Question about Garden
I recently bought a sealey plasmaster 60/1 plasma cutter it is approx 10 year old but unused I connected an airline to it and tried it it worked for s few minutes the stopped now it wont work It appears to work the relays click when the torch button is pressed an output voltage is 156v at torch cable input . The mother board has eight leds L1 to L8 all light whwn the torch button is pressed except L7 what does this mean ?Please help
SOURCE: 60pp9100d/37 60" phillips
I have a philips 60PP9100D/37. It was working just fine then I switched channels and the sound went off and the picture became fuzzy on all channels. So now there is no sound and fuzzy picture. Any ideas?
Posted on Aug 04, 2008
  • 36 Answers
SOURCE: Power Up Problem
You have a 8.6v supply error according to the 7 error code being displayed, what you can try is when the set goes to blinking disconnect the Y sustain board (if looking at the tv from the back the board on the left) from the upper left side of the power supply, if the error code stops then you know your Y sustain board is pulling down your power supply and causing the error, if the error code continues you have a probelm with your Logic Board (located under your Small Signal Board) disconnect this from the Y sustain board and see if the error code stops if it does you know that the Logic board is bad, if the error code is still blinking then the 8.6v supply line from the Power supply is faulty and the Power Supply needs to be replaced
Posted on Aug 13, 2008
  • 52 Answers
SOURCE: Power Up Problems
7 blink error is 8.6 volt error on that model. usually tied to y sustain board located on left side of set looking from back. disconnect y main from power supply and power on and if comes on verify power supply primary voltages located on label on pdp itself. if voltages present you would need to replace that board as not designed for component level repair. however if you find failed components like swollen caps or burnt ic's you could replace those. also when replacing the y main board there are two y buffer boards to left of main board that also would be recommended to be replaced at same time as they work as circuit and replacing one board without other could cause failure to other boards still in set
Posted on Aug 19, 2008
vanni7
  • 163 Answers
SOURCE: Furnace stopped working.
HI!!! Looks like your ignitor has stop working..change your glow ignitor and you should be fine..Good luck..
Posted on Jan 04, 2009
  • 44 Answers
SOURCE: Philips 42'' Plasma TV 42PF7320A/37 red led error codes
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
I purchased a I60 Plasma cutter and I don't have an instructions manual. Can I download one?
Plasma Cutting Guide - Plasma Cutter Tips - The Eastwood ...
www.eastwood.com/plasma-cutting-guide-plasma-cutter-tips-plasma-cutt...
Check out Plasma Cutting Guide at Eastwood tech library to know about ... hasapproximately 25 amps of output, a 1/2" machine has a 50-60-amp output, while ...When buying a plasma cutter, the manufacturer should provide cutting .... Finally, follow all safety tips and guidelines that are detailed in your instruction manual.
How To Select And Operate A Hand-Held Plasma Cutter ...
https://www.millerwelds.com/.../how-to-select-and-operate-a-hand-held-...
The actual process of operating a hand-held air plasma cutter unit is relatively .... If you only have 115V primary service, don't worry. ... 50 or 60 Hz. This means you can plug this plasma cutter in anywhere in the world. ... If you opt to purchase such a unit, position it as far away from the particle ... Plasma Cutting Roller Guide.
Best Plasma Cutter Reviews 2015 - AIR TOOL GUY
Dec 27, 2015 | Welding Tools
Is the internet article about the 60 year old pristene house true. It says it wasnt lived in for 60 years and yet still has pristine appliances. What happened to rust?
If you mean the kitchen with the pink exterior, you might want to ask the person that bought the house in 2010 directly. He's still selling the unused appliances.
Feb 24, 2015 | Cars & Trucks
Uniplas 30 power light flashing
See if the torch electrodes MIGHT be stuck... welded together. They have to arc and then separate or unit will shut down.
Jun 15, 2012 | Welding Tools
Consul propane fridge. No cooling. Pilot and flame work fine. I cleaned and checked flue. Has been no leakage. Fridge has been unused for 6 months. Approx 10 years old.
Check to make sure it is level. If so, the thermostat may have failed causing the fridge not to try cooling. If you still need help feel free to call Mt Hope Hardware at 330-674-7474 and ask for service. We stock most of the parts you should need. Thanks
May 07, 2011 | Refrigerators
Spectrum 2050 plasma cutter . Cutter blows air and stops when trigger is pulled no pilot arc or any cutting when trig is released air flows again and stop after 10 sec new tips was working the day...
Check compressed air pressure is in limits otherwise unit will cut out. Try adjusting the pressure up. also make sure the supply pressure is correct as it may not be your plasma cutter at fault.
Jul 30, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Plasma cutter no cutting
the tech is probably pretty close to the cost of board,but you may have moisture in air that still wont take out the p.c..you have a warrenty on the unit,go to your local welding store and request a new one if refussed tell them you want to talk to the miller salesman which they should have no problem to set up.if not call miller direct in appleton wisc.they are good people.
Apr 07, 2010 | Miller Spectrum 375 X Treme Plasma Cutter...
Pro cut 25 plasma cutter : turn it on and get a fault and hear air leaking from some place. will not cut just a safety fault
yes you need to find and fix the leak, it will show fault if not enough air pressure is there, double check airline connection exterior, and then airline interior after regulator valve also check for are around the regulator,
hope this helps.
Feb 03, 2010 | Lincoln Welding Tools
The lights are working for power and gas pressure but not the DC arc....BIG Repair problem?????? It a Pak Master 25 Plasma cutter from Thermal Dynamics bought 15 years ago
No, Try changing the tip. The one under thr node cone. If it burns back it will concave and increase the gap between the work and gun tungdten electrode.
Oct 30, 2009 | Welding Tools
Plasma cutter started cutting at an angle even when held perfectly perpendicular. New consumables were put on, same amperage, same air pressure. I'm stumped!
did you put all new consumables in ,sounds like there is still old one there.make sure nozzel is put back together right.I have worked on welders and plasmas for years,the torch head is very tempermental.
Mar 01, 2009 | Miller 903777012 SPECTRUM 2050 PLASMA...
Garden Logo
248 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
