Question about AEG L86800 Front Load Washer
AEG Lavamat 86720 washing machine fault code C3 with buzzer and pre-wash and main wash lights flashing
  • richardson56 Aug 26, 2008
    I had to call an engineer out in the end. Problem was caused by leaking door seal alowing water to drip onto electrical componets.
  • 3,230 Answers
This means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
post further comment for more help......
Posted on May 06, 2009
Although this is way past the posted date I thought I'd post it anyways, I found that water had accumulated in the base of the washing machine, so I removed the back plate and soaked up all the water and used a hair drier briefly just to be sure. Apparently there is a sensor at the very bottom of the machine to prevent flooding.
Posted on Apr 18, 2011
FAULT CODE C 9
Posted on Aug 17, 2008
2 Suggested Answers
  • 3230 Answers
SOURCE: aeg washing machine fault code
This error code means your water sensor has detected a leak. it will stop when the sensor is dry.
What means error code "C9" ? AEG Lavamat 74652
C9Motor tacho fault •Check main drive motor •Check tacho magnet •Check tacho coil •Check module
May 27, 2014 | AEG Lavamat 88840 Front Load Washer
Hi my AEG OKO-LAVAMAT 88830 is about 10n years old. Today I was cleaning my machine. I filled the machine up with water on the rinse cycle then turned it to pump. I did this a few times as I have had a...
According to my list for AEG Lavamat washers, 'C3' stands for 3 possible causes 1 'safety flood device operated' (I suspect it means that it has sensed some water in the bottom tray. Not an easy job to do but I would check for a leak underneath), 2 'pump fault' and 3 'module fault'. Sorry I can not be of more help ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 04, 2011 | AEG Lavamat 88840 Front Load Washer
My wash-machine, AEG oko lavamat 6955, is blinking at the 1500 and 900 buttons, and is showing the code "F9" and the door will not open. How do I fix this? And if I must have a specalist to...
to clear the error code: whilst holding the pre wash and short wash buttons in together turn the control knob from off to gentle spin, this will clear the fault code and run a LED test. (if all goes weel) F9 means carbon brushes need to be replaced
Nov 06, 2017 | AEG Washing Machines
My washing machine AEG lavamat 86800 (1998) blinks C9 and says no centrifuging and pre-wash. Thank you J.
1) Hold in the Pre-wash & soaking buttons TOGETHER;
2) At the same time, turn the knob clockwise from the OFF position, to "Short Spin". All the LEDS light up.
3) turn the knob anti-clockwise to "energy saving"
4) Machine is reset and the door release clicks.
Switch your machine off and then back on again.
Jan 17, 2011 | AEG Washing Machines
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
Fault c 9 is flashing on my oko lavamat 86720
I FOUND OUT THAT C9 WAS SOMETHING WRONG IN THE MOTOR. CHECKED OUT MOTOR AND FOUND THAT THE BRUSHES WERE WORN OUT AND I REPLACED THEM. I THOUGHT THAT WAS MY PROBLEM SOLVED BUT IT WAS NOT THE LIGHTS WERE STILL FLASHING AND C 9 STILL THERE. I PHONED A FRIEND WHO FIXES APPLIANCES.. HE TOLD ME WHAT TO DO TO CONFIGURE IT. LEAVE THE MACHINE OFF AND PRESS THE PRE WASH AND SOAKING BUTTONS TOGETHER AND SWITCH ON. ALL LIGHTS WILL COME ON AND AND MACHINE WILL WORK IT DID BUT YOU MIGHT HAVE TO DO IT A COUPLE OF TIMES.
Nov 06, 2008 | Washing Machines
Aeg washing machine fault code
May 08, 2008 | AEG L86800 Front Load Washer
Aeg 76669 oko lavamat machine not starting all six lights [pre wash, main wash, rinse, rinse , spin, and end] flashing machine three years old just successfully completed wash cycle, loaded up for next...
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Jan 10, 2008 | AEG Washing Machines
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
AEG L86800 Front Load Washer Logo
1,002 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
