Question about Acer Aspire One Netbook 8.9" Notebook
My acer aspire 1 is getting too hot too fast, anything i can do it gets hot within 15 minutes and i dont want it to burn up
    Problem Solver:
  • 10 Answers
This is a common problem with older models of laptops as the cement on the processor is not making contact with the processing chip, this is fixable but can cost quite a lot, if it is a cheapish laptop thewn i would suggest that you get a cooling stand for it which will cost approx: $30.00<br /> <br /> <a rel='nofollow' href="http://www.google.com/products?hl=en&amp;rlz=1G1GGLQ_ENGB267&amp;q=cooling+stands+for+laptops&amp;um=1&amp;ie=UTF-8&amp;ei=AlV2TOTXCIqOjAe6x_2mBg&amp;sa=X&amp;oi=product_result_group&amp;ct=title&amp;resnum=1&amp;ved=0CD0QrQQwAA">http://www.google.com/products?hl=en&amp;rlz=1G1GGLQ_ENGB267&amp;q=cooling+stands+for+laptops&amp;um=1&amp;ie=UTF-8&amp;ei=AlV2TOTXCIqOjAe6x_2mBg&amp;sa=X&amp;oi=product_result_group&amp;ct=title&amp;resnum=1&amp;ved=0CD0QrQQwAA</a><br /> <br /> hope this helps?<br />
Posted on Aug 26, 2010
Acer Aspire 3680 laptop keyboard walked over by cat - now will not let me type - have cursor but no letters appear
Shut down the laptop and remove the battery . Now allow 15 minutes and then replace the battery back to boot again. If the PC does not respond with the keys, it must be checked if the cat had soiled the key pad and there is a short within.
Oct 06, 2011 | Acer Aspire 3680 Laptop
Ive forgoten my login password and i dont have a reset disc how can i get back in to my acer aspire l100
I believe probably the easiest and safest way for you is remove your Windows OS Passwords with Windows Password Recovery tools. I found a good one at http://www.reset-windows-password.com last week, and then I downloaded it and used it to remove the lost password within only few minutes. Furthermore, the powerful tool didn't cause a little data lose. It's worth an attempt.
Aug 28, 2011 | Acer Aspire L100 PC Desktop
My 99 deville gets hot fast. within 15 minutes it's over 262. i've replaced the thermostat and it's still overheating. help!
Thanks for choosing FixYa and welcome to the site. 15 minutes is real fast to overheat. You may have a bad water pump. You still want to make sure you do not have a leak no where. It is possible that you won't see the leak and it ends up in your oil pan. Start the vehicle and observe the engine. Check for leaks at the hoses and cap. You may need a new coolant cap. Make sure your fans are kicking on correctly. If they are not, check the fuse. If the fuse is good, it is either a bad fan or a bad wire. You want to check your radiator also. Make sure it is working. Make sure you have coolant in the vehicle, and not all water. Water burns up quick. If these all check out, check your water pump to see.
Apr 24, 2011 | Cadillac DeVille Cars & Trucks
How do i reset my acer aspire one to factory default is ther a download for it
You can get restore CDs from Acer if you didn't burn them when you got your computer. Alt F10 is supposed to get you to the restore partition. Power on, hit Alt F10, you may have to hit F10 several times while holding down ALT button. If you get anything but the restore menu, you don't have restore or you didn't hit F10 fast enough.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Oct 02, 2010 | Computers & Internet
I am running Wxp on my Acer L100. After about 15
first things first pls check if the cpu fan is seated properly.
if not pls try to reseat the cpu fan, but before doing it put thermal paste on top of the cpu to haver a better contact on the cpu
if the fan is seated properly check the rpm of the fan on bios mode see if the rpm of the fan is fast enough.. if not then there's the problem.
this things only happens if the cooling system of your processor is malfunctioning. Your built in hardware monitor tends to turn of the computer to prevent further damage,,
Jan 11, 2010 | Acer Aspire L100 PC Desktop
Problems in mouse usb in laptop
i had this problem with wireles mice is it wireless if so then dont buy wierless cause ive gone trough atleast5 that burned out within 1 month
Jun 23, 2009 | Acer Aspire 1355LC Notebook
Dvd for acer notebook won`t burn
1. check ur dvd can burn dvd or just read dvd 2. your burning software my not compatible with yor optical drive
Apr 09, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 5040
With laptop's that lack smart battery technology, If you dont excersize your cells you lose their capacity. Smart Battery Tech. forces the cells to discharge their energy on their own after being hot for so long they just cut off the power being supplied to them and discharge back down to less then 10% charge, then they recharge.
Think of it this way, what happens if you dont excersize, you let yourself get fat and lazy. Chances are good you will die quicker then the guy that does. Same goes for the cells of the battery.
  1. Also please note If the battery is the one that came originally with the system, they never have a long lasting capacity to start off with unless of course you pay for the longer life battery you tend to get maybe an hour and a half. Also if you are covered under the warranty period still most manufacturers allw you at least 1 battery replacement. Hope all that helps you!
Jul 05, 2008 | Computers & Internet
Acer Aspire One Netbook 8.9" Notebook Logo
362 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
