio on when video is also present. if your tv is older, then go thru the menu options and look for option that turns back panel inputs to "on"...or it may be as simple as finding that option on the remote control.
May 27, 2007 | KLH DA1302 5-Disc CD Changer
KLH DA1302 5-Disc CD Changer Logo
161 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
