Question about Miele T9800 Electric Dryer
My Miele Touchtronic T 9800 Dryer progrma works but when the dryer has ocmpleted its cycle, the cloths are still damp and not dry.. .I have to run the cycle several times to even get near dry cloths. what would cause this issue... thanks
    Scholar:
  • 91 Answers
Hi dear.Try this,that should help you to solve the problem.If you need to download the user manual please click the link below.Thanks.
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T9802_us.pdf
Problem:The laundry is still wet. The program runs too long.
Solution:The air flow is insufficient. Check the lint filter, air intake and vent for obstructions(REFER USER MANUAL)
Posted on Aug 29, 2010
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
Problem with Miele Touchtronic T 9800 Dryer end indicator
You've most likely got a bad control board. You'll have to install a new one which can be a bit expensive but cheaper than a new machine by far. I recommend getting a service tech to replace it for you however if your handy you could replace it yourself. Just get the new control board from an appliance parts store, they should be able to look up which board you need as long as you bring them the model number.
Dec 15, 2009 | Miele T9800 Electric Dryer
My frigidaire dryer will not dry properly( still damp) in automatic mode
Depending on how damp they are, it could be normal or you could have a plugged dryer vent. I say that because on these dryers, the software in the control is programed to leave cloths a little damp in the sensor dry. This is for energy efficiency and less shrinking on clothing. If they are coming out to damp and you need to run them through two cycles to dry them, then the vent is plugged, either in the dryer or the house, and needs cleaned out. When the vent is plugged, the moisture isn't getting out, and the cloths will not dry.
Oct 04, 2009 | Frigidaire Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer tripping electricity saftey switch
You probably have a shorted heating element.
May 15, 2007 | Miele T1322C Electric Dryer
Miele T9800 Electric Dryer Logo
438 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
