Question about Dacor Preference SGM365SS Gas Cooktop
Hello We recently remodeled our ktich and have a dacor preference renaissance cooktop. My plumber installed the gas line. As part of the installation, Dacor required to install a gas regulator which my plumber did. We tested to ensure there were no leaks and none were recorded. However, since installation, we once in a while get a smell of gas. Then the smell goes away. We have drawers underneath the cooktop. Most of the time, when the drawer is open there is no smell. However, once in a while, there is a gas order as if you think there is a leak. I talked with my plummer and he suggested I check out more about the regulator and its use. Does the regulator vent out gas if there is too much pressure in the line? If there was a leak, both my plummer and I believe we would consistenly smell gas throughout the ktichen. That is not the case. So, I would like to know more about the gas regulator that Dacor supplies with the unit. Is it suppose to vent gas if there is too much build up in the gas line? Could the regulator be faulty? We would love to receive some feedback.
    Genius:
  • 1,340 Answers
I googled the problem to make sure I remembered how they worked.The only problem that would cause regulator leak is improper adjustment on a brand new one if the pressure is too high.It also talks about the spring which helps regulate the gas may lose its springiness,after several years though.There are numerous safety measures to stop the gas from coming out if you have a pilot light and it goes out which I did already know.I also know that NEVER will a regulator just simply release the gas into the air from overpressure.That would not even be allowed by anyone in the entire industry.Also,when your drawer is closed,then you open it,do you get a little whiff of gas?Natural gas(is that what you have?) does not have an odor in it's natural state.After it is drawn,a chemical is added so you can smell it and tell if there is a leak.If the odor is very minimal,it may just be the pilot burning if you have one.I would say it would likely be consistent if there was even the smallest of leaks.I used to repair gas appliances however...I was born with no sense of smell.I am including a link to you so that you can learn a little more about gas regulation.Also,I would be persistenet with your plumber and ask him to come over and do a checkup,and just tell him you are very worried about the situation since it could have obviously dangerous results,and it will give you peace of mind.They should do it for free,they better.Tell him you just want him to come over and make a quick gas reading.Hope this helps you out.If you have any questions about what you are reading,I know how all that stuff works,is designed,or whatever.
Just comment to this post and I will get an auto link.
Good luck! Greg
http://www.inspectapedia.com/plumbing/GasRegulators.htm
Posted on Aug 25, 2010
  • Greg McCarthy Aug 25, 2010
    Also I just thought of something.The gas company may come out and do a free check.Tell them what you did and your concerns,see what they think/recommend and go from there.
    Good luck! Greg
After cleaning one of the small burners will spark
make sure the little hole right by the ignitor isn't plugged.
Jun 15, 2010 | Dacor Preference SGM365SS Gas Cooktop
Dacor sgm304s, Ignitor constantly snapping.
under burner control knob broken plastic cam that operates switch.
Sep 07, 2009 | Dacor Preference SGM304 Gas Cooktop
I melted the knobs for my dacor cooktop and the model number for the cooktop is: SGM365S.  What do I need to order and from whom? Thanks, Sanford
You will have to order from a dacor dealer. Check with the manufacturer for a dealer near you. try 1-877-DDS-DACOR
Jan 28, 2009 | Dacor Preference SGM365SS Gas Cooktop
Converting LP to NG
The install manual on the dacor web site insists that Natural Gas requires the nozzles be removed, that low pressure NG works with the large 'default size nozzles'. Have done the conversion, in Australia, for my own barbecue, worked ok
Gas is too dangerous to make mistakes with. All I can suggest if Dacor is difficult is take the pdf of the installation instructions, link in the first replies, and the barbecue to a local gasfitter/plumber and ask them to work on it. they will be able to do the calculations from the existing nozzle size, lpg pressure, ng pressure, and required BTU output, to put in correctr nozzles
Dacor Australia are much easier to deal with.
(Now res in Canada,)
Bob
Aug 08, 2008 | Dacor Preference SGM365SS Gas Cooktop
Dacor cooktop ignition problem
TAKE THE BURNER CAPS OFF AND CLEAN THEM REALLY WELL AND MAKE SURE THAT THEY R PUT BACK ON PROPERLY THRER ARE GENERALLY A NOTCH THAT HAS TO BE LINED UP JUST RIGHT FOR THE CAPS TO FULLY SEED TO PROMOTE PROPER LITING
May 27, 2008 | Dacor Preference SGM304 Gas Cooktop
Dacor pgm 365 lp to naural gas
Yes by a licensed person so as not to break any local laws or Kill You,
LPg typically delivers at a higher psi than natural gas, and the propane content requires more combustion air than the methane butane mix of natural gas,
methane CH4 needs 2 oxygen (O2) to make CO2 +2 H20
Propane C4H10 needs 7.5 (02) 4 CO2 5 H2O
the nozzle injecting the LPg has small diameter, The Gas certified plumber can remove the nozzle(s) and replace them with larger diameter Natural gas ones for a small price, most manufacturers make both, its a simple job
Cant stress - Gas Certified plumber/tradesman - strongly enough, one explosion will ruin your whole day
May 09, 2008 | Dacor Preference SGM365SS Gas Cooktop
Cooktop burner problem
Your plumber should know that the pipe service your cooker must be of a suitable size. Normal half inch pipe is only good for a couple of small burners. Most installations require one inch! There is a simple formulae for working out the flow rate of the gas. Your gas installer will know it.
Apr 18, 2017 | Cooktops
Propane to Natural Gas Conversion
on the regulator there is a 1/2" nut, made of aluminum. loosen the nut, thur it around and screw it back in, there is a "NAT" on one side, and a "LP" on the other side, make sure the "LP" is facing out if you are using propane, and "NAT", if you are using Natural Gas. Very simple, all you need is a 1/2" wrench, or a small adjustable wrench,
Jan 06, 2008 | Dacor Preference SGM365SS Gas Cooktop
Dacor ignitor keeps clicking
Dacor has updated ignitors with a broad head. Install the new ones and it will very likely cure the problem. You'll need a special spanner wrench to remove the burners. And watch out for the flying keeper clips.
Oct 06, 2007 | Dacor Preference SGM365SS Gas Cooktop
Dacor Cooktop gas conversion
Where did you purchase the kit? Can you name the store with number or list the website? Also the part number information. Thanks
Sep 19, 2007 | Dacor Preference SGM365SS Gas Cooktop
Dacor Preference SGM365SS Gas Cooktop Logo
Top Dacor Cooktops Experts
jdthefixer
Lakeland Appliance...
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
