Question about Maytag Neptune MDE5500AY Electric Dryer
Our dryer stoped working (no heat) right after moving it to another location. spins good ,
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Dryer stoped "heating up" the
heatman101
Dec 27, 2010 | Dryers
My dryer heats up but does not tumble. I replaced
Sounds like worn tub back bearing.
take the belt off and spin the tub by hand to see if it is binding.
check that the pulley isnt loose on the tub back and also the motor pulley, feel if the motor spins free.
Finally check the tub itself for objects poking through or lodged in the outer tank.
Good luck
Mar 18, 2010 | Dryers
How do I find the thermal fuse to a Kenmore Dryer? It comes on and spins but no heat.
for kenmore dryer the thermo fuse, most often they are on the air duct. or located on the heating element can. The can is located on the bottom right in the dryer and holds the heating element..hope this helps pls do let me know
Jan 12, 2010 | Kenmore Dryers
I have a whirlpool dryer that will spin but will not heat or shut off automatically?
some dryer 's have belt sw on them if belt breaks dryer stopes ( no spin ) if dryer stops no heat . replace the belt and it should work .. other problems / ck the power if 220 you may have lost 1 leg . dryer will go but heat and will not shut of auto . mm
Dec 09, 2009 | Dishwashers
Tumble dryer spins, but doesn't heat up
You need an ohm meter to do needed checks. Unplug dryer from power,,, then look for sensors and locate the heat coils. Using the ohm meter, check each device by connecting meter to the posts ( your looking for an open curcuit) Note that when you touch the leads of the ohm meter together, the gage will move? This is closed condition, and if the needle did not move, this is called "open". When you find a sensor or heat coil that reads open, that part is bad.
Now make sure there is not a tripped breaker in the fuse panel of the house,,, because even though the dryer is 220 volt,,, 110 volt runs the tumble motor while the other 110 volt curcuit runs the heat side ( so one will work without the other)
Oct 10, 2009 | Tricity Bendix TM310W Electric Dryer
My Whirlpool Imperial Series Dryer is 4 years old. NO Heat.
Sure there is. The cheapest I have found is on amazon. click here Dryer Heating Element 279838 For Whirlpool Kenmore and take a look. I hope this was helpful. cheers
Sep 07, 2009 | Dryers
Dryer stpped working
with power disconnected
if any wire disconnected before any test, reconnect & test dryer, reconnect wires after each test
disconnect wires from start button and test, conduct when pushed, no conduct when release
if fail replace start button test dryer
disconnect wires from door switch and test, conduct when pushed, no conduct when release
if fail replace door switch test dryer
follow leads from start button to relay(relay is first device connected to start button), and make sure all wires connected at both ends. If any wires disconnected, test dryer
locate thermostats and thermal fuses on fan housing and ducts
individually disconnect wires from each and test. conduct good, no conduct fail
replace any failed thermal fuse or thermostat test dryer
if all prior test OK
replace relay, test dryer
Oct 10, 2008 | Magic Chef CYE4000AWW Electric Dryer
Gas dryer lgr4634eqo GAS
check the thermal fuse located at the back of the dryer for continuity and let me know how you make out
Sep 13, 2007 | Whirlpool LGV4634JQ Gas Dryer
No heat, timer not advancing
If the timer advances in timed cycle but not automatic, you have a bad heater thermostat.
Apr 10, 2007 | Kenmore 62622 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
