Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
I'm not totally sure this is my model number but my fride seems to be involentarily stopped working...its on but its not cooling...help!
    President:
  • 2,702 Answers
Check that there is power to it first then check the thermostat is still working,,if the thermostat has broken down the freezer wont run at all
Posted on Aug 25, 2010
Maytag mff2557hew fridge not cooling. Freezer ok. Fan in back seems to be workingt. cleaned coils, cleaned all around it, checked door switches. could it be the thermostat? If so where would it be and how...
i am not a expert just trying to help,,, try pulling fride out and checking the line from freezer down to the pan and made sure it is clear,cause this will keep the air from flowing,, hope this help
Oct 20, 2009 | Maytag MBB2256G Bottom Freezer...
Just stopped working: plugged in,light on,fan blows in freezer-
defrost timer probably failed in defrost mode go online search for defrost timer location and manually advancing or initiating a defrost cycle , it may pop into run mode and tell you thats what it is , 90% of the time thats it and they are cheap !
Aug 23, 2009 | Amana ABB1927DE Bottom Freezer...
Refrigerator stopped freezing & cooling
can you hear compressor working
Apr 05, 2009 | Refrigerators
Fridge portion of my 611 is warm but freezer is still cold. Help.
The only other thing that seems could be wrong is that your freon lines are icing up and is cause you to not cool properly. Pull out your fridge and check the compressor on the bottom
Feb 07, 2009 | Sub-Zero 611 / O Bottom Freezer...
GE Side by Side with leaky water inlet valve
WR57x10051 is the correct part number. The full model number can make a difference. Glad to help so thank you and if you'd care to take the time to rate my assistance I'd appreciate it and have a great week end.
Jan 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Dometic RM2652 cooling cois cold to touch.
If the controls are working correctly, it is defiantly a problem with your cooling unit, either blockage or else leak. The best way to find out if it is the cooling unit is the problem is to disconnect the the heating element from the circuit board and add a 110 plugin so you can plug the heating element directly into a wall outlet. Make sure it gets hot (the heating element) and let it run for at least 6 hours. The frige dosen't need to be on during this time because all controls are being bypassed if the fride dosn't make cool it is a bad cooling unit. If it cools you probably have either a short, or the main circuit board is bad. (in 1993-1996 Dometic used a yellow epoxyed circuit board that almost allways went out at about 2-5 years of use)
Dec 24, 2008 | Dometic NDR 1292 Refrigerator
Samsung window air conditioner model aw05ncm7 icing up not cooling
After I opened the front of the unit and discovered it full of ice, I left the unit off until it defrosted, so to speak, after the ice had melted, I turned the unit back on to see what happened. It is working fine now, I'm not sure why it iced up, if this is normal or not, but after it melted the problem was solved.
Jul 22, 2008 | Heating & Cooling
I am having problems with my samsung fridge model - SR-S2028CSS
does it freeze at all? you may have a problem with the coolent in the back of the fride which if so (depending on the cost of the fride) may be cheaper to replace, also the dial you use for selecting the freeze level could be faulty
Feb 19, 2008 | Refrigerators
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
24 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
