Question about Sony Playstation 3 (PS3) Console
Thers no picture or sound with my playstation 3 im using hdmi also tried 3prong cable
    President:
  • 1,139 Answers
Please carry out the following steps to fix your PS3 :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Posted on Aug 25, 2010
Sony Playstation 3. There is no picture, only sound through HDMI cable connection to TV from my playstation 3.
Does your HDMI cable was placed properly through the television and in the PS3 unit ? , If Yes then does you HDMI cable have defects ? If No then whats your PS3 ? Slim or Super slim or Fat ?
Oct 26, 2013 | Video Game Consoles & Games
Im not getting anything (soud or picture) with the red, yellow, and, white cords. thats because it is set for the HDMI cable. how do i get the picture to come in without a HDMI compatable TV?
Sounds to me like you will need to plug the PS3 into a HDMI capable display and change the output settings on the PS3 to composite / AV.
Then reconnect to the non HDMI TV. The red, yellow and white cables should now work.
Mar 20, 2011 | Sony Playstation 3 (PS3) Console
I turn the playstation on in my television using the three prong wire (yellow, red, white) and it will not work on my television it starts up but it soon sounds like it stopped running. I took the...
Please use HDMI cable to connect the PS3 to your computer when you found that it is working with that it. It only shows that your three prong cable is defective as it fails every time. Try with another three prong cable and see the results. I will still insist you to use HDMI cable which will give you better picture quality and sound.
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
Hooked up BluRay with HDMI cable and I can hear sound but no picture.
problem with the cable! try using the same cable HDMI cable for another system i.e dvd player, something that has an HDMI in-port
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
I am currently trying to hook up my playstation to my t.v. in the hotel & I have tried component cable, as well as an HDMI cable & the t.v. shows the cable is plugged in on the icon screen but...
connect the HDMI cable to the TV, then hold the "on/off" button on the ps3 for a few seconds, this causes the output settings to reset and the video/sound should work.
Dec 13, 2009 | Sony Video Game Consoles & Games
No Picture
Do a manual reset hold the power button when you turn it on till it beeps twice that should fix it. Or just MSG back
Mar 06, 2009 | Sony Playstation 3 (PS3) Console
HDMI green screen
1-HDMI is available in several versions. The PLAYSTATION 3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PLAYSTATION 3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
The HDMI cable is not included with the PLAYSTATION 3. If you are using an HDMI to DVI converter, you may wish to remove this adaptor.
2- The resolution output (i.e., picture quality) of the PLAYSTATION 3 will depend on three factors:
The type of cable used and the inputs available on the TV or display monitor.
The maximum resolution the TV or display monitor can support. The PLAYSTATION 3 can output two types of resolution: HD and SD. Refer to the TV or display monitor's owner's manual to check which video modes are supported.
The maximum resolution programmed into the source material (movie or game). Refer to the software packaging for information on maximum resolution details or contact the publisher directly.
3- Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HMDI setup and/or equipment.
4- Disconnect any coaxial cables at the point closest to the television. Signals sent through coaxial cables may cause interference with the sound and picture outputted from the PLAYSTATION 3 which results in buzzing and humming noises from your display and speakers.
Nov 29, 2008 | Sony Playstation 3 (PS3) Console
Ps3 problem
Change the resolution on the ps3 to accept 480p, 720p, 1080i, 1080p.
Jun 14, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
Hi there!
Try replacing the Playstation cable. It may be faulty.
Regards, JUS004
Mar 31, 2008 | Hitachi 57G500 57" TV
What do i need to got sound out of my hdtv?im using a hdmi to dvi cable.
if you have no optional external speaker on the ps3 you may have an earphone socket which can be connected to your tv's pc sound input via a 3.5mm or 6.5mm jack plugs.
Aug 13, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
